Page 845 of 854 FirstFirst ... 345745795835840841842843844845846847848849850 ... LastLast
Results 12,661 to 12,675 of 12803
  1. #12661
    Apr 2009
    macedonia
    i have vcds 23.3 with firmware 19.3 works perfect after update 1.96 give me error to all command settings i no have luck to find 23.11 cracked version for chinese vag
    because is not original i like only to back to 1.93 tnx for answer i love this site is amazing
  2. #12662
    @axlrose
    you are doing nonsense!
    and you're climbing in the wrong direction.
    FW of hex-usb-can is since many years the same (min. 2017Y). 1.96 - VCDS 18.*.* and maybe any early
    search for VCDSLoader_v9.2 package and use tools from Kolimer. if you will not be happy put you interface in the trash and buy new one.
  3. The Following User Says Thank You to miouser For This Useful Post:
    drdahmani2 (11th April, 2024)
  4. #12663
    VIIPLUSLOADER 08.024.04 https://mega.nz/folder/CIk2UaLI#ORjm.../file/HZFVRTZR
    Sent from my SM-A546B using Tapatalk
  5. The Following 6 Users Say Thank You to mrben For This Useful Post:
    miouser (16th April, 2024), Revtor (21st April, 2024), seal777 (20th April, 2024), Tomas003 (20th April, 2024), Za589 (25th April, 2024), ZIPPO4594 (19th April, 2024)
  6. #12664
    Jul 2018
    Does Anyone tried this?
    There is connector "BT" does it stands for Bluetooth?
    This is my friend interface bought recently from Aliexpress
    what is strange is the seller description and picture is for STM32F429 VIIPLUS Loader, But the real PCB was STM32F415 and using a new unknown V2helper1073.exe Loader which could make update the interface in the future
  7. #12665
    Nov 2023
    Quote Originally Posted by drdahmani2 View Post
    You've been cheated, VIIPLusLoader is VIIPLusLoader, VIIPLusLoader is not V2helper1073.
    different two company loader.
  8. #12666
    Nov 2023
    FLY VCDS Hex-V2 STM32F429VET6 + LKT4106 + VIIPLusLoader V08.024.04,Support SFD
  9. #12667
    Jul 2018
    I care only for possible Bluetooth extension module
    I do not care about the loader
    Just in case someone could or have found some information regarding the BT connector?
  10. #12668
    Top Poster MrDerv's Avatar
    Mar 2023
    UK
    No real HexV2 has Bluetooth. Only VCDS interface to operate without a wire is the Hex-Net, of which, there are no clones. VCDS also does not have a bluetooth option within the software, so ignore the BT connection on the board.
    If you've been sent a 415 and it was advertised as a 429, open a return with the seller.
  11. #12669
    Jul 2018
    tracing pinout of the ''BT'' connector
  12. The Following User Says Thank You to drdahmani2 For This Useful Post:
    tilki42 (19th April, 2024)
  13. #12670
    Jul 2018
    HEX-NET FCC id and probable wifi module according to FCC id
  14. #12671
    Mar 2023
    UK
    All very well and good, but VCDS doesn't work via bluetooth. Only USB for HexV2/HexNet or Wifi only for HexNet.
    Adding a bluetooth module to a HexV2 clone will not magically make it wireless, because the Software won't connect to it.
  15. #12672
    Dec 2020
    I think that drdahmani2 is playing with the thought of converting a Hex-V2 to use BT.
    VCDS communicates with the Hex-V2 using USB but the code itself is not USB related.
    When VCDS wants to send data to the cable it first opens a handle to it using create file (after searching for the correct HID device)
    After this then the windows API call WriteFile is used and every packet sent is 0x40 bytes.
    Using USB Analyzer we can see these packets but they are of course encrypted so will not make too much sense.
    At the other end then the Hex-V2 firmware reads these 0x40 bytes from the USB stack and handles the command.
    Now what if you could make a device that connects to the PC and uses the same VID and PID as the Hex-V2 uses.
    This device will read these 0x40 bytes packets and send them wireless to some other device connected to the Hex-V2’s USB port for so to be converted to a USB packet and sent to the STM.
    This should in theory work right?
    Now if you have access to the STM’s firmware you could rewrite the code to not use the USB stack itself but read the data from some other pins (connected to a BT device) and then patch the STM’s USB read call to read from this buffer.
    Again. This should in theory work right?
    Would have been a fun project I think
  16. The Following 5 Users Say Thank You to badrax For This Useful Post:
    Col19 (21st April, 2024), drdahmani2 (19th April, 2024), Qwarz (14th September, 2024), seal777 (20th April, 2024), tilki42 (19th April, 2024)
  17. #12673
    PelsonBMW's Avatar
    May 2020
    Eu
    Well i have kolimer loader that works with old HEX with ATMEGA and 23.11 newest vcds Version , but does not work with ST32 chip , is there any availible loader for 23.11 and ST32 ?
  18. #12674
    @PelsonBMW
    what about are you talk?
    for STM32 is many different loaders available
    - VIIPlusLoader from flyfvdi
    - KolimerVIILoader from flyfvdi
    - BadraxVIILoader from flyfvdi
    - V2Helper/V2PP_329 from ???
    - VAG DS V2 from sklad66
    - and last what i found new variant like drdahmani2 posted
    seller speak it didn't need Loader but i don't trust him
    maybe you mean B03-ST? It's clear to call!Nobody will support this fake.
    @drdahmani2
    can you share link?
    tell as more about this new interface. is it true that it work with out loader?
  19. #12675
    Nov 2023
    Atmega162 vcds hex-v2 Kolimer162VIILoader V7.24.01 ,support vcds v23.11.0 software,support multi-languages, just can do 1996-2015 old cars
