Page 804 of 854 FirstFirst ... 304704754794799800801802803804805806807808809814 ... LastLast
Results 12,046 to 12,060 of 12803
  1. #12046
    Jan 2018
    problem is sorted now thanks
    downloaded the laatest software from official vcds replaced the files keeping koilmer patch worked as charm again
  2. #12047
    Nov 2020
    Quote Originally Posted by constantinexx View Post
    what is kolimer patch ?
  3. #12048
    Jul 2018
    debug 415.jpgpinout 415.jpg I found this pinout for stm32F415
  4. The Following User Says Thank You to drdahmani2 For This Useful Post:
    mexanico1971 (14th May, 2023)
  5. #12049
    Jul 2018
    I found 9fb319528257d890d8a1bda26ccd8155.jpg pinout for stm32F405 but not tested either
  6. #12050
    Sep 2016
    this pinout to connect stm with what device ?
  7. #12051
    Jul 2018
    With ST-link
  8. The Following User Says Thank You to drdahmani2 For This Useful Post:
    heshamzn (20th April, 2023)
  9. #12052
    Sep 2016
    stm32F429 Also got stm32F415 but don't know what software to use WhatsApp Image 2023-04-20 at 12.23.16.jpg
    i mean where is vdd and pb3 on my sv link ?
  10. The Following User Says Thank You to heshamzn For This Useful Post:
    seal777 (23rd April, 2023)
  11. #12053
    Jul 2018
    This is the datasheet pinout
    regarding the connection to the stlink (I did not test it) but we can seek support from the Pro on this forum
  12. The Following 2 Users Say Thank You to drdahmani2 For This Useful Post:
    heshamzn (20th April, 2023), seal777 (23rd April, 2023)
  13. #12054
    Jul 2021
  14. The Following 2 Users Say Thank You to wiechec For This Useful Post:
    seal777 (23rd April, 2023), ZIPPO4594 (23rd April, 2023)
  15. #12055
    Nov 2020
    Quote Originally Posted by wiechec View Post
    yes ,flyfvdi vcds hex-v2 will update it soon
  16. #12056
    Feb 2018
    Quote Originally Posted by flyfvdi View Post
    1.vcds hex-v2 ATMEGA162 just can do 1996-2015 old cars,without loader,can not update freely, support one language, put vcds hex-v1 PCB board into vcds hex-v2 shell.
    2.vcds hex-v2 STM32f415 can not update freely, without loader, can not do Security Access, support one language.
    3.flyfvdi vcds hex-v2 viiplusloader stm32f429, update freely, with loader, can do Security Access, multi-language support.
    what is the status for stm32f405? what is the difference from 429?
  17. #12057
    Jun 2020
    [EDIT. The cables are in fact 405! Not 415 as stated!]
    Just received some of the STM415 cables. The ones that are basically 'non update'.
    However, they've been ripped with the new chinese firmware that allows them to work with 23.3.1 with latest firmware. And can also use the latest viiplusloader.
    If anyone does plan on buying these. Just remember. You will need to use Viiplusloader as security access won't work with Just the regular \/cds software.
    In order to get them to work correctly. You'll need to install vcds 32bit version not the 64bit.
    Then install latest Viiplusloader. And use that to launch the software for you.
    Last edited by Billyym; 24th April, 2023 at 06:55 PM. Reason: Mistake! Wasn't stm415 they are stm405!!
  18. #12058
    Dec 2020
    Quote Originally Posted by Billyym View Post
    Can you check and see which RDP level they are set to?
    Make sure you only use it for launching!
    If you start a firmware upgrade you will be flashing an unpatched firmware that wont run on this cable.
    The unpatched firmware might also lock the STM to RDP2 so you won't be able to re flash it using the ST-Slink programmer or in DFU mode.
  19. #12059
    Sep 2016
    how to flash it using st link can badrax show me how ? to flash it plz
  20. #12060
    Nov 2020
    Quote Originally Posted by ali0 View Post
    flyfvdi vcds hex-v2 use stm32f405 and stm32f429 and viiplusloader
