It's impossible to read the hole thread.I can read 6-7 pages per day,but new posts and pages arising in the higher valuePlease,tell me: is there solution how upgrade interface from 812 to 10.6 VCDS ,for free?
Thank you
It is low difference between 812 and 908 versions (I think) and work to do a lot,especially for me if I will be doing it the first time.So I will keep older version.Thanks.
May will be 10.6 for free in future
P.s. Why it's necessary to remove the STC chip, transistor and resistor?
What kind of job doing this chip?In my interface the STC is.Transistors I not see at all.
My interface a little bit difference others, who's pictures I so in the this threat,but built in the same or similar principle,I think.
Hello!
VCDS 10.6 does not work with FW 1.83
I checked all the dump from the forum!
Who really works?
It is shame,but I will ask.
What means reflash?It's like renew or delete and rewrite flash?Or simple show for VCDS?
I was always thinking that the flash is like eeprom inside bigest chip like CPU.I am wrong?
It seems where is no eeprom like 93x6 in may interface.Or might be this one in the picture is 93x6?
It means that VCDS without STC can't delete eeprom?But can not VCDS control erasing?
I'm not using internet in my PC.If I remove this component it means I can use?May will be other problems goes up?Or in my case,it is possible (removing STC) using vcds_908_flash from the this threat only?
Sorry for too many questions
Hi again! I flashed Atmega 162 succesfull but it gaves me the next error:
Reflash means reprogramming again the flash (memory).
You're right... The botom IC you marked seems to be connected to the FDTI, thus it's the FTDI's external EEPROM... However I am not familiar with that reference! Give me a clean photo of that IC or write here the whole reference.
If you have good dumps (908.0 arash dumps, for example) you don't need to keep reflashing that external EEPROM. Got it?
VCDS reprograming memory or the interface it doing itself?
I don't know that dump is exactly in my interface.
Bottom IC is ATMLH924 45D 1 Z8J2310.
Can somebody give me link about flash,please?
It is too many information for me in one day
@bibkare
please view post http://www.digital-kaos.co.uk/forums...tml#post965598 and give me a solution! I'm a desperate man!
