Page 82 of 854 FirstFirst ... 3272777879808182838485868792132182582 ... LastLast
Results 1,216 to 1,230 of 12803
  1. #1216
    Quote Originally Posted by rancoxxx View Post
    Thx but I need somethin that will work with cabel 10.6.0 (GERMAN) china interface thx for replay
    If it was a german 10.6 the seller should have it, maybe ask him. If it was just a 10.6 cable, than the german vcds will not work as tk500 already said, since it has not the right dump in it.
  2. #1217
    Dec 2010
    Quote Originally Posted by kodo28 View Post
    Have the same problem to... 10.6.2 china cable...
    Did u read the thread? It's already posted.
    Found the solution for my problem, it's a software problem, here is the right setup for 10.6.2:
    http://rapidshare.com/files/44543038...-Installer.exe
    Source:
    http://translate.google.com/translat...he-9783-4.html
  3. #1218
    Quote Originally Posted by paro44 View Post
    Maybe vcds 9.08? ;-)
    Iirc 9.12beta should work, too.
    Obviously the 908 version is correct, but I meant that version for the 908.
    There are several versions called 908, but not all are valid.
    Regards.
  4. #1219
    Thumbs up
    thx for replay, nice information
  5. #1220
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by bibkare View Post
    I have 908.1 MFT if it is any good to you
    Not sure.
    No conribution till now,no introduce himself...i dont think...
  6. #1221
    Hi there.
    I purchased a cheap chinese vcds clone from a site a while back. Ive managed to use the lite vcds with a loader.
    After reading this thread, I am more confused than ever about turning it into a 'real' cable.. in FTProg, it says my device is blank..
    The chips on it are as follows:
    FT232BM (top)
    LM393 9AM AXG1 g4 (bottom led side)
    What do I need to do?
  7. #1222
    Quote Originally Posted by esrodi View Post
    Regards.
    If you use good dump, you can use original version. No need for patch, loader, cr*ck ("installer v100") or something like that. Just google for it or use filecrop. There is a package with 908/912beta, i'm sure it will work.
  8. #1223
    Romania
    paro44 share a good dump
    tanks
  9. #1224
    DK Veteran cocutanu's Avatar
    Jun 2009
    Quote Originally Posted by NZHawk View Post
    Hi there.
    FT232BM (top)
    It's nothing you can do my friend. The REAL cable is this one which you have it now...don't expect to make this one working with newer versions of VCDS.
  10. #1225
    Quote Originally Posted by dariusddj View Post
    tanks
    It's all in this thread, read it carefully from the beginning and you will find it.
  11. #1226
    Quote Originally Posted by cocutanu View Post
    Ah sweet, Thanks for clearing that up! The Lite VCDS is pretty good anyway..
  12. #1227
    DK Veteran bibkare's Avatar
    B & H
    Regards.
    have you tried the one i posted
  13. #1228
    That's what I wanted to know, thanks.
    I have not tested yet for lack of time.
    Regards.
  14. #1229
    B & H
    Regards.
    try it with and without crack, it should be OK either way
  15. #1230
    iS THER A WORKING 912 DUMP?
