Page 76 of 854 FirstFirst ... 2666717273747576777879808186126176576 ... LastLast
Results 1,126 to 1,140 of 12803
  1. #1126
    Feb 2011
    Hey guys,
    So I am new to all this but I am trying to figure out what I can do with the wire that I have. Here are pics of the PCB:
    The chip says ftdi something on it. Now my question is as follows. Can I modify this cable to be used with VCDS 704, 812 or 908? Or is this one of those "dumb" cables? What can I do with this?
    Thanks.
  2. #1127
    Feb 2011
    France
    I look like a old VAGCOM 409, you can use only with K-line.
    No chance to use on CAN-BUS
  3. #1128
    Feb 2011
    I have used it successfully with VAGCOM 409, is that the best I can do with this or is there any better software I should be trying to get? I drive and audi A4 (2000).
  4. #1129
    Quote Originally Posted by Nevalite View Post
    He will work with VCDS-Lite v.1
  5. #1130
    Feb 2011
    Yeah I have tried it with VCDS-lite 1.0, the only problem is I dont have an activation key. I heard there was a loader floating around if anyone could PM some details about that it would be much appreciated.
  6. #1131
    DK Veteran rsibiza's Avatar
    Wink
    Try hit "Search" then "VCDS Lite" im sure the loader will fall in your hand very fast....
  7. #1132
    Feb 2011
    I have a few years ago China HEX CAN USB Interface purchased the went really until my computer is broken and I have not found the CD.
    Now I'm in my naivety that I should try the latest from Rosstech, has been shown as the VID / PID only fffffff.
    Now I'm very happy here you can read the new programmer.
    My real problem is that I do not know what I did for a version of the interface
    I took a picture maybe someone knows.
    Sorry for google translate
  8. #1133
    Dec 2010
    Czech Republic
    Quote Originally Posted by Fuchs111kw View Post
    hehe, unbelievable, another picture of cable from Chinas market and different than others. I guess that I saw in this forum more than 5 pictures of different cables.
    Anyway, you cable looks normal. In this forum are everything what you need to download new firmware for all programmable parts, your cable will works with 908 version, finally.
    Just make a cup of coffe and start reading
  9. #1134
    DK Veteran KenshinPT's Avatar
    PT
    I really love those china adaptions with through hole resistors and diodes. Lovelly
    Did it help? Push Thanks below
  10. #1135
    Jan 2011
    Lithuania
    Quote Originally Posted by tomasfilip View Post
    But all cables have ATF16 , MCP,Atmega162,FTDI,GAL16 and.... 7805
    I didn't see STC in the last picture.
  11. #1136
    Tereksaz's Avatar
    Nov 2010
    Dark side of the Moon
    Quote Originally Posted by mattydr67 View Post
    You talking about firmwear 1.83 but you need ATMEGA dump too and I really don't know that this 10.6.0 it is for free.
    So you ned to files to reprogramm Atmega not just 1.83 that you find here in this thread.
    BTW dumps for VCDS 10.6.3 for sure dosen't exist.
    About dump for Atmega 162:
    1. dump for FT232BM -have bootloader 256 word - it is for all old adapter!
    2 dump for FT232RL and new version com port - have 512 word - it is for all new version adapter
    3. dump ver. 1.78 -183 for FT232BM not same as dump for ver1.78 -1.83 for FT232RL and new com port.
    4 dump for com port, dont can use right for USB version , can use only for usb Serial Com Converter + latency timer =2 !!!!!!
    and else!
    about free damps - make dump very easy.
    instructioin!
    buy original HEX-COM+CAN interface- it is not many moneys.
    install and run HHD software - USB snifer.
    connect usb serial com converter and connect HEX-COM+CAN interface.
    Run snifer and run VCDS 11.2 or any another version.
    Select com port 2 and make test interface.
    Closed VCDS and save log file format HTML to snifer.
    open file and find all need information -then decript it and write dump.
    All time for job - not more 30 min.
    And gold key to your hands!
    good luck!
    =D.S. of M.=
  12. #1137
    Oct 2008
    On Earth
    Quote Originally Posted by Tereksaz View Post
    and else!
    instructioin!
    good luck!
    =D.S. of M.=
    I'm really impressed.
    Please give me an hour to do this I can't do it so quiclly, please.
    Good luck
  13. #1138
    Question
    and else!
    instructioin!
    good luck!
    =D.S. of M.=
    Isnt data encripted between interface and pc? I tought that sniffing the Hex Can this way would no more work?
    How to edit dump from sniffed data? Any explaintions pls?
  14. #1139
    Tereksaz's Avatar
    Nov 2010
    Quote Originally Posted by rsibiza View Post
    for example:
    need decode this array:
    4D 2C 0B D9 C5 C1 8D E9 95 51 DD 8A 3A 58 59 70 80 4E 9B A3 F2 A7 81 45 C5 78 48 54 CE 25 9F A8 E9 EC 45 93 A5 97 FF F9 2A 21 EF 12
    4D 2C 0B D7 2B 6F E3 C7 5B DF 93 89 EE CC BC 31 D4 27 55 A5 D1 E8 B1 ED 4F 6B C9 09 70 5B 88 89 41 EA 86 FE 4E 46 9C 2C 14 68 22 71
    4D 2C 0B 5D 79 E5 61 AD 89 B5 F1 71 27 4A D7 AB 75 C5 24 5E 0C 8B 3B 7D 11 C7 1D 86 E0 5D 24 0E FB 5A 76 EF AC C3 4F 82 48 C3 FD F7
    4D 2C 0B E3 C7 5B DF 93 B7 8B 4F 4D CE FC 59 22 58 3D F9 CB 4D 15 58 A7 6C 64 C2 33 88 3C 17 F8 E0 20 F6 67 52 BF 0D E0 CD 12 2F DD
    4D 2C 0B 69 15 D1 5D 79 E5 61 AD 54 02 EC 7F 50 A3 B9 3B 5E DE 38 ED CD 30 C8 D3 B9 17 2E 84 35 4A 95 EA 85 8F D3 20 E1 88 BA 57 B4
    4D 2C 0B BC 8C 1C 6C 7C 4C DC 2C 55 F9 AF 74 AD F8 BC 35 30 03 9B 57 74 35 DB 82 11 0A 2A C4 95 A4 8B 33 2F A2 9D 95 18 FA B1 ED E1
    4D 2C 0B DC 2C 3C 0C 9C EC FC CC 49 2C 3A 46 6F 65 0D C4 8A 93 40 B1 42 5B 17 00 9D 61 A5 64 8E 72 BC 89 A3 62 08 A8 A8 69 9B 77 6E
    4D 2C 0B 95 51 DD F9 65 E1 2D 09 DC 82 D8 EB 57 1F 08 78 B5 B5 93 CF CF 28 DE F9 17 59 4C DF EB 2B 99 BF 34 78 F7 02 BA C5 B6 DA 72
    it is all eeprom for atmega 162.
    64-bit key, different each time!!!!!!!!!!!!!!!!
  15. #1140
    blackpirate's Avatar
    Jun 2009
    for example:
    Wow!
    speechless!
    10q
    edit 1:
    till i find a version of hhd software cracked, can anyone try with USBTrace ???
    i think it have same features!
    cheers
    If freedom is outlawed, only outlaws will have freedom!!!!
