Page 825 of 854 FirstFirst ... 325725775815820821822823824825826827828829830835 ... LastLast
Results 12,361 to 12,375 of 12803
  1. #12361
    Dec 2020
    Quote Originally Posted by miouser View Post
    badrax
    I wrote to you that I have such a cable, but unfortunately you didn’t read mine PNs
    Sorry but I can't remember that.
    Perhaps you can share the PCB layout here then?
  2. #12362
    Dec 2019
    Romania
    Waiting for 23.7 release, now it's just Beta.
  3. #12363
    skla66 Interface look like fly v2
  4. The Following User Says Thank You to miouser For This Useful Post:
    amstel7 (10th November, 2023)
  5. #12364
    Smart66's Avatar
    Dec 2020
    It really looks like fly cable. Can you post more images in HD resolution? I can't see many details on these small pictures
  6. #12365
    @Smart66
    i have changed the pics.
    look again.
  7. The Following User Says Thank You to miouser For This Useful Post:
    Smart66 (15th October, 2023)
  8. #12366
    Smart66's Avatar
    Dec 2020
    That's what I was looking for Now, all is much clearer
  9. #12367
    Top Poster MrDerv's Avatar
    Mar 2023
    UK
    Those internals are the same as the 429 i have. Thats definitely a clone, so will need the loader if you want to do security access.
    As its a 429, its also rather expensive compared to the 429's on Aliexpress
  10. #12368
    Aug 2023
    Hello, Does anyone have the VCDS 12.12 version? As I found a VAG12.12 cable laying around and I wanna see if it works. Even with version 15.11 doesn't find the interface Thanks in advance!
  11. #12369
    Aug 2020
    Quote Originally Posted by Mangaia View Post
    Look on ross-tech website
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  12. #12370
    Dec 2014
    PL
    Here you go.
    It works with the old interface (12.12.0) without a 'loader'.
  13. #12371
    Aug 2023
    Quote Originally Posted by Mario6 View Post
    Here you go.
    For some reason I get this issue with every version https://imgur.com/a/LGRgiTe
  14. #12372
    Dec 2014
    PL
    In my case it looks like this, without connection to the car.
    Check how your interface reports in the device manager.
    https://www.digital-kaos.co.uk/forum...ht=vcds+repair
    You can also try SW VCD$ 12.12.3EN.
  15. #12373
    Dec 2022
    Could someone help a little, or does anyone know about:
    I have on my laptop windows 7 and 10. In windows 7 i have vcds 20.4.1 with loader (atmega cable). Now i bought stm32f429 cable and vcds is installed to windows 10 with loader.
    Is there any worries? Seller said need to uninstall v1 loader because vcds can see that and block my pc? They are not in same drive.
    Seems stm32f429 cable is disconnecting some times while im at some model like engine and doing basic settings, is that because i use new software? Should i use older software? Because my atmega works ALOT better...
  16. #12374
    Aug 2023
    I just tested it, however I got the same error. I downloaded the 12.12.3 installer and installed it. In the Device Manager it is recognised as "Ross-Tech Direct USB Interface".
    Idk if you have any other ideas, if not I'll have to mark this cable as toast
  17. #12375
    @Mangaia
    search for VCDSLoader v9.2 from Kolimer on this thread!
    use VAGCOM_EEWriteLang.exe to flash FW and then you can use newer vcds versions over VCDSLoader.exe
