Page 844 of 854 FirstFirst ... 344744794834839840841842843844845846847848849 ... LastLast
Results 12,646 to 12,660 of 12803
  1. #12646
    May 2023
    Nofear0044 wrote:
    Hello UK Team
    I PLEASE need your help I don't know what to do!!!!
    I have made no progress in the German-language forums. It's about my son's speedometer from the Audi A3 8L Marelli. I can't get the lockout code (LOGIN) from the VAG Com 1.4. . . .
    Audi A3 8L (~ VW Golf Mk4) probably has immo-3 in instrument cluster. Cluster swapping need PIN code for old and new cluster. http://wiki.ross-tech.com/wiki/index...ument_Cluster)
    PINs can not be extracted with VagCom/VCDS. Other tools such as VW Flash-reader tool or VagTacho might be able to do it using the VagCom cable.
    Repairing the old instrument cluster with parts from the new one may be another option.
  2. #12647
    Viiplusloader v08.024.03
    https://mega.nz/folder/CIk2UaLI#ORjm.../file/WFdyVZhL
    Sent from my SM-A546B using Tapatalk
  3. The Following 5 Users Say Thank You to mrben For This Useful Post:
    AYD (26th March, 2024), miouser (25th March, 2024), seal777 (31st March, 2024), silv3r (7th April, 2024), ZIPPO4594 (26th March, 2024)
  4. #12648
    Mar 2024
    Hy, I have Hex-v2 (atmega) cable displaying revoked, I think i used it online. Now it says ok for all tests but does not respond to scan
  5. #12649
    @doc9999
    reinstali sw and reflash with VAGCOM_EEWriteLang.exe.
    you can find all in this thread. use search!
  6. #12650
    Jan 2012
    Hi. Someone have the schematic for vcds with stm32f405.
  7. #12651
    Top Poster MaiiQ's Avatar
    Aug 2013
    Im using loader version v08.024.01 on AliExpress clones stm of 70-80€. Is possible to use newer version of loader or it will lock device if it doesn't have got lk chip?
  8. #12652
    Jul 2018
    if you are using v08.024.01 it means you have the LK chip and you could proceed
  9. #12653
    PelsonBMW's Avatar
    May 2020
    Eu
    wait wait wait... loader 9.2 works with all versions , i have Hex-V2 Dual-K&Can <-> USB VAG/ISO Interface , soo... does it have to update somehow or what ? Just installed newest version of VCDS and well.. program starts, in options the TEST says OK , so do i have to update cable or something ?
  10. #12654
    Mar 2016
    I have a clone cable with ATMega162. It suddenly stopped communicating on usb. The FTDI FT232R IC died (went into short and got very hot) and I took one FT232 off of a serial to USB adapter and soldered it to my HEX cable.
    Now if I plug it in, windows thinks its the serial adapter of course.
    I only have to reprogram the FTDI chip to get it working again, right? Which tutorial to follow? Thanks
    Update: Pretty much seems that the chip is locked. MProg says programmed, but everything stays the same.
  11. #12655
    Jul 2018
    Quote Originally Posted by SpeedTune View Post
    Yes, fake FTDI chips don't allow changing the VID & PID.
  12. #12656
    Mar 2016
    BTW I already ordered a 'real' HEX-V2 clone with ARM processor.
    Is the logging frequency higher compared to the ATMega?
  13. #12657
    Apr 2009
    macedonia
    Ho to flash 1.93 please i have can i programing atmega 162, with CH341A programmer ?
    ming this chip 162 with CH341A programmer
  14. #12658
    Apr 2009
    macedonia
    Can i programing atmega 162 with CH341A programmer or have some way to flash with usb port ? i need to flash 1.93 have nice day
  15. #12659
    Jul 2018
    Yes, the sampling rate is much higher with the ARM interface, but it also depends on the ECU you're connecting to.
  16. #12660
    Aug 2018
    France
    Quote Originally Posted by axlrose View Post
    hi,
    you need USBAsp programmer and Kolimer’s package (you’ll find it in this thread)
    why use 1.93 fw ? Last is 1.96
