Page 685 of 854 FirstFirst ... 185585635675680681682683684685686687688689690695735785 ... LastLast
Results 10,261 to 10,275 of 12803
  1. #10261
    Nov 2020
    There are two copy vcds hex-v2. one is good , another is bad.
  2. The Following 4 Users Say Thank You to flyfvdi For This Useful Post:
    Bastard2 (25th January, 2021), Col19 (6th February, 2021), drdahmani2 (21st March, 2021), Toljanoss (24th January, 2021)
  3. #10262
    Jan 2020
    Can anyone tell me if the clone hex v2 offered here by fly or others also works on a vw golf 8.
    Can someone confirm this with a vcds scan
  4. #10263
    Dec 2020
    Quote Originally Posted by flyfvdi View Post
    Yes. That's what I been trying to say all the time.
    Finally we agree on something
    But the one you call "not good" also support upgrades just like the 415!
  5. The Following User Says Thank You to badrax For This Useful Post:
  6. #10264
    Dec 2020
    Some update on my work on upgrading the 415
    I have made a new "firmware" / code to dump the whole 415 chip so that we can see what version of the bootloader is installed.
    This is coz I see that there are different version of it from feedback I have received from some forum test users.
    The bootloader I have on my 415 is verifying some code at address 0x08040000 and when crc8 is verified it reads the reset vector from it and jumps to this address. This code at 0x08040000 is actually a unmodified (or I believe this) firmware that contains the correct checksum and it's base address is actually 0x08010000. Now at this address 0x08010000 is a patched version of the firmware but it is using the same reset vector so when the bootloader jumps to it then all is good. My firmware is also patched to read the UID (AES encryption key) from the bootloader section which makes my firmware and bootloader compatible with each other (Use a common key).
    My patched firmware at 0x08010000 also calls a function at address 0x08060000 just to receive the base address used to set the VTOR register in the 415.
    So we have these four things that need checking:
    1. Firmware code verifier
    2. Reset vector to jump to
    3. What UID to use
    4. Get VTOR address
    From forum testers I have seen changes on 1, 3, 4. Until I see some other bootloaders I cant tell if 2 also is different.
    My firmware dumper could potentially handle all four of these tests but number 1 might require brute forcing if crc8 is different then mine.
    So as you can see. This is not strait forward and for all of you asking to test "upgrading" please be aware that flashing could brick your cable and make it unusable.
    And when I say "upgrading" that is to flash my dumper code or to flash the 4508 firmware only available atm.
    (Still reading? Good )
    Dumper code. (For you that are willing to do testing and to brick your cable)
    My dumper code behaves like a new firmware and when started by the bootloader it converts the cable into a USB mass storage device for you to access from your OS. You will see that one of your cables LED turns solid white and you will also see a new drive letter with the name FLASH.
    On this device there will exist two files:
    "extra.bin" which is the OTP area (One Time Programmable)
    "flash.bin" which is the whole flash memory of 1 meg.
    It will stay this way for 2 min and after this you will see the LED blinking yellow for 10 sec for so to start the bootloader again and wait for a new firmware upgrade.
    If you run out of time then just disconnect and connect your cable again and you will have 2 more min.
    Copy these files or make a zip container for so to send to me
    Your cable will now stay like this until you receive a new firmware from me after I have looked at the bootloader.
    regards
  7. The Following 17 Users Say Thank You to badrax For This Useful Post:
    AndreaEl (23rd January, 2021), Bastard2 (25th January, 2021), bvm5by (24th January, 2021), Col19 (2nd February, 2021), Creteil (23rd January, 2021), djzxz (23rd January, 2021), drdahmani2 (21st March, 2021), H2Deetoo (28th February, 2021), hbalazs (16th July, 2023), jan4 (24th January, 2021), kaalis (23rd January, 2021), miouser (23rd January, 2021), mrle9 (23rd January, 2021), nicu1979 (24th January, 2021), Tib82 (26th January, 2021), Toljanoss (24th January, 2021), ZIPPO4594 (23rd January, 2021)
  8. #10265
    Jun 2019
    Dumped and sent to you.
    Thanks for all the hard work you are putting into this, much appreciated
  9. The Following User Says Thank You to Ganja47 For This Useful Post:
  10. #10266
    Dec 2020
    Quote Originally Posted by Ganja47 View Post
    Awesome. Thanks for being the first guinea pig
    Will send you a firmware you can flash back to so you can use your cable again.
  11. The Following User Says Thank You to badrax For This Useful Post:
  12. #10267
    Jun 2019
    no worries. worked a treat, cable back to normal if anyone else needed reassurance to participate
  13. The Following User Says Thank You to Ganja47 For This Useful Post:
  14. #10268
    Mar 2019
    What did I do wrong during installation?
    When Windows starts, it seems it is running an update service.
    Kolimer loader was of course not running at Windows start-up
  15. #10269
    VCDS is setup on startup, i saw that after instalation vcds set startup command, and probably check for updates...
    Sent from my SM-G970F using Tapatalk
  16. #10270
    Dec 2019
    Post for Download
  17. #10271
    Jan 2019
    PL
    there is probably a newer loader than the one provided in the flyfvdi post, please link maybe someone has the file rar password
    https://www.chinaobd2.com/service/vc...ownload-7.html
    https://mega.nz/file/sHRBRCyK#QXsDcm...BBT67mTUs2Nxyg
    VIIPlusLoader-08.021.02-EN-Installer
  18. The Following User Says Thank You to szpectronik For This Useful Post:
  19. #10272
    Aug 2020
    Quote Originally Posted by szpectronik View Post
    https://www.digital-kaos.co.uk/forum...UAL-NO-PASS!!!
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  20. The Following 4 Users Say Thank You to crouchinggerbil For This Useful Post:
    Col19 (6th February, 2021), JTengyel (31st January, 2021), stefanncm (29th January, 2021), vernnon (28th January, 2021)
  21. #10273
    Aug 2020
    Quote Originally Posted by bg17aw View Post
    That is because the software is updatable. The loader does not affect updates.
  22. #10274
    Jan 2019
    PL
    Please new loader VIIPlusLoader-08.021.02 no pass
    https://mega.nz/file/hPoSTIqA#aWQwkn...bntWsqb5eEZsVU
  23. The Following 3 Users Say Thank You to szpectronik For This Useful Post:
    AYD (26th January, 2021), Col19 (6th February, 2021), mrle9 (25th January, 2021)
  24. #10275
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    any update changelog ??
