No, just No. Stop trying to put words in my mouth or accuse me.
Also, i don't appreciate the threatening private message you just sent me. Sums you up really. Reported to the forum admins.
Centautian (6th June, 2023), StanNB (31st May, 2023)
Hello everyone, I am new here. I have seen people posting about using VCDS cable to use VAG K+CAN commander. I have been trying since this morning but now luck.
Is this because I'm using Windows 10? does this VAG K+CAN V3.6 commander software only work on windows xp?
I'm getting following error when I run the application VAG K+CAN V3.6.
First I get "open port failted", if press okay I get "Cannot Find Device" and the programme shut it self.
is this because of the VSDC cable or something else
I also could see "SCOMM SET' button in the application. my VCP is set to COM 2
If you have any suggestion, that would be really helpful.
Thank you in advance.
The difference between the three vcds hex-v2
1.vcds hex-v2 ATMEGA162 just can do 1996-2015 old cars,without loader,can not update freely, support one language, put vcds hex-v1 PCB board into vcds hex-v2 shell.
2.vcds hex-v2 STM32f415 can not update freely, without loader, can not do Security Access, support one language.
3.flyfvdi vcds hex-v2 viiplusloader stm32f429, update freely, with loader, can do Security Access, multi-language support.
now v22.10 vcds stm415 hex-v2 used badrax fly vcds hex-v2 firmware, without loader, too many bugs.
The genuine vcds hex-v1
Funny, Note 3 above..... I'm using STM32F429, and CAN NOT do security access in 23.3 with or without viiplusloader. Thats why i have to use 22.10 instead. It simply does not do security access with 23.3.
End of story. I'm done explaining.
Proof if needed this is whats onboard mine:
In fact you are manufacturing and selling v22.10 stm415 hex-v2 with badrax fly vcds hex-v2 firmware. a competitive game between your team and fly.
The result of badrax's hard work for 3 years
Enough ...............
Centautian (6th June, 2023), drdahmani2 (2nd June, 2023), Fabio89 (6th June, 2023), flyfvdi (1st June, 2023), Johnner (4th June, 2023), lemrid (2nd June, 2023), miouser (1st June, 2023), MrDerv (1st June, 2023), mrle9 (4th August, 2023), networkers (1st June, 2023), paro44 (1st June, 2023), StanNB (1st June, 2023), vtuz (18th July, 2023)
Lets try again ... any sh1t and it's gone .....................
OK, who dares to open a new post.?
Hi everyone,
Has anyone managed to run a VDCS ARM on MacBooks M1/M2 with the Kolimer loader? As I just get an error “Hooking (3)” and it closes. I couldn’t find any information on it.
I used Parallels with Windows 11 installed 64bit. The VDCS does run without a loader I tested it on a separate installation, but requires license ofc.
Thanks in advance.
