seal777 (21st May, 2021)
somebody knows the security code of central eletric? i need to code led bulp warning but i cannot go in security acces:
i need to do exactly like this video:
but this guy his car is UDS and he enter 31347 and the key is valid
mine car is CAN and when i insert 31347 key is invalid
image of youtube
image of mine car
also i don't get yellow popup with the right key but this guy on youtube get yellow popup with the key.
From J2 and right (the one with the small square) you have [VDD(+3.3v), GND, PA15, SWDIO, SWCLK, PB3] (The side of the PCB with the STM chip)
Both the bootloader and the firmware will check the RDP level and set RDP2 if not previously set.
This will completely disable the debug interface so you wont get any response if you connect a debugger.
Here are some info from ST about RDP2:
"When RDP Level 2 is activated, all protections provided in Level 1 are active and the MCU is fully protected.
The RDP option byte and all other option bytes are frozen and can no longer be modified. The JTAG, SWV
(single-wire viewer), ETM, and boundary scan are all disabled. When booting from Flash, the memory content
is accessible to user code. However, booting from SRAM or from system memory bootloader is no longer possible.
This protection is irreversible (JTAG fuse), so it is impossible to go back to protection Level1 or 0."
Despite this I found a way to revert it so I would not say it is impossible. When that said it took me nearly a year of research to figure it out.
Good luck trying
Col19 (23rd May, 2021), drdahmani2 (22nd May, 2021), jakuza (23rd June, 2021), jan4 (21st May, 2021), kaalis (21st May, 2021)
anyone please have arm 415 fix or is there no fix for these cable shows illegal interface in vip loader
Hi friends
Who can share the part number of the PZ1 component to me please ?
Thank you in advance.
@ col19
does not work , no use of soldering it in !!
Col19 (4th June, 2021)
يعمل 100/100 على الاصلي هاذا اخر تحديث 3/2021
which interface can be used with this program, which cable, hello
Hi guys, I'm using a V2 interface with STM405 and if I use latest VII plus loader 08.021.05 with 21.3 version I get license error when trying to scan a car and "license revoked" at About menu. If I use 20.12 version it seems al is ok. As I know latest loader is suppose to work with latest version of VCDS. My interface SN ends with -5a22, am I doing something wrong ?
where I can finde on Aliexpress the vcds hex-v2 with the DADU DFN8 or SIT1050 DFN8 ship? Thanks a lot
I bought an interface and indeed the chip seems to be second hand and just added later (considering the bad quality of soldering)
Picture here: https://postimg.cc/cg43zgbZ
Anyone using the 415 cable experience burned chips?
Or perhaps more specific anyone with an upgraded 415 (to support 20.12) expenses this?
