Page 790 of 854 FirstFirst ... 290690740780785786787788789790791792793794795800840 ... LastLast
Results 11,836 to 11,850 of 12803
  1. #11836
    Nov 2020
    Quote Originally Posted by hid3 View Post
    Are you stupid or you were born as an idiot? We pointed out you FACTS that your shitty vcds doesn't work at least in several areas, meanwhile you keep blindly pasting same text over and over again that "it has same function as ross-tech".
    Phuck no, it doesn't! It doesn't work for everyday use!
    Potential buyers should be aware of what they are buying.
    And finally, this is some kind of chinese mentality/cultural thing - they always claim their truth, even if it's clearly obvious that it's not what they say. E.g. they say that white is actually black, whereas it's white. Whom you're gonna believe - your liars eyes or sincere chinese guy?
    same functions
  2. #11837
    Nov 2020
    Did you have flyfvdi vcds hex-v2 ? if you do not have ,please take back your words.
    if you do not trust flyfvdi vcds hex-v2,please buy ross-tech vcds hex-v2.
    i suggest you compare their fucntions first.
  3. #11838
    Jun 2020
    Quote Originally Posted by flyfvdi View Post
    Hello Fly, I've had many of your STM 405/429 cables. However, Security access does not work after software version 21.9.
    This has been said many times over the past on this forum. And it seems like you've been ignoring the issue.
    All the latest Viiplusloaders do nothing to fix the issue. All they do is allow the cable to be used on the latest software version. But does not help in rectifying the issue of security access.
    So could you please comment on that particular issue of security access after 21.9?
    Please let us know why security access does not work after 21.9 and believe me, people will stop asking you.
    Thank you.
  4. The Following 4 Users Say Thank You to Billyym For This Useful Post:
    Col19 (6th February, 2023), EpicFail78 (5th February, 2023), jan4 (5th February, 2023), kaalis (4th February, 2023)
  5. #11839
    Sep 2016
    Is this files can fix my vcds real hex v2 from china chip 405 which is blocked and tried every thing to get it back no way it got blocked forever error message about illegal and blocked
  6. #11840
    @heshamzn
    do clean install and disable AntiVirus
    use last VIIPlusLoader https://www.digital-kaos.co.uk/forums/showthread.php/99750-VAG-COM-VCDS-EVERYTHING?p=4477866&viewfull=1#post4477866
  7. #11841
    Jan 2023
    Quote Originally Posted by Billyym View Post
    Thank you.
    Hi, I have just tested my 429 cable with 22.10 and latest VIIPlusLoader.
    While security access does NOT work with the english VCDS (error 0x00, not accepted by controller), it was successful with the german PCI version (22.10 as well).
    Could you do a test with the 22.10 german PCI? Would be interesting to see, if I am the only one where it works \o/
  8. #11842
    Feb 2013
    Quote Originally Posted by Mnaoufal View Post
    Hello everyone,
    Today i came up with a new cluster and since my car (Seat Cordoba 1.9 SDI 2004) have immo, i downloaded most common used vag versions (vag eeprom 1.19/120 , vag tacho, vag k+can...)
    vcds is working without any problem it can read my car but the problem is vag programs doesn't find my car and shows either no ECU found or no device found.
    I'm using Win10 64bit.
    And China Hex-V2 cable (FT232RQ CHIP).
    What do I need to do, any help please?
    vag eeprom 1.19/120 , vag tacho, vag k+can, commander... etc etc they cant work with vcds cables, they just works with their own cables
  9. #11843
    Col19's Avatar
    Jan 2019
    France
    FlyFvdi should be banned from the forum for lying about hex v2 cables, it misleads members, its sole purpose is to deceive to sell their tools which is no better than an Atmega. Unfortunately Chinese sellers like to sell dreams.
  10. The Following 2 Users Say Thank You to Col19 For This Useful Post:
    hid3 (6th February, 2023), Qwarz (14th September, 2024)
  11. #11844
    Aug 2021
    Hi! Curently I have an ATMEGA 162 and I want to buy a V2 clone. I've read more than 50 pages of this forum and used Search, but I didn't manage to find out wich one to buy.
    STM32F405 or 429? There is any differences? Is one better that the other? Wich one should I buy?
    Thanks a lot!
    Regards,
  12. #11845
    Nov 2020
    Quote Originally Posted by rucsandac View Post
    Thanks a lot!
    Regards,
    flyfvdi vcds hex-v2 with STM32F405VGT6/STM32F429VET6 has the same functions.
  13. #11846
    Nov 2020
    vcds hex-v1 with ATMEGA162-16AU, vcds hex-v2 with STM32F405VGT6. please see www.ross-tech.com. Ross-tech is the vcds hex-v1 and vcds he-v2 original factory.
  14. #11847
    Nov 2020
    Quote Originally Posted by klsdjfklsdjflks View Post
    ok, next to fix it, please contact fly vcds hex-v2 support engineer.
  15. #11848
    Dec 2021
    Hi! I bought a clone of hex-v2 cable based on Atmega162. It works with vcds 22.10. I can read VW Golf 2014, but I can't read VW Passat B8 2021, VCDS shows message: "Unsupported vehicle".
    From the seller I have all files to flash atmega and eeprom.
    What should I do to make my cable support new cars?
  16. #11849
    Oct 2017
    Germany
    Quote Originally Posted by aivs View Post
    Nothing, it is not possible. You have to buy a "real v2". See the discussion some lines above.
  17. #11850
    Nov 2020
    vcds hex-v2 with Atmega162 just support the cars before 2018
