Page 807 of 854 FirstFirst ... 307707757797802803804805806807808809810811812817 ... LastLast
Results 12,091 to 12,105 of 12803
  1. #12091
    Dec 2020
    VCDS 23.3.1 does not require a firmware upgrade (it will work with CB:4631) so VIIPlus loader for 23.3 will work but it will not be able to decrypt UDS messages.
    In your scan log you will see something like this:
    13697024 - Component Protection
    U1100 00 [009] - No Basic Setting
    [Tip-TNF 231499]
    instead of:
    [Komponentenschutz keine oder falsche Grundeinstellung bzw. Adaption]
    Confirmed - Tested Since Memory Clear
    VCDS will of course know that you are missing the decrypt key and might do other strange things.
    Every version of VCDS is using a different key that only a genuine interface can calculate.
    The calculation is done by sending a MAC message to the external crypto chip and without this key it will be "impossible" to calc this response.
    The response will have to be ripped from a genuine interface and hard coded into the VIIPlus firmware.
    This is why VIIPlus loader need an update to fully work with VCDS 23.3.1
    For VCDS 23.3.1 ENG the Challenge is:
    0xFD, 0x9D, 0x98, 0x3B, 0xDF, 0x6B, 0x0E, 0x01, 0x01, 0x10, 0xEC, 0x79, 0x80, 0xB0, 0xEC, 0x76, 0xCE, 0x04, 0xC0, 0x01, 0xD8, 0x09, 0x85, 0x02, 0x09, 0x9E, 0x0E, 0x1E, 0x9D, 0x3C, 0x76, 0x27
    and the response is:
    0xED, 0x57, 0xB1, 0x21, 0xBC, 0xB0, 0x04, 0x72, 0xDE, 0x15, 0x02, 0xF3, 0x43, 0x79, 0x97, 0x10, 0x00, 0xCE, 0xE2, 0x6D, 0x30, 0x49, 0x0E, 0x1D, 0x46, 0xFD, 0xD6, 0xB9, 0xA9, 0x14, 0x3B, 0x87
  2. The Following 14 Users Say Thank You to badrax For This Useful Post:
    bg17aw (31st May, 2023), dmerkovic (15th May, 2024), drdahmani2 (6th May, 2023), DreamDancer (18th July, 2023), Fabio89 (28th August, 2023), kaalis (6th May, 2023), lsdlsd88 (2nd May, 2025), miouser (6th May, 2023), Qwarz (14th September, 2024), silv3r (30th May, 2023), StanNB (5th May, 2023), ulises11 (6th May, 2023), wiechec (5th May, 2023)
  3. #12092
    Apr 2022
    ok. Thanks. I will put back 23.3.0.
  4. #12093
    Jan 2021
    Germany, Baltic Sea
    Quote Originally Posted by badrax View Post
    Ask the Professional 👍
    Btw: It seems that there are issues with Security Access in the EN VCDS since 22.9.0 up to 23.3.1. Its recommend to use the 32bit Version of VCDS on 64bit Windows, always with loader.
  5. #12094
    Sep 2016
    im about to do it is there any soft to flash it ? always got eeror when i try to connect usb can u send file to other stm 415 ? to update itWhatsApp Image 2023-05-06 at 01.02.37.jpgWhatsApp Image 2023-05-06 at 01.02.38.jpg
  6. #12095
    Nov 2022
    Anyone have the 405 and 415 update files to program with ST-Link to work with 23.3?
  7. #12096
    Nov 2020
    FLY will release new viiplusloader and new firmware to support VCDS V23.3.1 soon
  8. #12097
    Nov 2020
    [Tip-TNF 231499]
    instead of:
    why you do not crack ross-tech vcds hex-v2 ?
  9. #12098
    Jul 2018
    Quote Originally Posted by heshamzn View Post
    it's difficult (only few knows )
    because the debug interface (which you are connecting your pins) is diasabled by the firmware (set to RDP2_)
  10. #12099
    Nov 2022
    Asked same question
  11. #12100
    Nov 2020
    You should crack ross-tech vcds hex-v2 firmware and software, you're the one to be admired
  12. #12101
    someone already success try to unlock SFD on MQB2020 with hex-v2 (viiplusloader)?
    i found that sfd tokens can be generated on vaglogins.com up to 5 dollars
  13. #12102
    Dec 2020
    Quote Originally Posted by flyfvdi View Post
    What makes you think I have not already done so
  14. #12103
    Nov 2020
    yes, you can not crack ross-tech vcds hex-v2, the whole world knows it. because you can not directly use the original ross-tech vcds hex-v2 firmware and vcds software.
    can you prove it to us ?
    you are fluky only.
    your technique is just so so.
    everyone know chinese stm 415 vcds hex-v2 is crap.
  15. #12104
    Dec 2020
    Not the whole world but most of the world
    How do you know that you can't use the firmware directly?
    Do you have it and are unable to use it?
  16. The Following 3 Users Say Thank You to badrax For This Useful Post:
    drdahmani2 (8th May, 2023), liviudiaconu (9th May, 2023), StanNB (8th May, 2023)
  17. #12105
    Jan 2021
    Germany, Baltic Sea
    you are fluky only.
    Sorry fly, but you know nothing! Last year we had contact by team viewer in case of a problem with VII Plus and VCDS. And your solution? There is no! You don’t have the skills to engineer anything! Who build’s the Loader? Is it you? Ask your russian friends!
    People with knowledge of RT firmware (they are rare) knows that the 415 is the best PCB for the VCDS. And yes, my 415 runs with 1:1 RT FW, without any loader and without any issues! VII Plus is crap!!
    So pls stop talking sht about people who have much more skill’s then u have!
  18. The Following User Says Thank You to StanNB For This Useful Post:
    drdahmani2 (9th May, 2023)
