Page 768 of 854 FirstFirst ... 268668718758763764765766767768769770771772773778818 ... LastLast
Results 11,506 to 11,520 of 12803
  1. #11506
    Jun 2020
    Thank you for the link
  2. #11507
    Dec 2020
    Does anyone know where I can get the Hex-V2 STM32F415 from outside of AliExpress?
    This type of interface. (NOT the 405 VIIPlus crap)
  3. #11508
  4. #11509
    Jul 2016
    Vilnius
    Panowie, he asked outside​ Aliexpress!
    * MK100
  5. #11510
    Jan 2016
    I have a cloned VAG157 running on 15.7.0, been using it for the past 5/6 years without issue on my 2009 passat, tried to connect to my friends 2018 Tiguan but seems like its outdated, whats the best way to update them, do I need to update Firmware on VAG157? and get a newer update of VCDS? if so whats the recommendations for a stable version?
  6. #11511
    Jul 2016
    Vilnius
    First of all, open up the case and check if you have ATmega162 chip inside.
    And even better, make high-res pictures of both sides of PCB and post pictures here, the community will advise.
    If there isn't any ATmega162 chip, then that interface is simply useless and not worth even a single minute of effort trying to make it usable
    * MK100
  7. #11512
    Jan 2016
    Not sure what I'm looking for
  8. #11513
    Jul 2016
    Vilnius
    ATmega162 chip with STC chip. Browse several pages back, find link for kolimer's loader v9.2.
    All you need is inside that package, but only if your bootloader is unlocked.
    Start by reading the readme file first, it has detailed explanation
    * MK100
  9. The Following User Says Thank You to hid3 For This Useful Post:
    PJD (19th April, 2022)
  10. #11514
    Jan 2016
    Quote Originally Posted by hid3 View Post
    Thanks for the reply,
    After reading the destruction manual, I've decided its better that I don't try and modify my lead, I'd prefer to keep it intact in its current operational state which I can keep as a backup, and purchase another lead which is preferably already good to go, is there a pre-configured lead? which somebody could recommend I buy? and from a recommended seller? (A bit like is recommended in the Autocom thread, in the "Read me" file there is the recommended lead from the recommended seller for that particular software which I purchased last night, in the hope it will be less problematic)
    If I have read right, will the HEX-V2 do the job needed straight out the packet? only job needed is the re-flash from VAGCOM_EEWriteLang.exe utility? which is a simple job right?
  11. #11515
    Jul 2016
    Vilnius
    Everything was covered in readme file regarding purchase recommendations. The information is valid there.
    And yeah, the setting up is as little headache as possible if you buy what's recommended there.
    * MK100
  12. The Following User Says Thank You to hid3 For This Useful Post:
  13. #11516
    Jan 2016
    I will make the purchase then, will be better all around IMO
    Thank you again.
  14. #11517
    Apr 2019
    Hi all!
    I currently using an 18.9 vcds with an atmega chip cable with a Kolimer loader. I want to update vcds, my question would be which is the latest stable version, 21.9.0?I read about several issues with 22.3 version.
  15. #11518
    Apr 2017
    Quote Originally Posted by Kapten View Post
    Attachment 880738
    kolimer loader v2 vcds 20.12
    why do i get this error ? is cable going bad? tested on 2018 and 2011 same error
    Internal ROD error:
    i just hade to update to 22.3.0
  16. #11519
    Mar 2009
    Default 415
    Quote Originally Posted by badrax View Post
    i have one of these did work on 20.1.3 now it don't is there any flasher for them vip loader it shows illegal or do i need a hacked vcds version
  17. #11520
    Mar 2009
    also whats the latest with 22.3 etc for vip loader clones still a NO go ???
