What latest version Vcds akp works with the VIIPlusLoader-08.022.09.005(BETA) ?
I have not bought the cable yet. Where can I buy the best cable for cheap? With shipping to Sweden.
Hello my friends
I need oddis work with my openport 2.0 tactrix.
Can i update my vcds B03 -V2
21.3- EN
Thanks in advance.
I tried ODIS -S 5.1.6, ODIS-S 7.2.1 , ODIS-S 9.1, ODIS-E 9.2 and none worked for me as passthru with Tactrix OpenPort 2.0.
However, they work with the cheap Mini VCI interface (Toyota Techstream). Of course, to a limited extent. (does not detect ignition)
So I guess the more expensive VXDIAG is better. (I did not try)
You select it in the installer
Actually the vxdiag for vw is cheaper than ori openport. The vxdiag SE Pro is expensive but you can add licenses for other btands.
Did you install the drivers from tactrix website? I have gotten it to work with 9.1 as passthru.
HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
seal777 (17th December, 2022)
I have Tactrix from Ali..... and I'm using the drivers from the CD. Not from the original website OpenPort 2.0. Apparently, these drivers can damage the interface. (I did not check)
Hello my friends
Can i update my vcds v2 to 2022 version
Vcds 22.3 china colne
Thanks in advance
@Kimoo2000k
maybe. open case and use thread search!!!
HI friends i had vcds atmega chip v162 iam tested on vcds 22.9 iam getting can not ready.the item sill new not work on can protocol i tested on windows 10 and windows 7,what is the problem thanks for help
is viIPlusLoader 08.022.09.005 working with STM32F405 Danish v22.10.00 ?
Thanks![]()
HI ,YOU GET A SOLVE TO YOUR PROBLEM I HAD SAME ISSUE MY CABLE IS NEW AND I GET CAN NOT READY
