Atmega162 vcds hex-v2 Kolimer162VIILoader V7.23.02 ,support vcds v23.11.0 software,support multi-languages.
@sanshao
what idiot came up with the idea to write on hex-can interface hex-v2?![]()
Hi, i need the soonest a clone hex cable that works. Anyone got some reliable source to buy from? Hit me in pm. TIA
I bought an Aliexpress Cable for ~70€ and it got the STM32F429 chipset inside of it and it says H11-002336 on the label. It came with the VIIPlusLoader 08.023.07 via download link.
I read that the guy making this loader added some downgrade protection on newer loader versions, so I wanted to use 08.023.02 of that loader.
I installed the loader and the German version of VCDS 22.10.0 and it says the following:
1) First of all, why five firmwares?Code:SW Version: V08.023.02 FW version: V01.08.04 Release date: 09/03/2023 Serial number: 1N07... Adapter status: user FW version No 1: V01.10.02 (needs update) FW version No 2: V01.00.05 (newest) FW version No 3: V01.00.02 (newest) FW version No 4: ********** (needs update)
2) When I try to update, it fails - no idea why.
3) Does this come pre-flashed with a newer loader firmware and I'm forced to use the newer loader?
Update process goes to 5% then shows me the version as "V01.10.02" and then fails.
Thank you
EDIT: Seems it was flashed with .07 and it worked fine without doing an update with that loader version.
Hello, i have an updatable v2 cable with badrax loader and can't enter on adaptation on any module. Only coding and security access is available, the others are disabled. I'm using BadraxVIILoader_V9.23.09.001_2303(EST) for 22.3 EST, got the same if i use BadraxVIILoader_V9.23.09.001_2303_R1(ENG) with English 23.3. I have another updatable cable with viiplusloader and it shows the same. Is that normal? https://imgur.com/a/wUipstg
I read a lot of posts and only I found people saying on 23.3 you can't do security access
I think i have this same issue on the viiplusloader cable. I think i installed 08.023.07 months ago and then downgrade to 08.22.07 which works good for me but FW shows 01.10.02 so it doesn't downgrade? Is that the problem? https://imgur.com/a/b5LlMHe
V23.11.0 VCDS V08.023.11 VIIPlusLoader Mega link:
https://mega.nz/folder/7N0jHLTI#eRoLKAjkNSzGQBxPqHYuLw
Hi i need help to resolve problem witch VCDS 17.8 (1.95). In test (in options) vcds is working correctly, but problem is when i try connect for example to engine and another modules in car. During communication i see comunicate: "failure to communicate [0]", and i can't diagnose.
I received a smt32F405 cable, VIIplus 08.023.02 running VCDS 23.3, finds all modules of a Polo AW plus the security works. But when connecting to a polo 6R it does not find the ABS module strange enough. I have a VCDS 15.7 cable which works but this doesnt run on windows 10 (reason i bought the new cable).
How to overcome the ABS module issue with the new cable
C03F762F-D3CD-40A5-AFD3-96A7C9CBC802.jpg0A1D6BE4-EB5D-43B7-80B4-98E291B76135.jpg39CEB36A-7430-4D0E-9A5F-CDBAFD4E6328.jpghello, i have vcds clone hw 46. fw 1.96 atmega162
my cable corruptet bootloader, i use teensy 2.0 make isp avrdude. fuse read, check mcu signature invalid?
i try no success?have soluction?
Use teensy2.0 (arduino isp)from ide. 37CF7BD5-620E-4D90-9519-6BBBEC777E87.jpg
