Tested my 415 upgraded to support VCDS 20.12 on my electric 2019 car
Looks like it supported them all. I used auto-scan and holy shit it was fast compared to my older genuine HEX-CAN interface which took ages to complete scanning.Code:01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 23-Brake Booster -- Status: OK 0000 29-Left Light -- Status: OK 0000 39-Right Light -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: Malfunction 0010 51-Electric Drive -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 75-Telematics -- Status: OK 0000 8C-Hybrid Battery -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 BD-Hi Volt. Batt. Charg. -- Status: OK 0000 C5-Therm. mgt. -- Status: OK 0000 C6-Batt. Chrg. -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000
Was playing around in vcds and everything seems to work just fine. Did not test any coding so don't know if that works yet
Anydraj (12th February, 2021), Aucor (10th February, 2021), Creteil (10th February, 2021), crouchinggerbil (10th February, 2021), drdahmani2 (29th January, 2022), DreamLand69 (13th February, 2021), jan4 (10th February, 2021), mrle9 (10th February, 2021), nicu1979 (14th February, 2021), paro44 (12th February, 2021), Toljanoss (11th February, 2021)
Hello badrax
Your vcds hexv2 work with loader or not?
Thks
badrax, which loader version are you using (if any)?
some reported bugd and errors with latest 08.021.03
badrax is working on the development of the update for a « STM32F415 » chip, until now, it was not possible...
Also, until now, it is claimed to use a « STM32F405 » for the reason given above.
Are you sure at your side you have a « STM32F415 » based cable ?
By the way, for now, like badrax say « Was playing around in vcds and everything seems to work just fine. Did not test any coding so don't know if that works yet ».
So, it would be better to wait another time for badrax making some tests about coding on recent platform, to be sure his work can benefit to others users with this kind of interface...
At your side, if you asking what version of loader you need to use, then, you probably have a « STM32F405 » chip based cable.
Hello badrax, where can dwonload eeprom and flash, i have many STM32F415 cables
I flashed my 415 back to the original firmware it came with and used VCDS 20.4.1 to test on my same electric car.
This is the auto-scan list it produced:
And you can see that these are missing from my last test (using 405 FW 01.02.05):Code:01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 23-Brake Booster -- Status: OK 0000 29-Left Light -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: Malfunction 0010 51-Electric Drive -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 75-Telematics -- Status: OK 0000 8C-Hybrid Battery -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 BD-Hi Volt. Batt. Charg. -- Status: OK 0000 C5-Therm. mgt. -- Status: OK 0000 C6-Batt. Chrg. -- Status: OK 0000 E0-Auxiliary Display 1 -- Status: OK 0000
Code:39-Right Light -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000
And this is new on the org fw:
Code:E0-Auxiliary Display 1 -- Status: OK 0000
One thing I noticed which are the same for them both is that module "03-ABS Brakes -- Status: OK 0000" shows OK without a fault but when the module was scanned it actually contains a fault:
Fault when using 405 FW:
Fault when using org 415 FW:Code:Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb Component: ESC Revision: 00000000 Serial number: Coding: 01FA40A12C21216E477C060361CA2980023484E26086943338915078C2E203 Shop #: ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019 ROD: EV_Brake1UDSContiMK100OMG_003.rod VCID: 2 Faults Found 8400 - Databus U1123 00 [032] - Received Error Message [FCAN: AB_Gurt_FA signal is invalid] Intermittent - Not Confirmed - Tested Since Memory Clear 16401 - Tire Pressure Warning C102D 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear
It does not show the same text but I guess this could be coz of VCDS 20.12 vs 20.4.1?Code:Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb Component: ESC Revision: 00000000 Serial number: Coding: 01FA40A12C21216E477C060361CA2980023484E26086943338915078C2E203 Shop #: ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019 ROD: EV_Brake1UDSContiMK100OMG_003.rod VCID: 2 Faults Found 8400 - Databus U1123 00 [032] - Received Error Message [Tip-TNF 239934] Intermittent - Not Confirmed - Tested Since Memory Clear 16401 - Tire Pressure Warning C102D 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear
Try to use both 20.4.1. If you can.
I had bad situation when I was trying to use vcds 18.2 loader with vag-com 17.8 (old eeprom). All information was different in coding and adaptation. Like another car.
hi which is the latest VIIPlusLoader for 405 chip has anyone a link to it please. many thanks.
Education is not the learning of facts, But the training of the mind to think
So hit the thanks button if I have enlightened you.
Here you go mate
https://www.digital-kaos.co.uk/forum...UAL-NO-PASS!!!
HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
WOODWARD395 (12th February, 2021)
