Page 742 of 854 FirstFirst ... 242642692732737738739740741742743744745746747752792842 ... LastLast
Results 11,116 to 11,130 of 12803
  1. #11116
    Dec 2019
    Romania
    Claudiu, trece-o la pierderi si cumpara-ti un VCDS cu chip STM32F405 si ai rezolvat problema.
    Oricum VCDS-ul ala care il ai, cu ATMEGA162 costa 20€, deci nu e mare pierdere.
  2. #11117
    Jun 2021
    Quote Originally Posted by MichaelKors View Post
    Treaba e ca softul nu imi merge,interfata este ok din punct de vedere functional,bootloaderul este intact in ea si este recunoscuta de aplicatia loaderului unde iti identifica tipul de hardware,la mine am o problema pe partea de software,ceva in vcds intra in conflict cu laptopul meu.
  3. #11118
    EU
    29.English is the only acceptable language on the forum.Please adhere to this,to avoid unnecessary confusion to other members,and to allow the staff to be able to moderate the forums.
    Sent from my VOG-L29 using Tapatalk
  4. The Following User Says Thank You to kaalis For This Useful Post:
    badrax (12th September, 2021)
  5. #11119
    Jun 2021
    Quote Originally Posted by kaalis View Post
    Understood.Sorry for that.
  6. #11120
    Sep 2021
    Hi, i have a 409 kkl cable "blue", which version is better ? i am using 311-2 but i canīt acess abs brake module in a seat ibiza 2002
  7. #11121
    May 2019
    central europe
    BTW, any opensource altyernatives to vcds? Maybe reversing it and making public is the way...I unsuccesfully searched for the old VAS 1052? or at least memory dum,ps, because vcds is unusable to complete that bloody MK60 ABS bleed. There must be a way how cycle solenoids separatedly without directly connecting. A bit OT but maybe the ABS pulse simulator is probably more useful as it simulates slip...
    I was a long time away, sorry, health... For newer cars im still thinking about the 5054a, but where get a good clone - even if rework is needed....
    For older non CAN cars, the KKL serial cable is enough /G iv/ Still not reversed vdspro...
  8. #11122
    Jun 2021
    Hello everyone!
    I managed to sort out the problem with my VCDS. I overlooked a simple thing that, when you think of it, makes total sense. The thumbdrive i was using to install my drivers and software on the laptop after clean installing the OS was corrupted and had some viruses on it. Found that out when i connected it to my cousins laptop and the Windows 10 defender found viruses on it even in official Intel drivers downloaded from their homepage. To everyone facing the same problem be very careful with the media storage that you're using.
    Have a great week!
  9. #11123
    Jun 2020
    It will probably never work with new software again. VCDS 20.12 working good.
  10. The Following User Says Thank You to Tomas003 For This Useful Post:
    bg17aw (15th September, 2021)
  11. #11124
    Jun 2020
    Can anybody help me, Trying to code a ABS pump on a 2007 Skoda Octavia 1.9 Diesel.
    Coding with VCDS Release 21.9 and genuine tool
    The old abs pump stopped communicating with the car, this replacement ABS pump is a Used one, but is working and communicating fine just the coding is off.
    I need the coding for my VIN
    Saturday,11,September,2021,11:25:33:60442
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.9.0.2 (x64)
    Data version: 20210903 DS330.0
    www.Ross-Tech.com
    VIN: TMBCS21Z972152275 License Plate: HY08SRV
    Mileage: 109890km-68282mi Repair Order:
    Chassis Type: 1Z (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: TMBCS21Z972152275 Mileage: 109890km-68282miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.clb
    Part No SW: 03G 906 021 LB HW: 03G 906 021 AN
    Component: R4 1,9L EDC 000SG 9251
    Revision: --H07--- Serial number: SKZ7Z0G4160318
    Coding: 0000071
    Shop #: WSC 73430 790 00000
    VCID: 6AD1C28B4593F3D9FF-803E
    VINID: 91D4938C206A24708114208714EF6DA33D
    5 Faults Found:
    000258 - Mass Air Flow Sensor (G70)
    P0102 - 000 - Signal too Low
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 109895 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 23:45:27
    Freeze Frame:
    RPM: 798 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Duty Cycle: 64.7 %
    Bin. Bits: 11000000
    Mass Air / Rev.: 240.0 mg/str
    Mass Air / Rev.: 0.0 mg/str
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 000 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 109895 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:02:01
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.70 V
    Bin. Bits: 11000100
    Temperature: 15.3°C
    Bin. Bits: 00110000
    005659 - Glowplug for Cylinder 2 (Q11)
    P161B - 000 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 109895 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:02:01
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.70 V
    Bin. Bits: 11000100
    Temperature: 15.3°C
    Bin. Bits: 00110000
    005660 - Glowplug for Cylinder 3 (Q12)
    P161C - 000 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 109895 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:02:01
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.70 V
    Bin. Bits: 11000100
    Temperature: 15.3°C
    Bin. Bits: 00110000
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 000 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 109895 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:02:01
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.70 V
    Bin. Bits: 11000100
    Temperature: 15.3°C
    Bin. Bits: 00110000
    Readiness: 1 1 0 0 1
    Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
    Part No SW: 1K0 907 379 AQ HW: 1K0 907 379 AQ
    Component: MABS MK70M 0105
    Revision: 00H32001
    Coding: 0016641
    Shop #: WSC 07894 551 00000
    VCID: 0103852758E510814E-8054
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    003 - Mechanical Failure
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1Z0 820 047 D
    Component: Climatic PQ35 010 0301
    Shop #: WSC 00000 000 00000
    VCID: 346D1CF357D7752995-8060
    1 Fault Found:
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000004870390
    Coding: 00880F030004140000110D000000000000087B075C0000
    VCID: 6BDFC78F4A69EAD184-803E
    Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 090207 022 0601
    Coding: 00055223
    Shop #: WSC 73430
    No fault code found.
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q4 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD15RUSB
    Coding: 0020788
    VCID: 3D7B39D7649DB4616A-8068
    Subsystem 1 - Serial number: 6332MSME17145B5CH
    Subsystem 2 - Serial number: 6342MSME187E0D67S
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
    Component: Lenksäulenmodul 036 0070
    Coding: 0000012
    VCID: 74EDDCF31757352955-8020
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D
    Component: KOMBIINSTRUMENT VD1 1610
    Revision: V1610056 Serial number: SKZ7Z0G4160318
    Coding: 0003401
    Shop #: WSC 59598 067 57207
    VCID: 366926FB41AB6739AB-8062
    Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H04 0021
    Revision: H04 02 Serial number: 110407F1001768
    Coding: 3D3F034007001303
    VCID: 2F67139FBEF156F1E8-807A
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VD1 1610
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
    Component: Tuer-SG 005 0954
    Coding: 0000756
    VCID: 387528C34BBF9149B9-806C
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.069 H07 1806
    Shop #: WSC 73430 000 90108
    VCID: 356B21F75CAD6C21A2-8060
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 99801A085283007F3F04850540085F97907CA0
    Shop #: WSC 73430 790 12345
    VCID: 030F8F2F42F902915C-8056
    Subsystem 1 - Component: Sounder No Answer
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE No Answer
    2 Faults Found:
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 109895 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 23:45:41
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 109895 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 23:45:41
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
    Coding: 0000756
    VCID: 39732DC770B5884146-806C
    Address 56: Radio Labels: 1K0-035-1xx-56.clb
    Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
    Component: Radio FO3 019 0034
    Revision: 00019000 Serial number: SKZ7Z3G0171798
    Coding: 0000402
    VCID: 2E590E9BB9FB5FF9E3-807A
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
    Component: Tuer-SG 005 0907
    Coding: 0000144
    Shop #: WSC 73430 790 1012544
    VCID: 37772BFF46A19E31B0-8062
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
    Coding: 0000144
    End-------------------------(Elapsed Time: 01:39)--------------------------
  12. #11125
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    viiplus loader update anyone ??
  13. #11126
    Dec 2019
    Romania
    Latest is 08.021.10 (Beta).
  14. #11127
    Nov 2020
    Quote Originally Posted by jan4 View Post
    VCDS-Release-21.9.0-Installer.exe
    VIIPlusLoader-08.021.10(BETA)-FULL-Installer.rar
    download from this link:
    https://mega.nz/folder/CIk2UaLI#ORjmykOKTDgGkFClCYpHRA
  15. #11128
    Sep 2021
    Is this chip good?f429
    which one is better,405 or 429? Is 429 slower than 405?
  16. #11129
    Nov 2020
    We have VIIPlusLoader with STM 405, STM 427 and STM 429, same functions. same
  17. #11130
    Nov 2020
    Quote Originally Posted by morbid80 View Post
