Page 687 of 854 FirstFirst ... 187587637677682683684685686687688689690691692697737787 ... LastLast
Results 10,291 to 10,305 of 12803
  1. #10291
    Dec 2020
    This is how it looks like without the stm chip in case you ever wondered
    Looks like they are using RTOS os this time. Also a small bootstrap code to copy and boot from ram so definitely a new firmware type.
    Main firmware now at address 0x08020000 and is about 180k in size.
    Will be fun to dig deeper.
  2. The Following 7 Users Say Thank You to badrax For This Useful Post:
    Bastard2 (1st February, 2021), Col19 (2nd February, 2021), jan4 (31st January, 2021), jaubertel (31st January, 2021), kaalis (31st January, 2021), mrle9 (31st January, 2021), Tib82 (31st January, 2021)
  3. #10292
    How can I change install directory of vcds? I want to run from an other place. When VII Plus installed first time it asked what directory I want to use...
    Now i got "Software startup failure" message from loader.
    thanx for reply
  4. #10293
    Aug 2020
    Quote Originally Posted by digiservice View Post
    thanx for reply
    You can choose folder when you do install.
    Delete and start again.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  5. #10294
    Jul 2016
    Poland Alkoholand
    Or drag vcds exe to vii loader window it should update path to exe
  6. #10295
    So, when I choose an other directory to install vcds, VII loader can not able to start the vcds. I wonder if how can I setup the working vcds directory in VII.
    (drag and drop not works)
  7. #10296
    Aug 2020
    Why dont you just leave in default directory..... Problem Solved........
  8. #10297
    Because the first install was in a different directory. Now i want to use the default... :-(
  9. #10298
    @digiservice
    delete UserData.db in C:\Users\PCUSER\Documents\VIIPlusloader\
  10. The Following 8 Users Say Thank You to miouser For This Useful Post:
    AYD (4th February, 2021), bendzji (31st January, 2021), bg17aw (10th February, 2021), Col19 (6th February, 2021), digiservice (31st January, 2021), kaalis (1st February, 2021), Yhoni (2nd October, 2022), ZIPPO4594 (31st January, 2021)
  11. #10299
    Jul 2016
    Poland Alkoholand
    you are right - with the drag and drop method you can start any vcds.exe but it doesn't save it as default path
  12. #10300
    miouser, it works!
    Thank you mate!
  13. #10301
    Nov 2020
    thanx for reply
    uninstall and reintall it
  14. #10302
    Quote Originally Posted by flyfvdi View Post
    Can ask your programmer to delete UserData.db file when uninstall the loader? because uninstall and reinstall not work always to solve problemm.
  15. The Following User Says Thank You to liviudiaconu For This Useful Post:
  16. #10303
    EU
    Quote Originally Posted by Tib82 View Post
    VCDS 20.12.0 HGJ (20210129 DS322.1) released
    SHA1: aa29301574b5b21f27e7c73ae9ea8940604a8c5f
    Recent releases of 20.12
    MFT, ROJ, DRV, PCI, AIB, NEZ in late january.
  17. The Following User Says Thank You to kaalis For This Useful Post:
    miouser (1st February, 2021)
  18. #10304
    May 2013
    Hi there Guys.
    Got VCDS china cable... The cheaper type and not the ARM MCU type.
    It was V20.4.2
    Was working fine until suddenly it shows LICENSE REVOKED. Obviously it's a clone but what solution to get it working again? DOes it need a reflash and which files? Or do we just need a loader or something?
  19. #10305
    Jul 2019
    Use Kolimer loader and firmware
