Hi, I have a VAG168, can I update this?
Thank you in advance
not high res images, but yes, you find and use tools from Kolimer loader. If boot loader is disabled, then use programmer solution. There's a header soldered on the pcb.
Search for vcds loader 9.2 - check if tbe bootloader is enabled then you can upgrade thry usb , if not you will need a programeer. Instructions are inside vcds loader folder
thank you, where can I find vcds loader?
It was somewhere in this topic
password ?? , see your inbox
Salah Bismilah (27th March, 2021)
Hi there!
I have an Hex V2 with a fried STM32f405.
Question is: If I find another unit with V21.3, it is easy to clone his STM32f405 in to another chip?
I mean, there are cripto or other security issues? What programmer should I use?
Can I ask a dumb question.....how do you get code for security access so I can go into adaptation.
Hover with mouse pointer over the place where you type it in.
No codes available....
Shout out for Jan4![]()
I have a interface from flyfvdi.
I installed VIIPlusLoader-08.021.05.
He asked for an update, he updated.
Now I have the message Software startup failure!
How do I solve it?
Thanks!
Problem with latest version VII Plus Loader 05, software 20.12 and 21.3 not full working.
Attachment 797247Attachment 797246
StanNB (28th March, 2021)
