Thank you. Did you try it with VCDS 23.30? Are security codes now working? Thanks.
mickyjenny (9th March, 2023)
I have buy a vcds clone , and i try to install 20.4.2 or 22.1 release and try whit loader 9.1 or 9.2 but still not working when i it the loader it shows the blue square vcds loader god bless kolimer x86 9.1 or 9.2 but then the square disaper and the prog does not load , im working on windows 7 professional 32bit
any one have this problem ???
Dobermann (10th March, 2023)
The fly spokesperson fledapa2:after the last decryption message from BADRAX
BADRAX alias Futur KOLIMER.
vcds hex-v2 languages to VIIPLusLoader version
The answer is simple: English also works without a loader, the other language versions ONLY through the loader. Any software run through the loader NO LONGER HAS that security code access bug. If English is run through VIIPLUSLOADER, Access security code will work without problems. Because of this, it appears that the German software does not have that bug, because it is run through VIIPLUSLOADER.
Hi annyone have a link to can commander v3,6 ???
jan4 (10th March, 2023)
