Page 772 of 847 FirstFirst ... 272672722762767768769770771772773774775776777782822 ... LastLast
Results 11,566 to 11,580 of 12705
  1. #11566
    pt
    i have the same problem but using kolimor loader with new portuguese version 22.3.1
    they have injected as virus in portugues spanish and italien maby in others too
    english no problem
    Quote Originally Posted by Prototype View Post
    Good day to everybody,
    I notice a strange message txt from VIIPlus loader at every startup of my second pc (W7 x64), and seems that many files into other software's folders are corrupted (corrupted and renamed with same message of the txt). It seems a virus of course, but it started after the last update of 22.3.1 ITT (with the fancy web page that ask you to confirm that you are using genuine interface). Anybody with same issue?
    Attachment 894487
  2. #11567
    Aug 2018
    France
    VIIPlusLoader 08.22.07 is available but unfortunately only for people who bought their interface at ChinaObd2.com…
    https://www.chinaobd2.com/service/vc...ownload-7.html
  3. The Following User Says Thank You to ZIPPO4594 For This Useful Post:
    miouser (24th June, 2022)
  4. #11568
    Feb 2018
    I hope someone will post 08.22.07 link asap..
  5. The Following User Says Thank You to thunderbolt96 For This Useful Post:
    Aleks1975S (6th August, 2022)
  6. #11569
    Nov 2018
    Here is the link for VIIPlusLoader 08.22.07
    https://drive.google.com/file/d/1acH...ew?usp=sharing
  7. The Following 21 Users Say Thank You to HG7 For This Useful Post:
    Aleks1975S (6th August, 2022), AYD (24th June, 2022), carpcat (24th June, 2022), Col19 (3rd September, 2022), dotexe (24th June, 2022), dynamic20 (20th September, 2022), HAMIZA (3rd July, 2022), isavrseno (29th June, 2022), jakuza (8th July, 2022), kymlalu (23rd July, 2022), liviudiaconu (26th June, 2022), MaTyyyspl (26th June, 2022), miglins (22nd September, 2022), miouser (24th June, 2022), mkii (24th June, 2022), mrben (24th June, 2022), old_sheep (24th June, 2022), Papiti56 (22nd August, 2022), seal777 (3rd July, 2022), ZIPPO4594 (24th June, 2022)
  8. #11570
    May 2018
    Quote Originally Posted by HG7 View Post
    I will test 22.3.1 Eng + new Viiplusloader to check if solved Security Access Bugs
    UPDATE: Tested and security access finally working with V&D$ 22.3.1
  9. The Following 2 Users Say Thank You to Fabio89 For This Useful Post:
    Col19 (3rd September, 2022), jakuza (8th July, 2022)
  10. #11571
    I've a doubt and perhaps you can help me on this. Which is the last VCDS version that can be used with the Atmega cable & VCDSLoader v9.2?
    Thanks to this forum I've reached to update my cable some time ago but currently I don't know which vcds version can be used with the old Atmega 162 cable.
    Thanks in advance and regards.
  11. #11572
    Aug 2020
    I also tested 22.3.1 EN + VIIPlusLoader 08.022.07 and Security Acces on Engine 27971 it is NOT WORKING. The same bug.
    The same software 22.3.1 EN with Atmega on the same car it is working.
  12. The Following 2 Users Say Thank You to Pater Fortunato For This Useful Post:
    Haltec (31st July, 2022), seal777 (3rd August, 2022)
  13. #11573
    May 2018
    Does it has any solution ?
    "Licence check 2 required - Please send an email with a photo of your cable to info vag com espanol"
  14. #11574
    Nov 2008
    Quote Originally Posted by Pater Fortunato View Post
    Thank you for info. 100% Best
    BR
  15. The Following User Says Thank You to v11 For This Useful Post:
  16. #11575
    Jul 2022
    Hi there,
    I have a China Clone HEX-V2 Adapter. I think its an ARM Chip model. Is there anything possible to update this adapter? I only saw possibilities for the ATMega162 Chip (or with modifications to the board with the ST-Chip).
    The Adapter is bound to the VCDS 17.1.3.
    Yesterday I'd connected the adapter to my Passat B6: first all went flawlessly, but after a while unfortunately the adapter wasn't able to connect to CAN. The Test menu in VCDS told me, that "CAN: not ready". What could be wrong?
    Thank you all and have a nice day
  17. #11576
    Aug 2018
    France
    @DigitaCarlo :
    hi,
    it’s a fake Hex-v2, it’s a hex can with ARM chip based, but it’s not the best hex-can ! The best is Atmega162 chip based.
    you can update firmware to 1.96 with this package and use vcds 21.9 or 22.3
    https://mega.nz/file/oNsHlT4C#m60qeU...S5pajMRW-fkGYE
  18. The Following 3 Users Say Thank You to ZIPPO4594 For This Useful Post:
    dynamic20 (20th September, 2022), kaalis (8th July, 2022), seal777 (10th July, 2022)
  19. #11577
    Mar 2009
    is there any fix for 405 ARM illegal device i tested 22.3.1 EN + VIIPlusLoader 08.022.07 but 1st time it loaded vcds then the cable was blocked on the 2nd attempt i tryed to flash back with loader but same issue illegal device deleted all cleaned reg an reinstalled all but no joy
    thanks for any help
  20. #11578
    Jul 2022
    Quote Originally Posted by ZIPPO4594 View Post
    @DigitaCarlo :
    hi,
    Hi there and thank you for your answer. With the help of another user (directly by DM, thank you again!) we could solve the problem: the VCDS software have a kind of pirating protection and after a while of usage, the software don't recognize the cable anymore. Solution: uninstall/remove everything Ross Tech related and reinstall everything again. Since that, the cable works again as supposed to.
    Question regarding the mentioned ATmega162 cable: does the newer software (currently I use 17.1.3) e.g. 21.9 or 22.3 bring me any advantages for my "old" car (Passat B6 09/2005) compared to the version 17.3.1? I actually use the cable only for fault code readout and reset - no coding at this time.
    Thank you all in advance and have a nicer day,
    Carlo
  21. #11579
    Jun 2022
    Zenica Bosna i Hercegovina
    Hi guys,
    first thanks to @hid3 for amazing help, currently I don't want to spam anymore to him .
    Situation is next:
    We have bought VCDS clone cable with CD that had VCDS software versions 21.9 and 22.3, it did work without any problems until I made a mistake and run the program without Loader. Currently our cable is "locked" and it says Licence Revoked.
    Then we went with Kolimer loader 9.2 and tried:
    1. VAGCOM_HwType.exe (runs without any problems and shows current FW and HW versions).
    2. VAGCOM_EEWriteLang.exe (runs till the end and I get an error saying Invalid Bootloader ?). What could cause this ?
    I am attaching different pictures so You guys can see. What are next solutions ? Flashing through TL866 or ?
    PS Is there anyone available to guide me, willing to pay.
  22. #11580
    Feb 2019
    Quote Originally Posted by DigitalCarlo View Post
    Carlo
    New software does not bring anything new to your car.
