Page 688 of 854 FirstFirst ... 188588638678683684685686687688689690691692693698738788 ... LastLast
Results 10,306 to 10,320 of 12803
  1. #10306
    Quote Originally Posted by miouser View Post
    @digiservice
    delete UserData.db in C:\Users\PCUSER\Documents\VIIPlusloader\
    Tested: If delete UserData.db WITHOUT reinstall loader, then loader will ask all the times wich version VCDS want to launch. If delete .db file and reinstall, will ask first time only. You can choose how is OK for you. That because .db file is generated only at install.
  2. The Following 5 Users Say Thank You to liviudiaconu For This Useful Post:
    AYD (4th February, 2021), bg17aw (10th February, 2021), digiservice (3rd February, 2021), jakuza (2nd February, 2021), ZIPPO4594 (1st February, 2021)
  3. #10307
    EU
    NEZ released 20.12.0.3 today.
  4. #10308
    I use Kolimer loader with VCDS 20.4.2 and now would like to update software, please can you point me the right direction?
  5. #10309
    Aug 2020
    Quote Originally Posted by Diablotic View Post
    Download it from ross-tech website and reuse the loader to launch
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  6. #10310
    May 2018
    Has any way to fix it ?
    VCDS ATMEGA162
    Tried change USB cable, Uninstall e Reinstall drivers... doesnt fix.
    Maybe hardware issue, right ??
  7. #10311
    EU
    Change ftdi chip to known good.
    Sent from my VOG-L29 using Tapatalk
  8. #10312
    Good to know, Thank You.
  9. #10313
    Oct 2018
    Quote Originally Posted by bendzji View Post
    Or drag vcds exe to vii loader window it should update path to exe
    hi, do you have test VIIPlusLoader-08.021.03 K2 all worked out? thanks
  10. #10314
    Oct 2018
    VIIPlusLoader-08.021.02 and VIIPlusLoader-08.021.03 with new bugs!
  11. #10315
    EU
    Post rod file as text, image is too small to read.
  12. The Following User Says Thank You to kaalis For This Useful Post:
    Col19 (6th February, 2021)
  13. #10316
    Jul 2016
    Poland Alkoholand
    08.021.03 works for me and A4 B6 / B7 - k1 k2 and can ok
    I was propably the first tester of 03 beta because there was no communication with telephone module address 77 ( On K1 in my car ) - 02 repaired K2 issues
  14. #10317
    Quote Originally Posted by obdcarsale View Post
    Just use : Postimages
    Upload your screenshot to the WEB page of « Postimages », let them encoding multiples URL's to your screenshot and use the one named « Thumbnail for forums ».
    Here is the result of what it do (clicking on the thumbnail redirect to a viewer for image in original size) :
    Hope it help...
  15. The Following User Says Thank You to Creteil For This Useful Post:
  16. #10318
    Oct 2018
    the old VIIPlusLoader-08.020.13 without this problems!
  17. #10319
    Oct 2018
    thanks for you help!
  18. #10320
    EU
    Actual filename is EV_GatewNF_VW37.rod
    VCDS detected cable as clone and switched some letters.
