Page 837 of 854 FirstFirst ... 337737787827832833834835836837838839840841842847 ... LastLast
Results 12,541 to 12,555 of 12803
  1. #12541
    Oct 2017
    Germany
    Quote Originally Posted by VMECU82 View Post
    hello, i have vcds clone hw 46. fw 1.96 atmega162
    my cable corruptet bootloader, i use teensy 2.0 make isp avrdude. fuse read, check mcu signature invalid?
    i try no success?have soluction?
    Try a cheap USBASP AVR Programmer and avrdude as described in _README.pdf
  2. #12542
    Dec 2021
    Ok try whit arduino to avr isp and work, problem is my lock fuse(LB 0xC0)
  3. #12543
    Dec 2021
    Arduino work same i check online, teensy no, successfully vcds work again thanks
  4. #12544
    Jan 2024
    Hello. Does this version of vcds hex-v2 update freely
  5. #12545
    @Calo
    must be. this is one of first updatable "Fly" cable.
    use VIIPlusLoader
  6. #12546
    Jun 2022
    @badrax
    I have gotten a used HEX V2 orig . it has 3 registered vins already , is it possible i can get this cable to work with a vii loader ?
  7. #12547
    Nov 2023
    FLY clone vcds hex-v2 can not do securtiy access
  8. #12548
    Top Poster MrDerv's Avatar
    Mar 2023
    UK
    Quote Originally Posted by garyr View Post
    @badrax
    If it is a legitimate Ross-Tech Hex V2, then no.
    Vii loader only works with clone adapters.
    You'll need to purchase additional VINs from RossTech if you want to use the legitimate device.
  9. #12549
    Jan 2024
    Default Unlocking Hex-V2
    Hello community, I'm new to this so easy with the flames . I've got a Hex-V2 and belive it is blocked. I tried running it with VIIPlusLoader and got ""Illegal device. The device is locked"" . In more details of the Loader it says "Device read data failed". I've read some of the related post from experience members and gathered that the version or IC of my interface matters. So I've taken some initiative and got some photos of the front and back of my pcb. Really I'm insterested in learning about how to identify interface versions and which goes with what softwares (loaders, VCDS version, etc) and how to unlock it so I can use by device again . BTW, I using the loader provided by Sanshao: V23.11.0 VCDS V08.023.11 VIIPlusLoader Mega link
  10. #12550
    @getin
    you paid 30usd and it was sell as not updatable with 20.4.1
    why to hell you try to use any loader?!
    use eng 20.4.1 and forgot any loaders!
  11. The Following 2 Users Say Thank You to miouser For This Useful Post:
    drdahmani2 (10th January, 2024)
  12. #12551
    Nov 2023
    if do not have loader, can not do Security Access
  13. #12552
    Nov 2023
    Cracked VIIPlusLoader for B03-V2 mega link:
    https://mega.nz/file/67x0xJ6L#_R4G6p...d9gkW4TZmBmFa0
  14. The Following 3 Users Say Thank You to sanshao For This Useful Post:
    dmerkovic (24th July, 2024), miouser (9th January, 2024), ZIPPO4594 (9th January, 2024)
  15. #12553
    Dec 2020
    @badrax
    Could you share a picture of the PCB to verify that it is in fact a genuine cable?
    You can contact Ross-Tech support and ask for an 10-VIN upgrade. If you are the owner then this should not cost to much but if you are not then you will have to pay for what they call "take ownership"
    If for some reason this is masked as stolen then you wone be able to upgrade it.
    But you can use it as is for reading out faults code and do logging. No need to VIN lock for such.
    Perhaps you can give me a copy of you lic?
  16. The Following User Says Thank You to badrax For This Useful Post:
  17. #12554
    Dec 2020
    Quote Originally Posted by getin View Post
    Connect cable to PC and start VCDS and go to Options->Test
    You should see a CB version number there?
    Does it say CB: 4508?
  18. The Following User Says Thank You to badrax For This Useful Post:
  19. #12555
    Quote Originally Posted by sanshao View Post
    from where are you got this?
    will work with this aliexpress.com/item/1005005372828717.html?
    have someone already tested? is safe to use?
    questions, questions and more questions )))
