Solved!
After uninstalling vcds and drivers, restart, everything is ok.
See Hex V2
The loader detects it.
Made uppdate ...
So everything is fine.
Thank you very much .... I was stuck, because I didn't know how I managed such a performance !!!!
Solved!
See Hex V2
Made uppdate ...
Hello guys ,
Can you please help me.
I have an HEX with STM32F405 , but i have a problem with it.
I tried to recode an Can Gateway on a basic car 2006 Passat B6 , but sometimes give to me error like , you need license interface for this ... but when i look on about , the interface is licensed.
I know , that these can runs directly with the original vcds , right ?
Thank you
How to get the yellow balloon with the security codes to display?
It is not showing on mine... for example, on module 16 it used to display security code is 40168
not anymore... is there a trick to make this happen?
I am using 20.4.2 English with 8.021.13 loader
You have to check which label file is loaded in specific ecu. Title bar of Measuring blocks.
Subject: V2 ARM
Few PCB having a little buzzer or speaker named PZ1
99% is not present, only pads
I have 2 pcs, one with speaker, one no speaker.
What must do that speaker? because to me do nothing, no sound.
Or make sound in specioal ocasions?
@liviudiaconu, it is supposed to make sound only if forgot in the car I think. Useless
Audi q5 2017 FY mlb-evo (with presense) gives me error after changing part 80A907129AC
5648384 - Control Module
C104A F0 [009] - Incorrect VIN
Confirmed - Tested Since Memory Clear
No channel 081, as that is only for can modules. Newer cars have UDS modules.
Any solution to make this module learn VIN? I have vcds, vas5054, obd11 but not sure how to do this
@bg17aw: like in Launch (my "launch" at the end give me a sound, but in the software on tablet, not the device).
Yes but speaker is useless like he told you because no one will forget for vcds in car as it is with cable and you must see it. On launch is different you can easy forget for the vci in obd port.
liviudiaconu (16th February, 2022)
Yes, you right, i only compared
Hi all
I have vagcom
B03-V2
20.4.1 EN+DE
Work perfectly but one month say vcds.exe not found
I dont have cd for new install
What can i do now?
Thanks in advance
Στάλθηκε από το RMX3081 μου χρησιμοποιώντας Tapatalk
@fishin :
link to download vcds 20.4.1 eng :
https://mega.nz/file/dJVyxbRI#d2dGHT...M6f6-YyAuTFqRg
sorry, but i don’t have DE version
Yes, it’s original install.
if you have HEx-can clone (Atmega162 based), use Kolimer 9.2 loader, and if you have Hex-V2 (STM32F405 based), use VIIPlusLoader 08.21.13
