Page 753 of 854 FirstFirst ... 253653703743748749750751752753754755756757758763803853 ... LastLast
Results 11,281 to 11,295 of 12803
  1. #11281
    Member seal777's Avatar
    Jun 2012
    Romania
    I need to VIIPlusLoader 08.021.11
    Thanks !
  2. #11282
    Nov 2021
    Quote Originally Posted by MichaelKors View Post
    I tried 21.9 with loade *.10 Beta and it has a lot of problems.
    I almost cannot do Autoscan, License Revoked, etc.
    I had similar results that changed when I turned off the internet .
  3. #11283
    Nov 2021
    Quote Originally Posted by kaalis View Post
    No, you have hex-can. You may have just a hex-v2 look a like case with non v2 internals.
    Real V2 port test result, about serial is different comparing with your screenshots.
    Sent from my VOG-L29 using Tapatalk
    Thank you for the update. They may have fooled me with look like on ebay which i bought in 2018. What is the best place to buy another cable with Atmega chip? I will place an order today. I found this on ebay, is this any good? https://www.ebay.com/itm/37377051601...4AAOSwxuFheTO~
  4. #11284
    Aug 2018
    France
    No, you need hex-v2 with stm32f405. On your eBay link, it’s a hex-can with V2 case like your actual cāble with Atmega162 chip.
  5. #11285
    Sep 2012
    dgtal81
    what kind of software did you use in cable with F415 chip which worked in long coding of unit 46 Audi A4 B9 ? It is special kind of 20.4.1 only prepared for F415 chips ?
    Or it is only usual version of 20.4.1 with changed VCDS exe file ? Will be not possible, that cable with chip F405 can work with the same kind of software on unit 46 well ?
  6. #11286
    Dec 2020
    Quote Originally Posted by malina10 View Post
    dgtal81
    with version 20.4.1 and the 415 chip cable works with the original software without modifications.the only bug detected is that instead of indicating the descriptions of the bits, it indicates codes such as tip34567 near each bit, same thing in the description of a faul code.
  7. #11287
    Nov 2021
    Quote Originally Posted by ZIPPO4594 View Post
    Thank you for these details. Do you know where we can buy these? ebay or other 3rd party sites would be helpful.
  8. #11288
    Aug 2018
    France
    Check on AliExpress it costs 80$
  9. #11289
  10. #11290
    Jan 2011
    Hello Audi0007,
    I would also like to buy a V2 clone.
    However, due to the many bad reports here, many have bought an interface that became defective shortly after commissioning due to bad/fake components.
    Does anyone have experience with good sellers on Aliexpress?
    Or already experience with the real V2 from Sklad or Diag Lauter?
    Does anyone have a purchase recommendation?
  11. #11291
    Jul 2019
    Quote Originally Posted by TheBadFrog View Post
    Hello Audi0007,
    I bought from here hex v2, same as original.
    firmware updates fine, works on both NA 2021 b9.5 sq5 audi and mk7.5 golf R
    https://www.obd2cartool.com/
  12. #11292
    Mar 2016
    @audi007 : You need to buy the one with STM32F405 chip.
  13. #11293
    Nov 2020
    Quote Originally Posted by mrle9 View Post
    STM405, STM427 and STM429 , same
  14. #11294
    Sep 2018
    Hello I want to buy vcds clone from aliexpress. Wich one to buy? I have golf 5 (2005)
  15. #11295
    Mar 2016
    For a 2005 car a cable with ATMEGA162 chip will be enough.
