Page 820 of 854 FirstFirst ... 320720770810815816817818819820821822823824825830 ... LastLast
Results 12,286 to 12,300 of 12803
  1. #12286
    Sep 2023
    Does anyone have download link for VCDS 23.3.0 version? I can't find it anywhere and it seems that's the last version working properly with the 08.023.02 VIIplus loader.
    edit: found it here nevermind mega(dot)nz/folder/FwEBCSSL#rhBFzLZFQGF2L9yLvRVi6A/folder/oxdChBpL
  2. The Following User Says Thank You to kalisz For This Useful Post:
    Saab A Dalys LT (1st October, 2023)
  3. #12287
    May 2023
    Dear friends,
    I tried viiplus loader v 08.23.07 by fly for vcds 23.3.1 latest one worked and secury code works for some modules not for all at least for me .
    loader upgraded hex v2 to latest fw v01.10.02 and now when i use vcds 21.9 it scans but adaptations is not readable and is greyout for all modules.
    I try every vii pluss loader but fw will NOT downgrade to previous versions.
    How can i downgrade hex v2 frimware to lower versions that i had and worked well with 21.9 ?
    Thanks in advance.
  4. #12288
    Sep 2012
    Looks like loader archive file broken, maybe you managed to find working file
  5. #12289
    Smart66's Avatar
    Dec 2020
    Firmware can't be downgraded using VIIPlusLoader Many members have same issue. Anyonee who succeeded to solve this issue?
  6. The Following User Says Thank You to Smart66 For This Useful Post:
    APNT1984 (1st October, 2023)
  7. #12290
    Jan 2021
    Germany, Baltic Sea
    If you read this Thread carefully you should know that downgrade isn’t possible anymore.
    The solution is: don’t update the device. It’s not necessary to use the latest version.
  8. The Following User Says Thank You to StanNB For This Useful Post:
    amstel7 (10th November, 2023)
  9. #12291
    Smart66's Avatar
    Dec 2020
    I was curious to try the latest version which was offered to me automatically so VCDS cable got bricked after updating firmware
  10. #12292
    Aug 2020
    Quote Originally Posted by Smart66 View Post
    Curiosity killed the vci. What is wrong with you? You knew already before you messed up
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  11. #12293
    Jan 2021
    Germany, Baltic Sea
    That’s the problem this times: People always want the latest version. But 95% don’t need it.
    Update VCDS only if you need it. If you don’t want to code 2022+ MQB cars there is no need to update.
  12. #12294
    Smart66's Avatar
    Dec 2020
    After I started VIIPlusLoader then firmware update started automatically so I couldn't skip it Many members had the same issue, firmware update can't be aborted
  13. The Following 3 Users Say Thank You to Smart66 For This Useful Post:
    amstel7 (10th November, 2023), APNT1984 (1st October, 2023)
  14. #12295
    Aug 2020
    Quote Originally Posted by StanNB View Post
    The real problem is how fly was treated here and now you all are feeling the consequences.
  15. #12296
    Smart66's Avatar
    Dec 2020
    Same situation is on other forums too. Many VCDS cables got bricked because of updating to the latest firmware
  16. The Following User Says Thank You to Smart66 For This Useful Post:
  17. #12297
    Jan 2021
    Germany, Baltic Sea
    He did all to get banned. But who is all ?? I don’t use VII Plus and don’t care about that shit.
  18. #12298
    Aug 2020
    Same situation is on other forums too. Many VCDS cable got bricked because of updating to the latest firmware
    Thats because your all using the same loader!
  19. #12299
    Smart66's Avatar
    Dec 2020
    Only latest versions of VIIPlusLoader will brick VCDS cable. It works fine with other older versions!
  20. The Following User Says Thank You to Smart66 For This Useful Post:
  21. #12300
    Aug 2020
    Only latest versions of VIIPlusLoader will brick VCDS cable. It work fine with other older versions!
    But you already knew this and yet you still bricked your vci...
