@ Bibkare
The "problem" was at the 93C46 chip wich was empty.I rewrote it and that was it .You should tell us what was the problem so somebody else could learn something
You know once i put solution for autodata 3.16 on carhelp, it was xor axax's medicine for previous version which i reworked for version 3.16, when he saw that he was pissed even i told everybody it's his solution with my modification, so i learned not to post something hot and new that is not 100% your work and in this case dump for 10.6 is not my work at all
Someone have full dump VCDS Beta 11.2 NOT for free? PM PLS...
again guys, since the "dream" its to make a interface to work with any software, i saw that chinese engineers done it!
anyone heard about it?
on 10.6 interface you can use any software starting from 704 without damageing it!
fake or true?
cheers
If freedom is outlawed, only outlaws will have freedom!!!!
Yes, you should reflash if. Use MPROG (if you have the *.ept file) or FTPROG (if you have the .xlm file).
It's an easy task. Connect the VCDS cable into the USB port (it's not necessary to power up with 12V). Then open MPROG or FTPROG, scan for devices, load the dump and flash!
Any one can tell me where can I buy online 93Cx6?
