Page 815 of 854 FirstFirst ... 315715765805810811812813814815816817818819820825 ... LastLast
Results 12,211 to 12,225 of 12803
  1. #12211
    Feb 2020
    Quote Originally Posted by flyfvdi View Post
    welcome badrax continue to crack fly vcds hex-v2, use fly vcds hex-v2 to earn little small money.
    FLY cracked RT's V2 as 1:1 pcb designed, and using VCD$ software, the name also the same HEX V2, cracked original, then you said it's your own FW, not cracked as RT's FW.
    This words should be for yourself "welcome flyfvdi continue to crack RT vcds hex-v2, use RT vcds hex-v2 to earn little small money." Lof.....
  2. #12212
    Nov 2020
    Quote Originally Posted by cardou View Post
    IC is stm32f429
    encryption chip is lkt4106
    canbus chip is sit1050t
    K-line chip is dp9241
    power supply chip is XL4001E1
    1:1 ?
    no
    not RT PCB , not RT firmware,compatible with RT vcds software by viiplusloader.
    fly engineers don't have the ability to crack RT hex-v2 firmware.
    If you can crack RT hex-v2 firmware, please send fly a free copy.
    Maybe badrax can crack RT hex-v2 firmware? be free for everyone ?
    badrax, since you like free, please make your development project code free.
  3. The Following User Says Thank You to flyfvdi For This Useful Post:
    seal777 (30th May, 2023)
  4. #12213
    Top Poster MrDerv's Avatar
    Mar 2023
    UK
    can do Security Access now,update to the newest
    No it can't.
    STM32F429 will do security access on 22.10, not newer 23.3.
    Jesus, so many complaints of no security access, get it sorted instead of saying it can
  5. The Following User Says Thank You to MrDerv For This Useful Post:
    ganobi (30th May, 2023)
  6. #12214
    Nov 2020
    Quote Originally Posted by MrDerv View Post
    No it can't.
    22.10 can do security access. why 23.3.1 can not? stop your lies and slurs.
    MrDerv, i had your stm32f415 hex-v2 vcds v22.10 in my hand,already tested, it is using fly vcds hex-v2 firmware. but because without viiplusloader , too many bugs.
    fly will modify the fly vcds hex-v2 firmware. you can't use it to manufacture 415 hex-v2 again.
    if you want to do security access, must have loader to do the RSA algorithm to calculate the security access key.
    no loader , no security access.
    MrDerv, only you slander here. others already contactd the technical support engineers.
  7. #12215
    Jan 2021
    Germany, Baltic Sea
    Oh really?? 🤣🤣
    4.15 security access without any loader.
    There is so much you don’t know!
  8. #12216
    Nov 2020
    Quote Originally Posted by StanNB View Post
    Oh really?? 藍藍
  9. #12217
    Mar 2023
    UK
    Firstly, You are the one lying here (its clear that everyone else feels the same way). The moment you are criticised, you go on the offensive to protect a product that clearly needs fixing to work with newer versions. You insinuate you have a cable i have supposedly supplied?? Couldn't be possible since i neither manufacture, supply, or sell these. All i own is an F429 i bought from Aliexpress, which as it turns out, CAN NOT DO SECURITY ACCESS with VCDS 23.3 and your VII Loader on my 2017 Passat. Once again, you try to attempt the old switcheroo in order to make it look like I'M the one who is the bad guy here. I AM A USER/CUSTOMER, NOT A COMPETITOR.
    Security access works fine on 22.10, so i'll stick with that.
    READ THE POSTS from everyone else here which say that security access does not work on 23.3 with vii loader. Fix it and stop claiming it works!!!! If you can't fix it, then say so, and tell people which version security access DOES work with.
  10. The Following User Says Thank You to MrDerv For This Useful Post:
    kaalis (31st May, 2023)
  11. #12218
    Nov 2020
    The competitors always slander here. the real customers always contact the technical support engineers.
  12. #12219
    Nov 2020
    crap vcds v22.10 stm32f415 hex-v2 is using fly vcds hex-v2 firmware.
    you are using fly vcds hex-v2 firmware,and you are calling it bad. absurd theory.
    why not develop the firmware by yourself. why to use fly vcds hex-v2 firmware?
  13. #12220
    Mar 2023
    UK
    I'll tell you what, AS A CUSTOMER, i will not recommend your product to anyone. Furthermore, your attitude towards customers stinks. Have you heard the phrase "look after your customers, and they'll look after you"?
    Me and many others have told you whats wrong. Stop trying to flip it back at me.
  14. #12221
    Nov 2020
    you are overreaching. your vcds v22.10 stm32f415 hex-v2 is so crap, please go to concern it. fly vcds hex-v2 does not need your slander.
    these are crap vcds v22.10 stm32f415 hex-v2 pictures.
    these are crap vcds v22.10 stm32f415 hex-v2 are using fly vcds hex-v2 firmware.
  15. #12222
    Jan 2021
    Germany, Baltic Sea
    That’s a lie. 1:1 encryption chip dump. I know, you can’t believe it cause your engineers from Russia are to stupid for this. You have to emulate the encryption. Thats from yesterday!
    Another lie. My 415 use 1:1 RT FW. It was done week’s before your VII Plus crap came out. I don’t need your crap!
  16. #12223
    Nov 2020
    First we need to stop these people from hacking and using our firmware.
    Second we continue to do a good job of our equipment fly vcds hex-v2.
    these vcds v22.10 stm32f415 hex-v2 factory boys do not hurry.
  17. #12224
    Nov 2020
    StanNB, please forget and stop talking about fly vcds hex-v2, thank you.
    Ok, who already used fly vcds hex-v2 firmware to manufacture vcds v22.10 stm32f415 hex-v2 , whose entire family will die.
  18. #12225
    Mar 2023
    UK
    ONCE AGAIN, i own a STM32F429 Hex-V2.
    I have no idea why you associate me with the 415???
    you are getting desperate, and will not listen.
    I'm done explaining.
