Page 727 of 854 FirstFirst ... 227627677717722723724725726727728729730731732737777827 ... LastLast
Results 10,891 to 10,905 of 12803
  1. #10891
    Nov 2020
    Quote Originally Posted by AlexKudry View Post
    where I can finde on Aliexpress the vcds hex-v2 with the DADU DFN8 or SIT1050 DFN8 ship? Thanks a lot
    please contact me , thank you
  2. #10892
    Nov 2020
    Quote Originally Posted by badrax View Post
    Anyone using the 415 cable experience burned chips?
    Or perhaps more specific anyone with an upgraded 415 (to support 20.12) expenses this?
    the fake MIC2920A-5.0WS just support 12V
  3. #10893
    Jul 2019
    Do you have flickering issues of tabs like faults codes, live data on 1.6 tdi engine with 21.3 and latest version of viiplus loader? ( While engine running) and live data to be represented as 111000111 etc.
  4. #10894
    Nov 2019
    somebody can identify this element? hex v2 405 after burned voltage regulator can transceiver dadu burned and also burned this element on the other side of the board... any suggestions about replacement?
  5. #10895
    Apr 2019
    LM317. Also in TO-220 package you can get and replace.
  6. The Following 2 Users Say Thank You to ESPRIT For This Useful Post:
    Col19 (4th June, 2021), isavrseno (31st May, 2021)
  7. #10896
    Hi Guys. I have a big engine problem (Cam i suspect) and i cant get my clone VCDS 18.2 cable to work, interface not detected with V18.2 software, Windows sees it fine and it used to work. Had it for years and cant remember who it is from, or even be 100% if the 18.2 software i have is genuine or the one supplied with the cable.
    The chip is an Atmega 162 160-TW.
    Windows sees it as:-
    USB\VID_0403&PID_FA24&REV_0600
    My car is 2009 so i dont need latest greatest software revision, just to be able to use it for diagnosis asap.
    How best can i proceed? By using a loader or does anyone have V18.2 compatible with a clone?
    All the links for older down-loaders and software referring to 18.2 are now dead. I am on holiday in the car next week so only have limited time to get it working.
    I would be eternally grateful for any help to save my holiday:-)
  8. #10897
    Nov 2019
    it needs to be recognised as ross-tech direct usb interface or ross-tech usb converter
    if not then you have problem with ftdi
    reflash it with mprog
  9. #10898
    Jun 2021
    last vcds hex v2 only possible run only loader right not possible any future fw update fix use english w/o loader ?
  10. #10899
    Jun 2021
    What is the difference between atmega162 and stm32f405?
    I want to order one HEX-V2 from aliexpress, those with atmega162 are cheaper than stm32f405, do all of them come with unlimited VIN's? and does it have the same functions between atmega162 and stm32f405 if the software is 21.3.0?
  11. #10900
    Quote Originally Posted by krstecd View Post
    You can have a look at : « Hex+can vs hex-v2 ».
    To resume :
    ATMEGA162 based cable -> Kolimer Loader.
    STM32F405 based cable -> VII Plus Loader.
    STM32F415 -> doesn't support upgrade.
  12. #10901
    Nov 2020
    Quote Originally Posted by Creteil View Post
    To resume :
    VCDS Hex-V2 with main chip STM32F405VGT6 and VII PLus Loader. full version, update freely. most stable.
    VCDS hex-v2 is also available in the following languages:
    Chinese, Croatian, Czech, Danish, English, French, German, Hungarian, Italian, Polish, Portuguese, Romanian, Russian, Spanish, Swedish
    VII PLus Loader support Polish,German,French,Romanian,Czech,English,Chines e.
  13. #10902
    Feb 2020
    hello i want to update automatic gearbox dsg 7 gear, touran 1.6 tdi 2011Y what file should be, the current one is 0AM300053C / 3010/043
  14. #10903
    Oct 2019
    Romania
    Hello ,
    Can someone please help me identify the problem with getting no respone from the controller error on some modules like instruments , central conv , central lock ...
    Strange thing is that on some modules like engine , airbag the interface it is conecting fine.
    I tested with another vcds interface on same car and all the modules are conecting fine.
  15. #10904
    Apr 2020
    Hello, I have seen several adverts on which the say "VagCom with anti-blocking chip".
    I suppose they will have ATMEGA chip and another one.
    Do you have a photo of this type of cable? Or it is not possible?
    Thank you in advance
  16. #10905
    Nov 2020
    Quote Originally Posted by carfreak1 View Post
