Page 750 of 847 FirstFirst ... 250650700740745746747748749750751752753754755760800 ... LastLast
Results 11,236 to 11,250 of 12705
  1. #11236
    Quote Originally Posted by golemiqP View Post
    Creteli im gonna try in a minute but somewhere i read that if Loader Screen shows Failed not OK loader do not work, that scares me more. A friedn of me has 12.12 VCDS with cable, with his version and his cable test goes well without pluged in the care and recieves a longer message with blue circle with !, not yellow like mine
    OK, so we wait for your feedback with cable connected to the car and key switched ON...
  2. #11237
    Oct 2021
    Quote Originally Posted by Creteil View Post
    Tested: XP 32bit laptop
    V21.3 (from the Xs of the cable + loader v9.1 from the cd) Still getting Failed 2 on loader > Test goes well, but nothing works … license say REVOKED
    V19.6, V20.4, V20.12 from here (mega archive) + Loader v9.2 automatic (mega archive)
    Loader shows OK status, test goes well, License REVOKED and nothing worksIMG_1897.jpg
    This info I get from this HW software…..
    Please guys help me find the solution
  3. #11238
    EU
    I'd better reflash firmware because of "7A - Unknown" language in bottom image, just in case.
  4. #11239
    Oct 2021
    Quote Originally Posted by kaalis View Post
    I scan the cable with another software I find “Ctest”
    What mean that loader v0.7 ?
    With the cd cable must be 21.3, can I reflash with 19.6 with loader 9.2 ??? And will this reflashing fix Revokes license ?
  5. #11240
    Just use « VAGCOM_EEWriteLang.exe » program to flash the language corresponding to the VCDS software language you have installed...
    TO DO THAT, THE CABLE MUST BE CONNECTED TO THE CAR WITH CAR CONTACT ON.
    DON'T SWITCH OFF THE CONTACT DURING THE FLASHING PROCESS !!!
  6. #11241
    Oct 2021
    PROBLEM FIXED - First the Loader I got with the CD (v9.1) was crap…. I used the Loader from the archive.
    Second reflash the cable with English as @Creteil and @jan4 explained me . And now 21.3 working well on x86 XP laptop.
    Thanks a lot guys !!
    Special thanks to @jan4 and @Creteil
  7. #11242
    Quote Originally Posted by b4b View Post
    I am not authorized to do this.
    If the company wanted it, the download link would be on their website and that is not the case!
    10th chars
  8. The Following User Says Thank You to Creteil For This Useful Post:
    Col19 (20th November, 2021)
  9. #11243
    Oct 2021
    I have the same issues. I have access to the archive now, but I have not yet found a manual on how to perform a reflash. Can you help me out too?
    Edit: There is a readme in the loader. I was under the impression that it was just the .exe file, not a folder full of information.
  10. #11244
    Oct 2021
    Quote Originally Posted by SuperR View Post
    I also have the same issue "Failed 2" . I'm gonna try with loader from archive.
  11. #11245
    Oct 2021
    @SupeR , @mitek96 if your cable is atmega162
    First download and Install the desired version VCDS for me it was 21.3.0
    Download Loader 9.2 from the archive (non-automatic) This contains folders with few programs, If you can use C-test and blablaHW test to see cable parameters (must be in the car with 12v ON)
    Copy loader exe to your Vcds folder as explained everywhere.
    On loading screen must be OK X86 instead of
    Failed 2 X86 or 64
    When you finish this steps and VCDS opened from loader exe always gives you OK, plug the cable on the usb and in the car.
    Now do the test in options as explained.
    After Save, go to ABOUT, there you see your license status. If revoked or something with red label, you must reflash the cable.
    Open EEwrite.exe from the loader folder, set language, mostly English and click the button and wait. When finish play VCDS from loader, test again , save and check license status, must be GREEN.
  12. The Following 2 Users Say Thank You to golemiqP For This Useful Post:
    FCV2005 (17th October, 2021), ZIPPO4594 (13th October, 2021)
  13. #11246
    Oct 2021
    hello everyone,
    Im using a Hex-V2 cable and vcds 20.4, it worked fine until today.
    Im getting error "vcds requires licensed interface", tried to reinstall software and nothing, also there is no serial at all .
    anyone know how to fix it ? never used my interface with internet on
  14. #11247
    Jan 2016
    Quote Originally Posted by FCV2005 View Post
    hello everyone,
    Do you have real V2 or atmega? What is in shown in test - check.
    If you use atmega (HEX-CAN-SUB) than just reflash device.
    If real V2 just start with loader and it should resolve your issue.
  15. #11248
    May 2016
    Quote Originally Posted by flyfvdi View Post
    Attachment 831864Attachment 831865Attachment 831866Attachment 831867Attachment 831868
    FLY compnay VCDS Hex-V2 with main chip STM32F405VGT6 and VII PLus Loader
    Did anyone tested this last model of cable with latest loader and VCDS 21.9 ?
  16. #11249
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    ask fly he knows everything ...........................
  17. #11250
    May 2016
    I dont need his experience, he is seller and sellers allways say its perfect untill problems show.
