Page 80 of 854 FirstFirst ... 3070757677787980818283848590130180580 ... LastLast
Results 1,186 to 1,200 of 12803
  1. #1186
    Portugal
    Quote Originally Posted by bibkare View Post
    I don't know how your interface looks like but i am sure you have stc chip on it, first of all upload a clear picture of your interface pcb, both sides then i can tell what should be done to avoid that error.
  2. #1187
    Portugal
  3. #1188
    Portugal
  4. #1189
    Jan 2011
    Lithuania
    Quote Originally Posted by toquim View Post
    Your interface like mine.Only one difference-my interface with STC
  5. #1190
    Jan 2011
    Lithuania
    I need to know what destroys the software of the atmega162 . When we do "autoscan" at VCDS.
    If is MCP 2551 or Gal16v or another component the cable.
    Thanks.
    KenshinPT(thanks to him) said that the function of destroyer doing STC.Are your cable alive or dead? My is alive(in work),but it's necessary to protect cable from destroying(It is mine opinion).We can talk about it via PM to avoid spaming this thread
    I would like to desolder STC from my cable,but I'm not sure will be it right.Your picture says that may be right.
  6. #1191
    Dec 2010
    Czech Republic
    Quote Originally Posted by art64 View Post
    1. btw, good picture of your cable! Clear, not dark, everything is readable and its put as attachment.. I hope so that others will take as example..
    2. STC chip impact the firmware - i'm not sure if is destroyer, but needs to be removed, just read this forum from beginning, its there setup how cable with STC chip should be fixed
  7. #1192
    Feb 2011
    That part about removing STC chip is not necessary true .I have a Super 812.4 dual k plus can cable from china.
    I made a nice interface an have used ponyprog to reflash it,all i did was wire up the power an atmega162 chip,i didn't remove the STC chip at all or the transistor or resistor.It flashes perfect everytime using only 3.3v interface.I am presently running 1062 VCDS an working fine.
    I didn't wire up the power to the input of the 5v regulator,i wired power onto the output pin of the regulator so that i could use the normal power supply from my programmer interface.
    The STC chip looks to me as only reflashing the FTDI eeprom,so why remove it ??? I could only see traces going to the FTDI eeprom in my cable.
    Just to say that not all the info here has to be followed exactly.Think about stuff yourself .This is an excellent site an alot of very good post here.
    Another tip,i wired the atmega chip pins an power lines to unused pins on cable car connector end, to program i just plug it in,no need to take plastic cover off,i used pin 9,10,11,12 an pin 2 for power , ground existing pin 4. Check
    wiring on car if you try this to be sure
    that those pins aren't also connected
    on the car.
  8. #1193
    is there Vcds 10.6.0 German???? i need it
  9. #1194
    Jan 2011
    Lithuania
    Quote Originally Posted by willy789 View Post
    I made a nice interface an have used ponyprog to reflash it,all i did was wire up the power an atmega162 chip,i didn't remove the STC chip at all.It flashes perfect everytime using only 3.3v interface.I am presently running 1062 VCDS an working fine.
    on the car.
    It's difficult understand what changes you made. How did you can wire up the power to the output of the 5v regulator?Hole chips of interface uses
    5V,not 12.Is it temporally,only in the programming mode?
    I understood why you wired up atmega chip pins and power lines to unused pins of cable car connector.For programming.
    But I misunderstood,are you regularly reprogramming atmega?Why?
    Are your cable same like mine?Can you show the picture of it?(In position will be seen changes you made on)Thank you
  10. #1195
    Feb 2011
    Slovenija
    Hello!
    This is very interesting stuff!
  11. #1196
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by rancoxxx View Post
    Yep there is:
    VCDS (VAG-COM) DIAGNOSETOOL - Diagnose f?r VW, Audi, Seat und Skoda Fahrzeuge, MFT
    or
    http://shop.dieselschrauber.de/
  12. #1197
    Dec 2010
    Quote Originally Posted by spongemak View Post
    I have the same problem, just bought a 10.6.2 cable and everything seems to work fine except that it doesn't save the coding, does any one know the solution to this?
    Have the same problem to... 10.6.2 china cable...
    when I open VCDS and I do an AUTOSCAN, it doesn't read all modules from car (VW Scirocco 2.0tdi 2010). And after autoscan when going on modules and changing the long coding, the "do it" button doesn't work.
    If you start VCDS and go immediatly on module mode, change the long coding and press "DO IT" button say's Saved but the long coding entered is not saving at all
    Other problem after the autoscan, if you try to do another one I get : Auto-Scan..."Function not supported by the gateway . Can someone Please Help with this issue ??
  13. #1198
    Wink
    Quote Originally Posted by kodo28 View Post
    Please dont double Post and mess up threats...wait getting answer on 1 Threat before posting same question in other threats please
  14. #1199
    Dec 2010
    Quote Originally Posted by rsibiza View Post
    Both treaths are for vcds or i'm wrong?
  15. #1200
    Default Problems with china VCDS 10.6 cable
    Hi!
    I have problems with my VCDS cable. When it is connected only to usb vcds detect cable but if i connect it to power supply there is interface not found error. I`ve got 2 same cables and both not working
