Page 69 of 854 FirstFirst ... 1959646566676869707172737479119169569 ... LastLast
Results 1,021 to 1,035 of 12803
  1. #1021
    Default VCDS 10.6
    thanks man
  2. #1022
    Oct 2008
    On Earth
    Quote Originally Posted by ~~~tak View Post
    In my VCDS908 i have sma problem before.After change 1 digit in RT-USB driver from 0 to 1 .This stops FTDI chip to write own VID and PID.After that i do not problem with unplug cable from usb.This is solution that i read in forum but i dont remember who is write it.Maybe help to you.Best Regards
    Do you mean this:
    RT-USB.NT.HW.AddReg]
    HKR,,"ConfigData",0x00010001,0
    like this:
    HKR,,"ConfigData",0x00010001,1
    Good luck
  3. #1023
    Quote Originally Posted by bibkare View Post
    Beli my friend reflash atmega with new dump and also reflash ftdi with new eeprom, you have everything here at least for version 908
    can you look your pm bibkare? pls
  4. #1024
    Quote Originally Posted by mattydr67 View Post
    You need to reprogramm it.
    Our friend Aminebot it is expert in this and he explain here why it happend to you this.
    Just becasue you need to stop ross-tech to check your "licence"
    Is it in this forum an .bat file which can do this. It is named " disable updates" and it put a file name "hosts" in this 2 directoies C:\windows and in C:\windows\system32\drivers\etc
    Inside this file it writes like this:
    127.0.0.1 update.ross-tech.com
    I will share this file if you want to pt it manually in that 2 directories befor starting first time an internet sesion after the VCDS instalation.
    Good luck
    but i have problem... i followed tutorial... i used program vippidfix like in tutorial... it doesnt register any pluged cable... also mprog doesnt register anything pluged...
  5. #1025
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by beli123 View Post
    i replied you, first create drivers with UD fixer ( respect to XOOM) then vidpid fix will be able to recognize your interface
  6. #1026
    here are pics of the error
  7. #1027
    brasil
    Pedro what the f.u.c.k. you uploaded, those are not full size pictures, reupload then we will talk
    Ok Bibkare
  8. #1028
    brasil
    Ok Bibkare
    Another side of the plate.
  9. #1029
    Feb 2011
    Hello everybody!
    Who can provide, write, ATMEGA162, flash, eeprom183. version or higher
    Or there (VCDS812.4 Edition), registration / activation code to write, ATMEGA162, flash, eeprom ....
    I have 908 DUMP, but VCDS908.0 English, translation, difficulties
    Thank you! My English is not my strong suit. Sorry!
  10. #1030
    Feb 2011
    Ask you
    ATMEGA162 flash + eeprom 183, can activate the Chinese VCDS 908.1 version?
  11. #1031
    Junior Member max4ever's Avatar
    Romania
    Hi! I have chinese version 908 with FTDI 232BL chip.I write FTDI chip with 908 dump english.Is ok, but after autoscan 2-3 modules show "License is broken" or something also. What should I write, which chips? Only FTDI or must write ATMEGA 162? Or ATF16V8B?
    Soory for my bad english!!!!
  12. #1032
    B & H
    you need to provide additional ftdi driver files because xoom's ud fixer only creates 2 files, try this with windows xp
  13. #1033
    B & H
    Quote Originally Posted by PEDRO4053 View Post
    Ok Bibkare
    correct me if i am wrong but this interface has no transistors which means that you are lucky, also i couldn't see STC chip so you only should reflash atmega and you are good to go
  14. #1034
    Tereksaz's Avatar
    Nov 2010
    Dark side of the Moon
    I saw tha you live in Dark side of the Moon.
    Please step on Earth first mate.
    Good luck
    everyone has his own house.
    I'm looking for dump for VCDS 10.6.3
  15. #1035
    Feb 2011
    Question
    hi,
    is it possible to flash an china adapter (labeled on the board with VGC 2 2010-09-15) for VCDS 10.6.3 to any german version?
