Page 684 of 854 FirstFirst ... 184584634674679680681682683684685686687688689694734784 ... LastLast
Results 10,246 to 10,260 of 12803
  1. #10246
    Jul 2016
    Poland Alkoholand
    I have connection problems with my "real" HEXv2 - STM32F405 chip. Can works nicely and quick but K-line is crappy. No communication in A4 b6/b7 and a6 c5 with some modules like 37 navigation and 56 radio ( RNSE ) , 77 telephone ( bluetooth module ) , even sometimes cluster.
    On KKL cable and Hex based on Atmega no problems with communication - so it's not a problem in the car.
    Firmware updated , checked on different version of VCDS ( 20.12 , 20.04 , 18.9 ) - still the same problem , here's a photo of insides of cable , two l9637d are used to communicate on K lines - maybe its their fault? Any idea? Maybe some settings?
  2. The Following 3 Users Say Thank You to bendzji For This Useful Post:
    Col19 (6th February, 2021), EpicFail78 (20th January, 2021), kaalis (20th January, 2021)
  3. #10247
    Jan 2021
    I actually did some code change with it on my 2018 Atlas with 20.12.0. I think it's working at least for now.
  4. #10248
    Nov 2020
    Quote Originally Posted by badrax View Post
    If anyone with the non upgradable 405 want to do some testing then please PM me for more details
    STM32F405 VCDS Hex-V2 can update freely by VII Plua Loader
  5. #10249
    Nov 2020
    Quote Originally Posted by bendzji View Post
    Already fixed, use VIIPlusLoader-08.021.01-EN-Installer, update it
    VIIPlusLoader-08.021.01-EN-Installer.rar mega.nz download link:
    https://mega.nz/file/FxkVxQgZ#Pknh_d...YwHSpDv1zxUTBU
  6. The Following 5 Users Say Thank You to flyfvdi For This Useful Post:
    EpicFail78 (20th January, 2021), marujo62 (1st June, 2023), Papiti56 (20th January, 2021), seal777 (21st January, 2021), Tomate (21st January, 2021)
  7. #10250
    Nov 2020
    Quote Originally Posted by StanNB View Post
    OK. My 405 is upgradable and works fine with VII Plus Loader in any language.
    But my 415 don't work with the loader, is not upgradable and only support VCDS up to 20.4.1 and only in english.
    For the 415 I need a solution to upgrade, like in your video.
    415 vcds hex v2 never update, with many bugs, can not support multi-languages
  8. #10251
    Jul 2016
    Poland Alkoholand
    @flyfvdi not fixed , have the latest update installed and firmware upgrade , it was the first thing I have done after encountering these problems
  9. #10252
    Jan 2021
    Germany, Baltic Sea
    Quote Originally Posted by flyfvdi View Post
    Yes, normally. But there are some PCB with 405 that are not able to update with VII Plus Loader.
    True, too. For now. But maybe we'll find a way to update 415. It's not impossible.
  10. #10253
    Nov 2020
    please contact me by private message, i can give you the vcds 405 factory technical support engineer contact mode.
  11. #10254
    Nov 2020
    This is 405 vcds v2 can update by VII Plus Loader
  12. #10255
    Dec 2020
    all 405 vcds v2 can update by VII Plus Loader
    This one cant
  13. The Following 2 Users Say Thank You to badrax For This Useful Post:
    Col19 (6th February, 2021), kaalis (21st January, 2021)
  14. #10256
    EU
    Just got this from obd2ct. FW updated.
    Various ecu connections:
    CAN ok
    K1 ok
    K2 does't work.
    That didn't help either. Tried 20.12.0.0, 20.12.0.1 in combination with various viiplusloader.
    Sent from my VOG-L29 using Tapatalk
  15. #10257
    Jul 2016
    Poland Alkoholand
    I have similar problem. I'm in contact with fly and someone from enginneering staff - they are trying to find a solution.
    What car are trying to connect so that k2 doesn't work? A4 b6 and a6 c5 after 2002?
  16. #10258
    EU
    Doesn't really matter: A4 B5-B6-B7 and A6C5 various modules which sit on K2.
    02 trans K1 ok
    08 hvac K2 FAIL
    15 airbags K1 ok
    16 steering K1 ok
    25 immo K1 ok
    34 level control K1 ok
    35 central locks K2 FAIL
    45 inter monitor K2 FAIL
    55 headlight range K2 FAIL
  17. #10259
    Nov 2020
    Quote Originally Posted by kaalis View Post
    CAN ok
    K1 ok
    K2 does't work.
    please contact vcds v2 405 factory technical support engineer
  18. #10260
    Nov 2020
    This one cant
    There are two copy vcds hex-v2 factory. your v2 is not good.
    this pcb v2 is best. support multi-languages. update freely.
  19. The Following User Says Thank You to flyfvdi For This Useful Post:
