seal777 (8th June, 2022)
Does anyone have vcds lite and loader
more than 10 years old .......
Dear, what is the latest loader that works with VCDS v1 Amtega162 chip? Is it the one mentioned below? What is the latest VCDS it works with?
https://www.digital-kaos.co.uk/forum...06#post3639906
@ireun :
yes, the lastest loader for hex-can (Atmega162 chip based) is 9.2 by Kolimer
edit :
Vcds 22.3.1 FRM available
IMG_1328.jpgIMG_1329.jpgIMG_1329.jpgIMG_1327.jpghello
i have vcds 21.9 kolimer loader v9.2 hex v2 atmega 162 2117E17 FTDI FT232RQ
the problem started after a recent connection to the vehicle.
when the laptop was connected it blocked and since then I can't connect to any module on the car
the interface blinks green when connected to the car I run vcds I click select and then the modules that have any on the car to click just a little as an attempt to open and nothing happens I can not access any module
I tried to reinstall the driver by deleting and the installation failed I deleted the entire program from the laptop reinstalled failed again
as far as i know this is a clon version not orginal ross tech
after that i get help from Mario6 to take look on this post and download all i need but after i use vag com hw type to see is bootloader enabled and yes it is
then i use vcds usb eeprom write english language selected and finished that
i start vcds whit interface and he ask me to update offline
after finished update
i do test and try to enter module on car
and her are pictures of all proceses what i do
this time he entered module on car but after few secunds give me a messege no response from controller!
i tried change of version of vcds tried whit difrent drivers loaders but no use
can sombady help me i dont know what next to do
VCDS 9.2 by Kolimer it's not working on latest 22.3.1 (Hooking failed) and 21.9 cannot be installed anymore because "software is too old, please update to latest version" or something similar. Last working version is 21.3
rtbdiagnostic (15th June, 2022)
Anyone
jakuza (16th June, 2022), rtbdiagnostic (15th June, 2022)
@badrax
"Does anyone know where I can get the Hex-V2 STM32F415 from outside of AliExpress?
This type of interface. (NOT the 405 VIIPlus crap)"
Hi!
Late, but in case you have not find any.
https://www.obd2cartool.com/index.ph...oducts_id=1211
And thank you all for the great work you put in this!
My best Regards
badrax (4th November, 2022)
Brought a hex 2 clone, but I can't seem to get it working.
STM92F429
VET 6
9909Y 9R
MYS 99 017 5
ARM chip.
It came with vcds 22.3.0 and vcds loader v2 08.022.01.
Under the test function the device is found successful.
However, under vcds interface config I get the message "an interface must be connected by Usb to use this program"
Can't run a scan, it shows "failure to communicate (0)".
Cable is connected to the car with the ignition on.
Can anyone help please?
Good day to everybody,
I notice a strange message txt from VIIPlus loader at every startup of my second pc (W7 x64), and seems that many files into other software's folders are corrupted (corrupted and renamed with same message of the txt). It seems a virus of course, but it started after the last update of 22.3.1 ITT (with the fancy web page that ask you to confirm that you are using genuine interface). Anybody with same issue?
