Page 743 of 854 FirstFirst ... 243643693733738739740741742743744745746747748753793843 ... LastLast
Results 11,131 to 11,145 of 12803
  1. #11131
    Aug 2021
    VCDSLOader 9.2 not running!!! Can you tell me what settings to make? I disabled windows defender. I installed VCDS21.3. I add exceptions in defender settings: Ross Tech folder and VCDSLoader.exe. I copied VCDSloader and ftd2xx, shortcut on deskop, run administrator: the icon appears on my desktop for a few seconds and then disappears. I tried in windows 7 32bit and 64bit and windows 10 32bit and 64bit. What happens? What to do?
  2. #11132
    EU
    Post detailed pictures from both sides of your cable pcb. Loader doesn't run on every clone hardware. Does it atleast show up in device manager?
    Sent from my VOG-L29 using Tapatalk
  3. #11133
    Oct 2017
    Quote Originally Posted by bigwolf68 View Post
    Maybe try 20.12 because you don't get any advantages of 21.3 anyways. For me 20.12 works just fine. You can even use 18.9 which works 100%. With every new version ross tries again to ban our clone interfaces, so I would stick with a tested stable version
  4. #11134
    @bigwolf68
    check DeviceManager!
  5. #11135
    Aug 2020
    Quote Originally Posted by miouser View Post
    @bigwolf68
    What for?
    This is not going to solve the problem.
    Drivers is the only need to check devmgmt.
    This is something to do with the software not the hardware.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  6. #11136
    Aug 2021
    After a series of installations and uninstallations of windows variants, I finally managed to enter VCDS 21.3 With VCDSLoader 9.2.
    Thanks to everyone who answered. Nice guys.
  7. The Following User Says Thank You to bigwolf68 For This Useful Post:
    peetr (16th September, 2021)
  8. #11137
    Jun 2020
    Quote Originally Posted by MichaelKors View Post
    Yes, Loader 08.021.04 works well with VCDS 20.21.
    If 04 gives problems, try 03.
    It does not give License Revoked after use.
    I wonder why that is. You're the only person who has actually said something that has fixed my V2 cable. I've tried so many loaders with latest and oldest vcds. And always on auto scan it says license interface required.
    However, on loader 08.21.03 English. It has worked perfectly with vcds 21.12.
    But im confused as to why the latest loader won't work with any software above that?
  9. #11138
    pt
    has anyboudy a good version od PTT 21.3 (portugues)
    the one downloaded from oficial website, the setup is kapot a lot of files missing during instalation
    thank you
    ze
  10. #11139
    Dec 2019
    Romania
    Quote Originally Posted by Billyym View Post
    That's because i don't talk unless i tested it first and my V2 cable worked fine with VII Plus Loader 08.021.03 or .04 and VCDS 20.4 or 20.12.
    The latest loader with VCDS 21.3 or 21.9 are simply a JOKE !
  11. #11140
    Dec 2019
    Romania
    Quote Originally Posted by zecas View Post
    thank you
    ze
    Here you go.
    https://mega.nz/file/FMchxKRJ#q761z-...iU_7OZuoeP_Sa4
  12. #11141
    Nov 2018
    Hello! Can someone please give a link with VII Plus Loader 08.021.03 ? Thank you.
  13. #11142
    Aug 2020
    Quote Originally Posted by cuciulicu View Post
    If you used the search function, you would be abe to find it here all by yourself.......
  14. #11143
    Dec 2019
    Romania
  15. The Following 2 Users Say Thank You to MichaelKors For This Useful Post:
    so7iR (21st September, 2021), zecas (17th September, 2021)
  16. #11144
    Jun 2020
    Absolutely, I don't get that. It shouldn't even be the case. But it is. Oh well.
  17. #11145
    Dec 2019
    Romania
    Finaly, did you use VII Plus Loader 08.021.03 with VCDS 20.12 and success ?
