Page 79 of 854 FirstFirst ... 2969747576777879808182838489129179579 ... LastLast
Results 1,171 to 1,185 of 12803
  1. #1171
    I was pointed to this discussion (Thanks dorcky) in trying to figure out an upgrade for my old 512.4 VAG-COM (clone) cable to a later version (v8 or v9). Here are the pictures of the existing VCDS cable.......
    http://img824.imageshack.us/img824/458/vcdscable1.jpg
    http://img843.imageshack.us/img843/7734/vcdscable2.jpg
    Can you pl. tell me where to start in terms of what programmer can I use for this, where to get it from and what is the s/w that goes with that programmer to flash. Are there any tutorials (step-by-step) available for this. I am on WIN XP (SP3).
    I am sure there are bits and pieces of this info in the thread and I am trying to read through it as well but it is quite overwhelming and I am pretty much confused.
    Thank you for your support and help
    SB
  2. #1172
    Dec 2010
    Czech Republic
    Quote Originally Posted by sbihue View Post
    SB
    Can you do more better picture, please.. Use macro mode in you camera, tripod.. whatever to clear picture where we can easily read what is written on the chips, thanks
  3. #1173
    DK Veteran bibkare's Avatar
    B & H
    SB
    your pics are crap, how can you expect to help you with that
  4. #1174
    Quote Originally Posted by tomasfilip View Post
    Sorry my regular camera crapped out and am using an old sony with no macro.
    Meanwhile I'll try to post some info on the chips on the PCB...
    Side1 (without LED) of PCB has......
    • ATMEL - ATF16V8BQL 15JC 0141
    • FTDI - FT232BM 606-1
    Side2 (with LED) of PCB has.......
    • ATMEGA162 16UA 0553
    • A Three pronged connector L805CV CC10R VW MAR 516
    • Besides the LED, this side has three crystals 6.000, 7.3728, 16.000
    The PCB is NOT soldered DIRECTLY to the CAN interface. Three wires from Side1 and Three from Side2 of the PCB are connected to Six pins (Three each on top and bottom row) of the CAN interface.
    From this forum, I have compiled the following...
    VCDS_SOFT_DUMP_TOOLS that include
    • FTDI_TOOLS
      • Mprog
      • VCR_CDM 2.00.00
      • vidpidfix.exe
    • PonyProg2000
    • VCDS_805_dumps
      • Ross_Tech.ept
      • VCDS_805_Atmega_162.bin
    Tutorial, everything-tutorial (VCDS 805 programming and upgrading)
    What are the next steps? Should I build the programmer (parallel port) by using the layout/mappings in the tutorial and then flash the ATMEGA using this tutorial verbatim?
    SB
  5. #1175
    Quote Originally Posted by bibkare View Post
    Sorry, I'll try a loaner camera and try to post better ones later today
  6. #1176
    Nov 2010
  7. #1177
    Mar 2009
    https://t.me/pump_upp
    1. dump for FT232BM -have bootloader 256 word - it is for all old adapter!
    2 dump for FT232RL and new version com port - have 512 word - it is for all new version adapter
    3. dump ver. 1.78 -183 for FT232BM not same as dump for ver1.78 -1.83 for FT232RL and new com port.
    4 dump for com port, dont can use right for USB version , can use only for usb Serial Com Converter + latency timer =2 !!!!!!
    and else!
    about free damps - make dump very easy.
    instructioin!
    buy original HEX-COM+CAN interface- it is not many moneys.
    install and run HHD software - USB snifer.
    connect usb serial com converter and connect HEX-COM+CAN interface.
    Run snifer and run VCDS 11.2 or any another version.
    Select com port 2 and make test interface.
    Closed VCDS and save log file format HTML to snifer.
    open file and find all need information -then decript it and write dump.
    All time for job - not more 30 min.
    And gold key to your hands!
    good luck!
    =D.S. of M.=
  8. #1178
    Oct 2010
    portugal Coimbra
    Default audi a4 8d0 920 900 dash and radio light problem
    when turn off ignition key dash and radio light doesn't turn off.
    and when we drive at night light is all off.
    509 019 305 200
    What should i do ? light control doesn't work
    Thanks for all
  9. #1179
    Member Icemaan's Avatar
    Quote Originally Posted by thomasnb View Post
    509 019 305 200
    Thanks for all
    U lost m8?
  10. #1180
    B & H
    @ baigano, can you please tell us what's the point of repeating somebody's post (in this case tereksaz's)
    which was posted few days ago
  11. #1181
    Oct 2008
    On Earth
    Maybe he wants to explain like this that it is not a piece of cake like that guys said.
    Good luck
  12. #1182
    Jan 2011
    Russia
    Hello PedroDelucchi
    My fault, I was solder the wires on LPT connector in incorrect
    way - upper part was "mirrored".
    I'm not sure that was mirrored, just a few pins aren't correct connected (4,5..as I written, but not mirrored)
    But I'm to tired now to check your new image, sorry
    It is not a question - how much I failed. Mirrored or no - it does not matter. Now, the wires are soldered correctly.
    And one more question - do I need something another dump for Russian language software, or should I use something specific VCDS software?
    each locatization of VCDS use own keys included in this VCDS version, so english doesn't works in Russian, French.. others and probably viceversa, Russian doesn't works with English
    Can You explain it little more? I need the specific software for Russian or specific dump?
    Heh... I think, now I totally destructed my VCDS...
    With 12v power connected (diode flashes green and red),
    Blinking/flashing Indicate cable is works..
    Of course! But - NOW - after connection to LPT with 12v power connected and with no common ground it is not flashing... Maybe, something element on device is dead?
    I connect it to LPT port...
    PonyProg does not recognize my VCDS (error -24).
    Disconnect the 12v power, power off my PC. Disconnect the LPT connector, power up 12v again, and the diode not even flashing anymore...
    I think, that you mix more things together
    +12V into 7805 (Input) create +5V for uC, otherwise uC isn't powered and you cannot program it..
    When you connect programmmer, reset is connected and uC is reseted - so no blinking anymore, that is correct
    What is UC? As I wrote above, LED no blinking totally - with LPT connected or not, when I connect it to USB... Before, the LED flashes, when the device is connected to USB or when it powered with 12v.
    For now, when I try to insert the USB connector into the USB port, for trying to do all the procedure again, the VIDPIDFIX does not recognize the device... (screenshot added)
    But the VCDS is still recognized by the OS ("USB-Serial converter" and "Ross-Tech HEX-USB")
    ? VIDPIDFIX should always works, so what you written is strange.. How can VCDS recognize this cable if VIDPIDFIX not? What say Device Manager, is there some Ross-Tech device/USB serial converter?
    WinXP: Control Panel -> System -> Hardware -> Device Manager
    When I wrote "VCDS", I mean the device, not a software. I'm sorry if I'm wrong. So, in Device Manager the device present - "USB-Serial converter" and "Ross-Tech HEX-USB", without drivers installed or with drivers installed.
    So start please reprogram uC, please be 100% sure that LPT is correct.. than we can continue with rest..
    Thank You very much for help and attention.
  13. #1183
    Jan 2011
    Russia
    Quote Originally Posted by max4ever View Post
    The interface you checked with PonyProg ?PonyProg is version 2.07c? You choose AVR micro and ATMEGA 162?
    Sorry for my bad english!!
    Yes, PonyProg from this forum. Version 2.07c. It has the settings for AVR-micro and Atmega 162 already chosen. And from official site - results are the same...
  14. #1184
    Dec 2010
    Quote Originally Posted by spongemak View Post
    No, everything seems to work fine, adaptation works, Long Coding doesn?t make any changes, this cable only came with 10.6.2 cracked software and doesn?t run on 10.6
    Found the solution for my problem, it's a software problem, here is the right setup for 10.6.2:
    http://rapidshare.com/files/44543038...-Installer.exe
    Source:
    http://translate.google.com/translat...he-9783-4.html
  15. #1185
    Dec 2010
    Czech Republic
    Quote Originally Posted by PedroDelucchi View Post
    Each translation of VCDS has own keys/serial numbers because official distributor knows cables sold in his country. So you need Russian contains of Atmel eeprom + Russian version of VCDS.
    I guess that you erased Atmel chip, so there isn't firmware, so this is reason why LED no flashing. Please try successfully reprogram Atmel with working eeprom contains (in this forum are both), then if you have success we can continue
    uC = microcontroller (u=micro) so this is Atmel ATMEGA162 here.. On my side when firmware is alived, LED is blinking only and only then if cable is plugged in the car or +12V is connected to the power.
    Ok, so "cable"; is better than VCDS, because is common use VCDS for software. It Is strange that you have two device in the system in one time. Do you have really some usb->serial converter in PC?
    When Ross-Tech is appear, that FTDI chip (it's just usb->serial converter) is successfully recognized. It's very good step to continue. But this is only converter for communication's PC with cable.
    When you got "usb->serial converter"; you need program it FTDI eeprom, you can do by PC with proper software (VIDPIDFIX for example),
    But for beginning try reprogram ATMEGA (uC)
