I flashed my 415 back to the original firmware it came with and used
VCDS 20.4.1 to test on my same electric car.
This is the auto-scan list it produced:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
23-Brake Booster -- Status: OK 0000
29-Left Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
51-Electric Drive -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: OK 0000
8C-Hybrid Battery -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
E0-Auxiliary Display 1 -- Status: OK 0000
And you can see that these are missing from my last test (using 405 FW 01.02.05):
39-Right Light -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
And this is new on the org fw:
One thing I noticed which are the same for them both is that module "03-ABS Brakes -- Status: OK 0000" shows OK without a fault but when the module was scanned it actually contains a fault:
Fault when using 405 FW:
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Component: ESC
Revision: 00000000 Serial number:
Coding: 01FA40A12C21216E477C060361CA2980023484E26086943338915078C2E203
Shop #:
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003.rod
VCID:
2 Faults Found
8400 - Databus
U1123 00 [032] - Received Error Message
[FCAN: AB_Gurt_FA signal is invalid]
Intermittent - Not Confirmed - Tested Since Memory Clear
16401 - Tire Pressure Warning
C102D 00 [032] - -
Fault when using org 415 FW:
Component: ESC
Shop #:
VCID:
2 Faults Found
8400 - Databus
[Tip-TNF 239934]
C102D 00 [032] - -
It does not show the same text but I guess this could be coz of
VCDS 20.12 vs 20.4.1?
