Hello my friends
I got vcds 22.3 it is china colne
Can I use odis software and how??
bg17aw (12th January, 2023)
Mine vcds has the same 415 chip. It should be working on 20.41 with no loader. Basically when starting up the vcds app first time everythings looks promising... First full scan looks ok. When I try to jump to any module from scan window for example trying to enter HAVC module and check dtc when leaving the dtc window it looks like it cannot stop connecting to the module but still connecting doing refresh of the connection and I have to force to close the window using cancel. is this any bug in 415 chip or mine is just bugged somehow? Thanks for response. @Bardax could you guide me to update my cable fm to use newer vcds version? Maybe it should be any solution.
Thanks and regards.
Im in a realy tough situation and i cant afford to get more VIN on the vcds. I tried to pm you but im not quite sure if i did it right.
Could you send me that patch over or give me a link?
TIA Onyx11
which clone limits your vin count?
Some people have original interface, not clone.
there is a very good forum for owners of original cables .
Yeah, but can you ask there how to “hack” an original cable ? Dooh !
jan4 (8th December, 2022)
Hello Friends! I have a clone china cable v17.1
I wanted to ask if it is possible to update and to which version for good functioning.
Chip Atmega162 e FT232
Photo: https://www.mediafire.com/file/27xnv53kwumuyoc/20221203_201146.jpg/file
Yes, you can upgrade it with kolimer’s package
Hi !
VCDS 22.10 eng and FRM available
waiting new VIIPlusLoader…
If your hardware is 17.1, then you can only use 17.1 or 16.84 software, if you need, I can pass you the software. Or you need to remove the two short circuit blocks on the PCB, and then update the program in the 162 to the kolimer version, so that you can use the loader and the latest software
