Page 798 of 854 FirstFirst ... 298698748788793794795796797798799800801802803808848 ... LastLast
Results 11,956 to 11,970 of 12803
  1. #11956
    Mar 2019
    Quote Originally Posted by klsdjfklsdjflks View Post
    22.9 is older. 9 < 10
    Just to clarify, I don't care at all for the english version (native german here). Just wanted to help others with these comparisons and tests.
    btw. S12345 is not a security code. It only changes the session mode (Engineering mode IIRC). Security codes are numerical only.
    Mathematically, 22.10 = 22.1
    I'm not an English native either, but I still think it is best to use the English version, and it would help us here to standardize our testing. It is pretty much the same reason we are all using English language here on the forum...
    I did ask what else to test, what modules exactly, what steps. I want to help testing and reporting back, but not sure what exactly. Probably it should be a combination of things that are more complicated? Long coding is always risky with a clone...
  2. #11957
    Mar 2019
    Would you mind testing 22.10 with loader 08.022.05 as well? It's possible that VIIPlusloader for 23.3 was fixed and only 22.10 is broken
    where can I download 22.10?
  3. #11958
    Nov 2020
  4. The Following 2 Users Say Thank You to flyfvdi For This Useful Post:
    jabichocu (13th March, 2023), mazzy960 (17th March, 2023)
  5. #11959
    Mar 2019
    Quote Originally Posted by flyfvdi View Post
    I noticed something in a picture from the link above, why install 32 bit version?? I never used 32bit version in the last 10 years.
    Also, the box "Open windows firewall" should be unchecked in my opinion.
  6. #11960
    Jan 2023
    Quote Originally Posted by bg17aw View Post
    Software versioning is not based on decimal math. Actually, the correct version is 22.10.0. That isn't even a valid decimal numeral^^
    Many people were saying that security codes were not working, while it was working fine for me. "Standardizing" testing (aka using only the english version ever) would not have shown that difference betwenn English vs. German.
    (Also, why should I use something that doesn't work for me? )
    The problem regarding testing is not the language but documenting what exactly was tested with which version, language, .... (and ofc the correct loader versions must be used. Probably problems result from bad combinations of VCDS and loader version.)
    Also, interpreting the test results correctly seems to be a problem here.
    Another problem is that people don't understand the differences between various clones and are not even able to match the right combination of VIIPlus Loader / VCDS Loader, VCDS and clone interface and then only report "does not work for me". Yeeeah, welll....
    Until now, I have not seen any problems with Long Coding during testing. I believe it's a problem with the very shitty clones, while the better 405/429 clones *seem* to be ok. ...ish
    Regarding testing of security codes, you could try to adapt e.g. the turn signal cycle count, which requires a security code.
  7. #11961
    Jan 2023
    What happens when you uncheck the 32 bit option? Doesn't seem to be required, is it? Anyway, I don't think it's relevant at all.
    EDIT: ooooh. omg. This could be the reason for many problems. Maybe the VIIPlus Loader does only work with the 32bit version! The German version is 32bit-only....
    EDIT2: CONFIRMED! Even with 22.10.0 (English) security codes work, but only when the 32bit version is installed. VIIPlus Loader simply does not support the 64 bit binary
    The firewall option is only relevant for HEX-NET. You should uncheck it and also add proper blocking rules for VCIConfig.exe and VCDS.exe to prevent your interface being blocked.
  8. The Following 3 Users Say Thank You to klsdjfklsdjflks For This Useful Post:
    Col19 (10th April, 2023), MrDerv (13th March, 2023), seal777 (15th March, 2023)
  9. #11962
    Mar 2023
    Hello to all gurus of this forum. These are pictures of my two cables, first one is Atmega (really cheap) but the other one I have no idea what sort of cable it is (bought it in 2009 ) can anyone tell ???
    https://ibb.co/tBgfPTG
    https://ibb.co/stbfpdF
  10. #11963
    Sep 2015
    Quote Originally Posted by jabichocu View Post
    Take a good photo No. 2 and I'll tell you.
    Zrób dobre foto nr.2 to Ci powiem.
  11. #11964
    Mar 2023
    Well, well...it is apparently a 2009 Atmega >>https://ibb.co/z6xYCpv
  12. #11965
    Sep 2015
    This cable should work.
  13. #11966
    Mar 2023
    Of course it works! I´m using them both...so, is there any difference between> atmega162 16au 091sh and atmega162 16au 2221h ??
  14. #11967
    Sep 2015
    But you care how it works.
  15. #11968
    Feb 2018
    where can I download 23.3.0 with loader
  16. #11969
    Nov 2018
    I wanted to say that I tested the german version and security access works and in the meanwhile everything is changed here.
    Tomorrow I will try with 23.30 and 32 bit exe (if the option is still there).
    P.s.: I found another bug beyond the security access, in module 17 instruments you can not test the cluster functions ( I had to calibrate the needles), no problem with 22.10 german.
  17. #11970
    Jan 2023
    Quote Originally Posted by mickyjenny View Post
    I'm sure there's much more broken without VIIPlus Loader (or when it's not working like with the 64bit VCDS)
