Page 695 of 854 FirstFirst ... 195595645685690691692693694695696697698699700705745795 ... LastLast
Results 10,411 to 10,425 of 12803
  1. #10411
    Mar 2018
    Quote Originally Posted by cebbes30 View Post
    Hello All,
    I have used this cable by fly on my VW Golf 8, but not working well even an error message component protection on my airbag have cause this with this cable!!
    Engine 01, 8107 Antenna, 811E, 811F, 8120, 8121 not accessible!!!
    Be careful with this in new cars, like me you need to go to the dealer to resolved this error.
    811E-Burglary Protection FL"
    811F-Burglary Protection FR"
    8120-Burglary Protection RL"
    8121-Burglary Protection RR"
    the original scanners also do not code - you need to have an account VAG, and generate tokens for access - but these are all plans for now.....
    http://www.vag-com-espanol.com/EN_SF...al_for_UMB.pdf
  2. The Following User Says Thank You to Roma77 For This Useful Post:
    badrax (15th February, 2021)
  3. #10412
    Jan 2020
    Hello All,
    Please look at this site and you see that the orginal is working!
    With the cable
    2021 Golf 8 Style e-Hybrid: | Ross-Tech Forums (ross-tech.com)
    Wednesday,06,January,2021,14:51:32:29555
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
    Data version: 20201125 DS322.1
    www.Ross-Tech.com
    VIN: WVWZZZCDZMW3 License Plate:
    Chassis Type: CD-VW38 (5WA)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 4B 4B 51
    52 5F 6C 75 82 8C A5 C6 D6 D7 8107 811E 811F 8120 8121 C002 C003
    VIN: WVWZZZCDZMW3-----
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    23-Brake Booster -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    4B-Multifunc. Module -- Status: OK 0000
    51-Electric Drive -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Cannot be reached 0100
    75-Telematics -- Status: Malfunction 0010
    82-Heads Up Display -- Status: OK 0000
    8C-Hybrid Battery -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: OK 0000
    C6-Batt. Chrg. -- Status: Malfunction 0010
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    8107-Antenna -- Status: OK 0000
    811E-Burglary Protection FL -- Status: OK 0000
    811F-Burglary Protection FR -- Status: OK 0000
    8120-Burglary Protection RL -- Status: OK 0000
    8121-Burglary Protection RR -- Status: OK 0000
    Address 01: Engine (J623-DGEA) Labels: None
    Part No SW: 04E 906 014 AB HW: 04E 907 309 FH
    Component: 1.4l TFSI hy H20 1211
    Revision: K2H20000
    Coding: 011D403263640D0830080000000000000000000000000000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM14TFS01104E906014AB 001008
    ROD: EV_ECM14TFS01104E906014AB_VW38.rod
    VCID: 609855427AC4943B132-8034
    6 Faults Found:
    34193 - Implausible Data Received from ESP Control Module
    U0416 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 4 km
    Date: 2020.12.01
    Time: 09:27:14
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 38 ∞C
    Intake air temperature: 31 ∞C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.980 V
    Unlearning counter according OBD: 39
    Cruise Control System (CCS): status-Bits 0-7: 0
    Drivetrain coordinator: ACC fault status-Bits 0-7: 0
    Drive train coordinator irreversible switch off conditions: 0
    Drive train coordinator reversible switch off conditions: 2155905024
    Drivetrain coordinator: brake fault status: 5
    23419 - Implausible Data Received from Diagnostic Gateway Module
    U0447 00 [032] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 4 km
    Date: 2020.12.01
    Time: 09:27:15
    Engine RPM: 1597.50 /min
    Normed load value: 30.2 %
    Vehicle speed: 34 km/h
    Coolant temperature: 63 ∞C
    Intake air temperature: 13 ∞C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.880 V
    Outside temperature: 10 ∞C
    Absolute intake pressure: 65 kPa abs
    Engine torque: 75.2 Nm
    Fuel: tank fill level: 6.0 l
    Electric drive torque: actual value: -30.5 Nm
    Operating mode control expanded electrical driving: False result
    Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
    High-volt. battery: charge state: abs. value: 36.70 %
    23765 - Control unit for information electronics 1
    U1054 00 [032] - No Communication
    [Information electronics control module 1No Communication]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 39
    Mileage: 4 km
    Date: 2020.12.01
    Time: 09:27:21
    Coolant temperature: 15 ∞C
    Intake air temperature: 10 ∞C
    Ambient air pressure: 1020 mbar
    Voltage terminal 30: 13.960 V
    Outside temperature: 9 ∞C
    Absolute intake pressure: 102 kPa abs
    Engine torque: 0.0 Nm
    Fuel: tank fill level: 4.8 l
    Electric drive torque: actual value: 0.0 Nm
    High-volt. battery: charge state: abs. value: 33.35 %
    43768 - Release / Enable Active
    B184C 00 [032] - -
    4178 - Fuel Injection Malfunction
    P0148 00 [096] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 11 km
    Date: 2021.01.04
    Time: 10:21:12
    Engine RPM: 385.50 /min
    Normed load value: 37.3 %
    Intake air temperature: 11 ∞C
    Voltage terminal 30: 14.760 V
    High fuel pressure: specified value: 20.828 MPa
    Fuel high-pressure: actual value: 16.960 MPa
    High fuel pressure: regulator output value: 2.3080 MPa
    Low fuel pressure: specified value: 547.8 kPa
    Fuel pump: specified value: 64.59 %
    Low fuel pressure adaptation value for EFP: modeled: 120.0 kPa
    Fuel: tank fill level: 5.0 l
    4201 - Fuel Level too Low
    P1250 00 [047] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 11 km
    Date: 2021.01.04
    Time: 10:21:13
    Engine RPM: 1114.50 /min
    Normed load value: 12.9 %
    Voltage terminal 30: 14.820 V
    Unlearning counter according OBD: 0
    Absolute intake pressure: 37 kPa abs
    Engine torque: 18.3 Nm
    Electric drive torque: actual value: -8.0 Nm
    High-volt. battery: charge state: abs. value: 33.10 %
    Readiness: 0000 0000
    Address 02: Auto Trans (J743) Labels: None
    Part No SW: 0DD 906 556 HW: 0DD 300 046 J
    Component: GSG DQ400 H33 0361
    Serial number: 5ZV02008220590
    Coding: 0014
    ASAM Dataset: EV_TCMDQ400022 001001
    ROD: EV_TCMDQ400022.rod
    VCID: 77AA1E1ECF4A7383428-8022
    18 Faults Found:
    21352 - ROD - Unknown Error Code
    - 00 [002]
    60353 - ROD - Unknown Error Code
    - 00 [002]
    60354 - ROD - Unknown Error Code
    - 00 [002]
    60355 - ROD - Unknown Error Code
    - 00 [002]
    60356 - ROD - Unknown Error Code
    - 00 [002]
    60357 - ROD - Unknown Error Code
    - 00 [002]
    60358 - ROD - Unknown Error Code
    - 00 [002]
    60359 - ROD - Unknown Error Code
    - 00 [002]
    60360 - ROD - Unknown Error Code
    - 00 [002]
    60361 - ROD - Unknown Error Code
    - 00 [002]
    60362 - ROD - Unknown Error Code
    - 00 [002]
    60363 - ROD - Unknown Error Code
    - 00 [002]
    60364 - ROD - Unknown Error Code
    - 00 [002]
    60365 - ROD - Unknown Error Code
    - 00 [002]
    60366 - ROD - Unknown Error Code
    - 00 [002]
    60367 - ROD - Unknown Error Code
    - 00 [002]
    60368 - ROD - Unknown Error Code
    - 00 [002]
    60369 - ROD - Unknown Error Code
    - 00 [002]
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 5WA 614 517 BF HW: 5WA 614 517 P
    Component: ESC H14 0127
    Serial number: 62870000000235
    Coding: 64FC269032224C725279A00905C76186AA5558504AC8670841 BCA231018FF121842814
    ASAM Dataset: EV_Brake1ESCEPBMQB37W 013051
    ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
    VCID: 0D465CF6DDD66953084-8058
    3 Faults Found:
    1905 - Transport Mode Active
    U1105 00 [032] - -
    590080 - Release / Enable Active
    B184C 00 [040] - -
    [Unlock_protection_of_vehicle_diagnosis_active]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 4 km
    Date: 2020.12.01
    Time: 09:27:06
    33015 - Switch for Electric Parking Brake
    C100C 29 [040] - Signal Implausible
    [Switch_disturbance_failure]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 39
    Mileage: 8 km
    Date: 2020.12.08
    Time: 21:42:25
    Address 05: Acc/Start Auth. (J518) Labels: None
    Part No SW: 5WA 959 436 C HW: 5WA 959 436 C
    Component: Kessy IOBOX 070 0703
    Serial number: ---------------
    ASAM Dataset: EV_Kessy37w 003022
    ROD: EV_Kessy37w_003_VW38.rod
    VCID: 54F089923E7C789B87A-8000
    No fault code found.
    Address 08: Auto HVAC (J979) Labels:* None
    Part No SW: 5WA 907 007 S HW: 5WA 907 007 S
    Component: AC Automat H31 3150
    Coding: 00210101701112001010001011101110200013110020100100 0000000000
    ASAM Dataset: EV_ACClimaHVPREVW38X 001084
    ROD: EV_ACClimaHVPREVW38X.rod
    VCID: 57EA7E9E2F8A5383628-8002
    Address 09: Cent. Elect. (J519) Labels: None
    Part No SW: 5WA 937 086 Q HW: 5WA 937 086 J
    Component: BCM 37W BOSCH 016 0137
    Serial number: BXJ53F031120951
    ASAM Dataset: EV_BCM37w 005001
    ROD: EV_BCM37w_005_VW38.rod
    VCID: 5F9A56BE47BAABC32A8-800A
    2 Faults Found:
    155136 - Unknown Error Code
    B1A61 F0 [046] - Unknown Error Elaboration
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 21 km
    Date: 2021.01.06
    Time: 12:53:03
    267032 - Alarm Horn / Siren for Anti-Theft System
    B131D 29 [104] - Signal Implausible
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 11 km
    Date: 2021.01.04
    Time: 11:01:15
    Address 10: Park/Steer Assist (J446) Labels:* None
    Part No SW: 5WA 919 298 A HW: 5WA 919 298
    Component: PLA 12K Kanal H04 0230
    Serial number: 000030092094560
    Coding: 9300026011
    ASAM Dataset: EV_EPHBO2CVW3800000 002028
    ROD: EV_EPHBO2CVW3800000_VW38.rod
    Address 13: Auto Dist. Reg (J428) Labels:* None
    Part No SW: 5WA 907 572 A HW: 5WA 907 572
    Component: ACC Bosch MQB H10 0246
    Coding: 2E0318FF407540451247400000004005AE4020000000000000 000000000000
    ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
    ROD: EV_FRONTRADARBOSCHVW380_003_VW38.rod
    VCID: 4CC091F2E64C205BDFA-8018
    Address 15: Airbags (J234) Labels:* None
    Part No SW: 5WA 959 655 K HW: 5WA 959 655 K
    Component: AirbagVW40 007 0636
    Serial number: 000000003C0J1R6
    Coding: 88CC000000C0C0000000002000000000515400002054000040 00F68000930065
    ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
    ROD: EV_AirbaVW40SMEVW38X_VW38.rod
    Address 17: Instruments (J285) Labels:* None-SRI2
    Part No SW: 5H0 920 340 A HW: 5H0 920 340 A
    Component: KOMBI 203 3450
    Coding: 24A400406B9C00080180620B2100080810B00C00
    ASAM Dataset: EV_DashBoardVDDMQB37W 003032
    ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
    VCID: 201815423A44D43B532-8074
    4 Faults Found:
    16777018 - Control unit for information electronics 1
    U1054 00 [008] - No Communication
    [Audio_0x31 communication error bap_error_timeout heartbeat]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 16 km
    Date: 2021.01.04
    Time: 17:33:50
    16777020 - Control unit for information electronics 1
    [TEL_0x28 communication error bap_error_timeout heartbeat]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 16 km
    Date: 2021.01.04
    Time: 17:33:50
    16777022 - Control unit for information electronics 1
    [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 10
    Reset counter: 40
    Mileage: 11 km
    Date: 2021.01.04
    Time: 10:55:52
    16777024 - No Communication with Diagnostic Gateway
    U0146 00 [008] - -
    [BCME_0x23 communication error bap_error_timeout heartbeat]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 41
    Mileage: 11 km
    Date: 2021.01.04
    Time: 11:00:09
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 5WA 907 530 E HW: 5WA 907 530 C
    Component: GW2020 High 752 7075
    Revision: -------- Serial number: 771049050020314
    Coding: 0000113D660000000000010001030137730161090200010003 0100010001010000000000000000000000000000000000
    ASAM Dataset: EV_GatewMQB2020 004003
    ROD: EV_GatewMQB2020_VW38.rod
    VCID: 4ACC97EAEC383E6BED6-801E
    4 Faults Found:
    2494569 - Unknown Error Code
    U1643 00 [047] - -
    [Rearview_camera_system_control_module_no_communica tion_vlan]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 5
    Reset counter: 40
    Mileage: 11 km
    Date: 2021.01.04
    Time: 10:40:57
    2097338 - Unknown Error Code
    U1646 00 [046] - -
    [Antenna_control_module_1_no_communication_vlan]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 39
    Reset counter: 40
    Mileage: 11 km
    Date: 2021.01.04
    Time: 10:48:36
    12400 - Release / Enable Active
    B184C 00 [040] - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 37
    Mileage: 11 km
    Date: 2021.01.04
    Time: 10:40:57
    8482816 - Activatable Functions
    B18D3 F4 [046] - Authentication of Transmission Failed
    [Fs_id_authentification_failed]
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 38 km
    Date: 2021.01.06
    Time: 02:26:21
    Address 23: Brake Booster (J539) Labels: None
    Part No SW: 5WA 909 059 H HW: 3Q0 909 059 A
    Component: EBKV H06 0112
    Serial number: BPA085201020013
    Coding: 1102C504740000CE39E79C73000049922449922400
    ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
    ROD: EV_BrakeBoostG2BoschVW37W_014_VW38.rod
    VCID: 55F6749635866193704-8000
    2 Faults Found:
    107024 - Unknown Error Code
    U14E4 00 [032] - -
    [Scl_Getriebe_11_GE_Fahrstufe_Error]
    1024304 - Release / Enable Active
    B184C 00 [032] - -
    [SECDIAG_ROLE_UNLOCKED]
    Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
    Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
    Component: ELV-MQBB H09 0040
    Serial number: 20000265209008
    Coding: 8800000000000000
    ASAM Dataset: EV_ELVMarqMQBA0 002004
    ROD: EV_ELVMarqMQBA0_VW27.rod
    VCID: 323CEF0A64A856ABB56-8066
    1 Fault Found:
    12666386 - Databus
    U1121 00 [008] - Missing Message
    [Timeout Getriebe_11_alt]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 21 km
    Date: 2021.01.06
    Time: 12:14:25
    Result lock conditions: invalid
    ESCL locked: No
    ESCL unlocked: Yes
    Lock sensor: Not operated
    Unlock sensor: operated
    Error mode 1: not active
    Error mode 2: not active
    Clamp S: OFF
    Clamp 15: OFF
    Clamp 15 Status: valid
    Remote Start: not active
    Driver door: to
    Central locking locked external: unlocked
    Central locking safed external: Vehicle not secured
    Clamp Request: No
    Request highside lock: No
    HW highside lock: OFF
    Highside unlock: No
    Motor break: not active
    Activation lowside unlock: OFF
    Activation lowside lock: OFF
    I2C overflow: No
    I2C error pathflags: No
    I2C resetinfo: No
    I2C error cpu: No
    I2C error rom: No
    I2C error ram: No
    I2C length failure: No
    I2C error sda: No
    I2C communication failure: i2c no comm failure
    I2C state esp 10: i2c cnd false
    I2C cnd haco message: valid
    Coco reset: No
    Coco supply: On
    Password IMS OK: Yes
    Signature IMS OK: Yes
    IMS responded: Yes
    Positive authentification in current KL15 cycle: No
    Lifestate: Immobilizer download obtained
    Learn mode: Adapted
    Authentication valid (T1): No
    State of authentication state machine: WFS_AUTH_INIT_e
    Vehicle speed: 0.00 km/h
    UBat internal: 12.4 V
    UMotorBridge: 6.7 V
    Lock condition engine speed: Condition met
    Lock condition clamp S: Condition met
    Lock condition clamp 15: Condition met
    Lock condition E2E clamp status: Condition met
    Lock condition timeout clamp status: Condition met
    Lock condition vehicle speed: Condition met
    Lock condition E2E vehicle speed: Condition met
    Lock condition timeout vehicle speed: Condition met
    Lock condition Mode1: Condition met
    Lock condition drive readiness: Condition met
    Lock condition selector lever position parking: Condition not met
    Clamp enable ESCL: not enabled
    Lock condition timeout distance pulse: Condition met
    Lock condition E2E distance pulse: Condition met
    Lock condition difference distance pulse: Condition not met
    Address 36: Seat Mem. Drvr (J136) Labels:* None
    Part No SW: 5WA 959 760 H HW: 5WA 959 760 H
    Component: MEM-FS 009 0361
    Serial number: 20A1701KA00329
    Coding: 01789A400000A0508803010101010000000000212100000000 000000215000
    ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
    ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
    VCID: 59EE78A6599E45F354C-800C
    Address 3C: Lane Change (J1086) Labels:* None
    Part No SW: 2Q0 907 686 D HW: 2Q0 907 686 D
    Component: HRE_Master H25 0276
    Serial number: 00000559544528
    Coding: 969945D0
    ASAM Dataset: EV_HREntryHellaGen3Mstr 001013
    ROD: EV_HREntryHellaGen3Mstr_VW38.rod
    VCID: 3B22C22EB3E297E3660-806E
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
    Component: TSG FS002 0330
    Serial number: YE007TJ51019E
    Coding: 003B1620D201040000001000
    ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
    ROD: EV_DCU2DriveSideMAXHKLO_VW38.rod
    VCID: 49CEA8E6E93E3573E4C-801C
    Rear Driver Side Door Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C
    Component: FOND_FHSG_DRV 007 0011
    Serial number: 00000000000045025148
    Coding: 0D0000
    Address 44: Steering Assist (J500) Labels:* None
    Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
    Component: BASGEN1MQB37 502 1040
    Serial number: 00395354
    Coding: 0000000100000101000102010100010000000101010101
    ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
    ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
    VCID: 4EC49BFA1050124BB1E-801A
    Address 4B: Multifunc. Module (J745) Labels:* None
    Part No SW: 5WA 907 338 HW: 5WA 907 338
    Component: FCM2020 Low 009 1372
    Serial number: 150151220442193
    Coding: 00000000090007CE01002F1002000300000000000000000000 0000000000
    ASAM Dataset: EV_MultiModulContiVW38X 002010
    ROD: EV_MultiModulContiVW38X_002_VW38.rod
    VCID: 0B4252EEA3C26763160-805E
    Address 51: Electric Drive (J841) Labels: None
    Part No SW: 5WA 907 080 B HW: 5WA 907 080 B
    Component: LE Gen 3.3H19 0222
    Revision: 00H19000
    Coding: 03090000000000000000
    ASAM Dataset: EV_DMCM08530115WA907080B 001016
    ROD: EV_DMCM08530115WA907080B.rod
    VCID: 47CAAEDEFF2AC303F28-8012
    Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
    Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
    Component: TSG BFS002 0330
    Serial number: YE007TIT1735B
    Coding: 003B1020DE01040000801000
    ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
    ROD: EV_DCU2PasseSideMAXHKLO_VW38.rod
    VCID: 48C8ADE2F234CC7BFB2-801C
    Rear Passenger Door Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C
    Component: FOND_FHSG_PSG 007 0011
    Serial number: 00000000000043661741
    Coding: 150000
    Address 5F: Information Electr. (J794) Labels:* None
    Part No SW: 5H0 035 816 B HW: 5H0 035 816
    Component: MU-O-ND-EU H56 1666
    Serial number: WG8LGM101120000
    Coding: 23800008000000000000000000000000000000000000000000
    ASAM Dataset: EV_MUOIMQB37w 001002
    ROD: EV_MUOIMQB37w_VW38.rod
    VCID: 2614035A58603A0B29E-8072
    1 Fault Found:
    12316 - Clock Syncronization Failure
    U138F 00 [008] - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 31 km
    Date: 2021.01.06
    Time: 13:36:45
    Address 6C: Back-up Cam. (J772) Labels:* None
    Part No SW: 5WA 980 556 A HW: 5WA 980 556 A
    Component: RV eCompact H21 0193
    Serial number: FCL-K2017.10.20
    Coding: 02038004E43000
    ASAM Dataset: EV_CamSysRVCCompaFicos 009020
    ROD: EV_CamSysRVCCompaFicos_VW38.rod
    VCID: 4FFA86FE175A1B43BA8-801A
    2 Faults Found:
    10489856 - No Basic Setting
    B2010 00 [046] - -
    [System not calibrated]
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 13
    Reset counter: 40
    Mileage: 0 km
    Date: 2072.00.24
    Time: 24:16:16
    13705507 - Databus
    U1121 00 [047] - Missing Message
    [Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 13
    Reset counter: 40
    Mileage: 720896 km
    Date: 2072.03.21
    Time: 07:56:16
    Address 75: Telematics (J949) Labels:* None
    Part No SW: 5WA 035 284 A HW: 5WA 035 284 A
    Component: OCU3HMQB37W H12 0067
    Serial number: 0000000911VIPA8
    Coding: 023800009068A8209405460071502E07
    ASAM Dataset: EV_OCU3HMQB37W 001039
    ROD: EV_OCU3HMQB37W_001_VW38.rod
    VCID: 44D0B9D2CE1CE81B17A-8010
    1 Fault Found:
    0080 - Databus
    [Ethernet Databus missing message - Transceiverbox]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 38 km
    Date: 2021.01.06
    Time: 13:58:57
    Voltage terminal 30: 12.0 V
    Address 82: Heads Up Display (J898) Labels:* None
    Part No SW: 5H2 919 608 HW: 5H2 919 608
    Component: HeadupDisplay H09 2032
    Coding: 5740C0
    ASAM Dataset: EV_HeadUpDisplMQB37W 001018
    ROD: EV_HeadUpDisplMQB37W.rod
    VCID: 70B82502AA2424BB832-8024
    1 Fault Found:
    16777040 - Function Restricted due to Interrupted Communications
    U1110 00 [008] - -
    [NAV_0x32_communication_error_bap_error_timeout_hea rtbeat]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 16 km
    Date: 2021.01.04
    Time: 17:33:51
    Address 8C: Hybrid Battery (J840) Labels: None
    Part No SW: 5WA 915 183 B HW: 5WA 915 183 B
    Component: J840 K8C BMC 004 0920
    Serial number: 000000151020050
    ASAM Dataset: EV_BMCeVWBSMQB37W 001004
    ROD: EV_BMCeVWBSMQB37W.rod
    Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
    Part No SW: 5WA 980 653 A HW: 5WA 980 653
    Component: MQB MFK 3.0 H06 3129
    Serial number: E57830712203180
    Coding: 00000808216CC040109E400010300080004180000000000000 00000000000000
    ASAM Dataset: EV_MFK3ValeoMQB 005050
    ROD: EV_MFK3ValeoMQB_005_VW38.rod
    VCID: 4DC69CF61D562953C84-8018
    Address C6: Batt. Chrg. (J1050) Labels:* None
    Part No SW: 5QE 915 685 C HW: 5QE 915 685 C
    Component: OBC KOSTAL H03 4632
    Serial number: 0810202J80004Z
    Coding: 115069222008
    ASAM Dataset: EV_OBCSinglPhaseKLOMQB16P 001001
    ROD: EV_OBCSinglPhaseKLOMQB16P.rod
    VCID: 50F885820A6404BBA32-8004
    1 Fault Found:
    12583680 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    [BapErr_Timeout_Heartbeat]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 41
    Mileage: 38 km
    Date: 2021.01.06
    Time: 13:57:21
    Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
    Part No SW: 992 941 571 AE HW: 992 941 571 A
    Component: LED1L H08 9202
    ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
    ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
    VCID: 6596445665E6F113E04-8030
    Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
    Component: LED1R H08 9202
    ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
    Address 8107: Antenna (J666) Labels:* None
    Part No SW: 5WA 035 741 A HW: 5WA 035 741 A
    Component: TrxModulHigh H10 0068
    Serial number: 0000000008VIFW3
    Coding: 02380011040080
    ASAM Dataset: EV_TrxMLGEMQB37W 005006
    ROD: EV_TrxMLGEMQB37W.rod
    VCID: 42DCBFCAD408E62B256-8016
    3 Faults Found:
    0081 - Databus
    U1121 00 [040] - Missing Message
    [Ethernet-Datenbus - fehlende Botschaft- POS_GNSS_05_Position]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 0
    0083 - Unknown Error Code
    U1541 00 [040] - -
    [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 0
    0096 - Unknown Error Code
    U153F 00 [109] - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 0
    Address 811E: Burglary Protection FL (J518) Labels: None
    Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
    Component: Kessy RSAD 070 0636
    ASAM Dataset: EV_RSADVL37w 002013
    ROD: EV_RSADVL37w_002_VW38.rod
    Address 811F: Burglary Protection FR (J518) Labels: None
    ASAM Dataset: EV_RSADVR37w 002013
    ROD: EV_RSADHL37w_002_VW38.rod
    Address 8120: Burglary Protection RL (J518) Labels: None
    ASAM Dataset: EV_RSADHL37w 002013
    Address 8121: Burglary Protection RR (J518) Labels: None
    ASAM Dataset: EV_RSADHR37w 002013
    End----------(Elapsed Time: 01:46, VBatt start/end: 13.1V/13.1V)-----------
  4. #10413
    Jan 2020
    And look now with this cable by Fly for the difference...
    Friday,29,January,2021,14:31:09:61752
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    www.Ross-Tech.com
    Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 52 5F 75 82
    A5 D6 D7 8107 811E 811F 8120 8121
    VIN: WVWZZZCDZLW01+++++
    05-Acc/Start Auth. -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    13-Auto Dist. Reg -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    3C-Lane Change -- Status: Malfunction 0010
    Address 01: Engine
    Cannot be reached
    Part No SW: 5WA 614 517 AE HW: 5WA 614 517 A
    Component: ESC H09 0011
    Serial number: 602800
    Coding: 34FC2C9022214471527A50070AC961862DB458F042D067C001 9CA231218FF100002814
    ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
    ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
    VCID: 0B43A505B3CA43D3160-805E
    1 Fault Found:
    8519 - Implausible Data Received from Cruise Control Front Distance Range Sensor
    U0433 00 [040] - -
    [CCan_ACC_Anhalteweg_inv]
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 5496 km
    Date: 2021.01.25
    Time: 13:59:10
    Component: Kessy IOBOX 070 0662
    ASAM Dataset: EV_Kessy37w 003019
    VCID: 54F17E792E745C2B87A-8000
    2 Faults Found:
    1052939 - Touch Sensor on Exterior Door Grip; Driver Side
    B116B 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 5215 km
    Date: 2020.12.29
    Time: 07:18:11
    Terminal 15 status: On
    Voltage: 14.9 V
    1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
    B116C 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 5215 km
    Date: 2020.12.29
    Time: 07:18:11
    Voltage: 14.9 V
    Part No SW: 5WA 907 727 T HW: 5WA 907 727 T
    Component: Climatronic H01 0240
    Coding: 00200001021112001010000011101111000013110020000000 0000000000
    ASAM Dataset: EV_ACClimaBHBVW38X 005062
    ROD: EV_ACClimaBHBVW38X_VW38.rod
    VCID: 619FA7AD61C6B9831CC-8034
    Part No SW: 5WA 937 086 J HW: 5WA 937 086 J
    Component: BCM 37W BOSCH 016 0132
    VCID: 58E98A49329C784B6B2-800C
    No ASAM data for: "EV_BCM37w" (VW38)
    Address 10: Park/Steer Assist (J446) Labels: None
    Part No SW: 5WA 919 298 HW: 5WA 919 298
    Component: PLA 12K Kanal H04 0022
    Serial number: 00002
    Coding: 8200026001
    ASAM Dataset: EV_EPHBO2CVW3800000 002027
    VCID: 1373BD65EBFA9B13DE0-8046
    No ASAM data for: "EV_EPHBO2CVW3800000" (VW38)
    2 Faults Found:
    1080304 - ROD - Unknown Error Code
    - 00 [036]
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 5451 km
    Date: 2021.01.18
    Time: 13:39:10
    1113328 - ROD - Unknown Error Code
    - 00 [036]
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 5451 km
    Date: 2021.01.18
    Time: 13:39:08
    Component: ACC Bosch MQB H03 0245
    Coding: 060318F70007404512474000000040054E4020000000000000 000000000000
    VCID: 4CC16619F64404EBDFA-8018
    4 Faults Found:
    1389 - Function Restricted due to Insufficient Voltage
    U1400 00 [040] - -
    [FAULT_VBAT_BUSMON_LOW]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 24
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    1560 - Databus
    U1122 00 [040] - Implausible Message
    [FAULT_VMM_INCONSISTENCY_ACC]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 34
    Mileage: 5496 km
    Date: 2021.01.25
    Time: 13:59:09
    1561 - Databus
    U1123 00 [040] - Received Error Message
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 5493 km
    Date: 2021.01.24
    Time: 22:44:47
    2068 - Databus
    [FAULT_TSK_IRREV_ERROR]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 5496 km
    Date: 2021.01.25
    Time: 13:59:09
    Part No SW: 5WA 959 655 A HW: 5WA 959 655 A
    Component: AirbagVW40 007 0523
    Serial number: 000000003C0DKR6
    Coding: 88CC000000C0C0000000000000000000515400002054000040 00F68000130065
    ASAM Dataset: EV_AirbaVW40SMEVW38X 001028
    VCID: 55F7837D258E4523704-8000
    Address 17: Instruments (J285) Labels: None
    Part No SW: 5H0 920 340 HW: 5H0 920 340
    Component: KOMBI 237 1400
    Coding: 04A40000639C00080180620B2000080810300800
    ASAM Dataset: EV_DashBoardVDDMQB37W 002029
    ROD: EV_DashBoardVDDMQB37W_002_VW38.rod
    VCID: 5F9BA15557B28F732A8-800A
    No ASAM data for: "EV_DashBoardVDDMQB37W" (VW38)
    Part No SW: 5WA 907 530 B HW: 5WA 907 530 B
    Component: GW2020 High 734 7068
    Revision: -------- Serial number: 150160900046131
    Coding: 0000808D0F00000000000000010301307301610F0000030003 0100000001010000000000000000000000000000000000
    VCID: 47CB5935EF22E7B3F28-8012
    1 Fault Found:
    U1646 00 [044] - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 149
    Reset counter: 40
    Mileage: 5239 km
    Date: 2021.01.03
    Time: 06:31:05
    Part No SW: 5WA 909 059 E HW: 3Q0 909 059 A
    Component: EBKV H06 0092
    Coding: 1002C140730000CE39E79C73000049922449922400
    ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
    ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
    VCID: 52FD78611460521B956-8006
    Component: ELV-MQBB H08 0040
    Coding: 0000000000000000
    VCID: 323D18E174A0721BB56-8066
    Coding: 01589A400000A0508803010101010000000000212100000000 000000215000
    VCID: 59EF8F4D4996614354C-800C
    Coding: 569945D0
    VCID: 3B2335C5A3EAB353660-806E
    1 Fault Found:
    2240563 - Databus
    [databus error value received - ESC_50 - ESP_QBit_Gierrate]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 27
    Mileage: 5239 km
    Date: 2021.01.03
    Time: 06:27:26
    Serial number: YE007SL
    Coding: 003B1220D200040000001000
    VCID: 49CF5F0DF93611C3E4C-801C
    Subsystem 1 - Part No SW: 5Q0 959 408 C HW: 5Q0 959 164
    Component: FOND_FHSG_DRV 007 0010
    Serial number: 00000000000037005403
    Coding: 110000
    Part No SW: 5WA 907 144 H HW: 5WA 907 144 C
    Component: BASGEN1MQB37 101 1030
    Serial number: 0004
    Coding: 0000000000000000000002010100010000000101000101
    ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
    ROD: EV_SteerAssisBASGEN1MQB37_006_VW38.rod
    VCID: 4EC56C11005836FBB1E-801A
    Coding: 003B1020DE00040000801000
    VCID: 48C95A09E23CE8CBFB2-801C
    Subsystem 1 - Part No SW: 5Q0 959 407 C HW: 5Q0 959 163
    Component: FOND_FHSG_PSG 007 0010
    Serial number: 00000000000036942473
    Coding: 090000
    Part No SW: 5H0 035 816 A HW: 5H0 035 816 A
    Component: MU-O-ND-EU H56 1650
    Serial number: WG8LGM2
    Coding: 23800000000000000000000000000000000000000000000000
    VCID: 2517F3BD356E15A3204-8070
    VCID: 44D14E39DE14CCAB17A-8010
    3 Faults Found:
    1350144 - Mobile Data Services
    B149A 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 141
    Reset counter: 40
    Mileage: 5343 km
    Date: 2021.01.13
    Time: 14:46:09
    Voltage terminal 30: 14.6 V
    0080 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 23
    Mileage: 5380 km
    Date: 2021.01.15
    Time: 11:27:53
    Voltage terminal 30: 14.2 V
    1381120 - Unknown Error Code
    U1513 00 [008] - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Date: 2000.00.00
    Time: 00:00:00
    Part No SW: 5H1 919 608 HW: 5H1 919 608
    Component: HeadupDisplay H15 0027
    Coding: 5740E0
    ASAM Dataset: EV_HeadUpDisplMQB37W 001017
    VCID: 6FBBD195A7121FF39A8-803A
    Component: MQB MFK 3.0 H05 3127
    Serial number: E267351
    Coding: 00000888216CC040109E000010200020004180000000000000 00000000000000
    ASAM Dataset: EV_MFK3ValeoMQB 005039
    VCID: 4DC76B1D0D5E0DE3C84-8018
    1 Fault Found:
    1124477 - Databus
    U1123 00 [008] - Received Error Message
    [KLR_01_KLR_Touchauswertung]
    VCID: 6597B3BD75EED5A3E04-8030
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Cannot be reached
    Cannot be reached
    End----------(Elapsed Time: 01:24, VBatt start/end: 15.0V/15.0V)-----------
  5. #10414
    Mar 2018
    I see logs of 2 different cars - I think it is necessary to test scanners on the same car.
    Have you ever thought that there are 3 points in the diagnosis - 1-a person, 2-a scanner, 3-a car. If something does not work, then it is not a fact that this is the 2nd option.
  6. The Following User Says Thank You to Roma77 For This Useful Post:
    jakuza (19th March, 2021)
  7. #10415
    Jan 2020
    Roma77,
    The last scan is from my car.
    so you and all other can see the diference, same software version, same firmware version, but not accasble with fly cable of all control units, but the orginal hex v2 scan en show all the module by type and name.
    Even no Asam data ony couple modules
  8. #10416
    Jun 2019
    Default 415 cable fully aupdated and operational
    Hi folks,
    Just wanted to drop in and let everyone know thanks to badrax I have managed to update the non udateable 415 cable to firnware 1.03.02 and it's running VCDS 20.12.0
    Some slight hiccups regarding connecting to my old car (8N mk1 TT pure Kline) since the firmware is using a different UART to communicate with one of the Kline chips but was easily fixed with 2 wires after badrax done the research and found the testpads to connect to
    Please don't go nuts now asking where to download and how to update, I'm sure badrax will let everyone know when it's time for that
  9. The Following 6 Users Say Thank You to Ganja47 For This Useful Post:
    Creteil (16th February, 2021), goveng (16th February, 2021), jakuza (19th March, 2021), karim1630 (4th January, 2024), Qwarz (13th September, 2024), seal777 (17th February, 2021)
  10. #10417
    Mar 2019
    Quote Originally Posted by Ganja47 View Post
    Hi folks,
    Did You cut those two lines next to capacitor c18 and S1 sign?
  11. #10418
    Jun 2019
    Nope, right now USART 1 and 3 are both connected to the kline chip. Still at early stage and easier to reverse things like this for now
  12. #10419
    Jan 2020
    Hello All,
    I have contacted fly today with skpe on his insistince, you can tell 100 times its not working, showing prove, but every time he ask do you have orginal cable.
    I have try to tell him tmany times, like the firmware and software are the same with orginal end clone but its not showing all of the control modules like orginal. Afcourse he dont want to hear this after 10 times telling. Every time whe need confirmation we need to test bla bla. Do you have orginal cable you can test for us, what the f..k i do on this forum..
    Verry strange i am wrong the cable is ok.. so people i dont say dont buy this cable but if you want to use on a golf 8 maybe you can wait 6 months to buy..
    comment Fly
    Just Forum
    We need to confirm
    We need to test
    Would do not trust
    To many decrier
    Slander
    We need to test and collect data to tv
    WE need to confirm
    I am done with this Fly shit, just you can olso accept its not working, after many prove
  13. The Following 2 Users Say Thank You to cebbes30 For This Useful Post:
    Creteil (17th February, 2021), quadral (18th February, 2021)
  14. #10420
    EU
    I understand that genuine hex-v2 is too expensive for mk8 buyers, however it's easy to spend 35k for the car, right?
    You want too much from a clone...
    If firmware version is the same, it doesn't mean it's content is identical.
    Sent from my VOG-L29 using Tapatalk
  15. #10421
    Aug 2020
    Quote Originally Posted by kaalis View Post
    You can get Genuine for around €200, Good clone around €60 and shit clone for around €30.
    In fairness OEM Hex v2 is really not that expensive in comparison to other VCI's.
    If you want the latest software and all that then just invest in a proper tool that will do the job and stop your whining.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  16. #10422
    Jan 2020
    very stupid comparison, I indicate that it is not the same as an original and that your on-board computer gives an unacceptable error message after use Component protection and not accesible modules.
    when I indicate this there are apparently co-owners here on the forum of fly who comment right away.
    if it does not work, other future riders of a vw golf 8 may also know that it does not work, so she, like me, will make a bad buy afterwards..
    I have been contacted by fly and other users in response to my post here!!
    what does not work on a Golf 8, I am not going to declare here that it works!!!!!!!!!!!!!
  17. The Following User Says Thank You to cebbes30 For This Useful Post:
    Creteil (19th February, 2021)
  18. #10423
    Jan 2020
    whining?
    Do you all work for fly on this forum or do you get a bonus.
    whining and truth are two different things.
    Quote Originally Posted by crouchinggerbil View Post
  19. The Following User Says Thank You to cebbes30 For This Useful Post:
    quadral (19th February, 2021)
  20. #10424
    Aug 2020
    whining?
    I dont work for fly no. Personally i dont trust someone who asks you to message them and them bombard you with the shit they sell in their shitty little shop
  21. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    peetr (18th February, 2021)
  22. #10425
    Nov 2020
    Hello All,
    comment Fly
    Just Forum
    We need to confirm
    We need to test
    Would do not trust
    To many decrier
    Slander
    WE need to confirm
    Yes,you contact fly, but you do not have original ross-tech vcds hex-v2 and fly stm405 vcds hex-v2. you just said ,said and said.
    so easy , fly need to test and collect the data.
    if fly stm405 vcds hex-v2 has the bug of VW Golf 8, fly can modify it and update freely soon.do not worry.
