Page 774 of 854 FirstFirst ... 274674724764769770771772773774775776777778779784824 ... LastLast
Results 11,596 to 11,610 of 12803
  1. #11596
    Jul 2022
    Greetings to all! Has anyone tried clone Hex v2 on chip stm32f405 or stm32f415 for cars in 2021, Skoda or Audi with SFD lock? blocks are read? if you first remove the blocking of the sfd, is it possible to encode the blocks?
  2. #11597
    Aug 2021
    Hey guys. I lost my cd of the chinese VCDS 12.12
    May someone please provide a download link ?
    THANKS
  3. #11598
    Apr 2018
    Quote Originally Posted by frikki View Post
    hi there members. i have a old vag 11.11 cable. but dont have the software for it. does anyone have maybe the software. its a aftermarket cable. got it from a friend some time ago. i need to reset the long term memory of mp9 ecu. the hex v2 cable is incompatible to do reset mp9. many thanks in advance. keep well.
    Link in PM sent
  4. The Following 2 Users Say Thank You to Tib82 For This Useful Post:
    dynamic20 (16th September, 2022), frikki (7th August, 2022)
  5. #11599
    Sep 2019
    hi, am I doing this right way,
    i downloaded software from rostech site original 22.3.1
    and from here i found loader 9. something,
    and it works, reads codes, clears them
    bud when coding the helper is not available, i have to manualy put codes in?
  6. #11600
    Oct 2021
    Quote Originally Posted by kaalis View Post
    RUS 22.3.1 released couple days ago
    Sent from my VOG-L29 using Tapatalk
    Did you tried it with latest loader ?
  7. #11601
    Quote Originally Posted by vcdss View Post
    Older car without CAN? MY before 2004-2005 = no CAN
  8. The Following User Says Thank You to liviudiaconu For This Useful Post:
    seal777 (3rd August, 2022)
  9. #11602
    Jul 2022
    Hello,i would be thankful if someone could help me.
    I have 2 clone intefaces which dont work.Test is ok,but when i want to scan or something else,i get the messege:functions not supported by the gateway.I think the cause is that the interfaces were tried to use with the wrong software.
    Is it possible to fix them?What should i do?I looked here on many pages and searched the internet,i found just partial or incomplete informations about it.I have not found anywhere what I exactly need to do,so i did not try anything in order not to destroy them completely.
  10. #11603
    EU
    Start with good quality pictures of PCB from opened cables.
  11. #11604
    Aug 2022
    Hello everyone!
    After some years working fine, my ATmega162 interface stopped working correctly with VCDS 16.8 (that came on CD with it).
    In details, VCDS doesn't show me options to calibrate Adaptive Cruise Control even if it sees correctly it's module (a couple of years ago was working fine) and from a week VCDS also doesn't allow me to enter and scan Engine Module (it recognizes the module and it's errors but when i try to open it the system doesn't preoceed.
    I don't know what's the issue. Could they be problems related to VCDS? I already tried to unistall and install again the software provided with the interface, but the AAC problem still remains (i haven't tried a clean install for the new Engine Module problem).
    Do you think a software update to newer versions of VCDS could solve my issues?
    Also, I downloaded VCDS 20.4.2 and 9.2 Loader and the software recognizes my interface but, when i TEST it at the beginning, it shows me "not plugged into car" even if it is.
    Is it related to an old firmware version of my interface?
    I already made HD photos of my interface PCB.
    May someone please help me?
    Thanks!
  12. #11605
    Sep 2015
    The problem may be the stc chip,you need to remove it,look on the forum.
  13. #11606
    Aug 2022
    Thanks for the answer!
    I read about removing the STC chip in oder to update the interface firmware.
    I think, from what I've read, that my interface must be updated in order to be compatible for VCDS versions newer than 16.8. Am I right?
    Do you think that a complete update (VCDS and interface firmware) could solve my issues?
    Also, I can't understand why these two modules suddenly can't be read and cleaned correctly. I use a laptop only for car diagnosis, never connected to internet (wifi and lan disabled) and with no antivirus nor firewall
  14. #11607
    Jul 2016
    Vilnius
    Greetings. Anyone know suitable alternatives for MIC2920A-5.0WS voltage regulator?
    MIC2920A is out of stock everywhere without any signs it might become available again in the near future
    * MK100
  15. #11608
    Aug 2018
    France
  16. #11609
  17. #11610
    Jun 2020
    Have we still got issues with latest vii plus loader and 22.3.1. Still can't get security access to work.
    And what's the most stable vii plus loader and software version to use?
    Thank you.
