Page 725 of 854 FirstFirst ... 225625675715720721722723724725726727728729730735775825 ... LastLast
Results 10,861 to 10,875 of 12803
  1. #10861
    Nov 2020
    Quote Originally Posted by meciu View Post
    Hey guys,
    I've bought really cheap a chinese "REAL HEX-V2" with STM-405, and everything is working fine.
    Because of all HW issues other user have - I wanted to REWORK the board (remove chinese crap and solder proper ICs) but on one chip I cant see any markings.
    Do someone know, what kind of IC is that? @flyfvdi maybe You can tell me
    Thanks,
    Attachment 809333Attachment 809336
    Yes, FLY STM 405 Vcds hex-v2 with VII Plus loader
    All IC is working well , do not need to change
  2. #10862
    found on the net
    415 burn out too!
    carhelp.info/forums/showthread.php?t=153136
    Hello everyone,
    A couple of weeks ago I came from China VCDS HEX V2 with an STM32 chip.
    Knows how to update the firmware, work with the English version as an original wire, compared to the one on FTDI + Atmega, this one just flies.
    But the joy was not very long, today it burned out
    Sped up 2-3 components.
    1. MIC2920A-5.0WS
    2.I don’t know yet how to replace DADU 1734 JHV
    3. C1 - resistor, I also don’t know which one, but most likely the same as standing next to it.
    I didn't quite understand how it burned out, but probably when the car was started, I inserted or pulled it out.
  3. #10863
    Oct 2019
    somebody knows if you can acces security acces 16 from 09 central elektric, the code is 31347 but i cannot go in, i bought mine hex v2 from flyfvdi.
  4. #10864
    Nov 2019
    Quote Originally Posted by miouser View Post
    found on the net
    415 burn out too!
    i have 415 interface with different pcb layout
    can transceiver is sop8 not dfn8
  5. #10865
    May 2021
  6. #10866
    Aug 2018
    France
    @RFFK:
    it’s an hex-can câble in Hex-V2 case. You can upgrade it with Kolimer package
  7. #10867
  8. #10868
    Aug 2018
    France
    What is your car model and MY?
    maybe testing with VCDS 20.4 or 21.3 …
  9. #10869
    Jul 2018
    HEX V2 STM32.jpgHI GUYS, ANYONE HAS ANY IDEA ABOUT THE PINOUT TO CONNECT THE SWD STM32 DEBUGGER, THANKS FOR SHARING
  10. #10870
    May 2021
    Quote Originally Posted by ZIPPO4594 View Post
    Audi A6 C6 2008.
    I tested with 20.4 , 20.12 and 21.3 (the same problem).
    Cable connects throught Dual-K but not CAN.
  11. #10871
    Quote Originally Posted by RFFK View Post
    Audi A6 C6 2008.
    What does a full autoscan report (use manual body car selection in autoscan) ?
  12. #10872
    May 2021
    Quote Originally Posted by Creteil View Post
    Auto-detect / 4F - Audi A6/S6/RS6/allroad C6 (2005 > 2011) = same results (Function not supported by the gateway)
  13. #10873
    1st, check you VCDS on another car working in CAN.
    If it work, then check wiring scheme for can bus on the 4F - Audi A6/S6/RS6/allroad C6 (2005 > 2011) Car Diagnostic Interface...
  14. #10874
    Jul 2018
    I WOULD LIKE TO TEST FOR DUMPING FIRMWARE
  15. #10875
    Dec 2020
    Hungary
    Quote Originally Posted by flyfvdi View Post
    Use SIT1050T DFN8 to replace DADU DFN8
    I just got mine from Aliexpress, it already has the SIT1050T, is this the "better" version?
