Page 848 of 854 FirstFirst ... 348748798838843844845846847848849850851852853 ... LastLast
Results 12,706 to 12,720 of 12803
  1. #12706
    Col19's Avatar
    Jan 2019
    France
    Hi friends
    I had also bought an stm32f405 "supposedly" with possible update, using it only with its charger and software provided, after 6 months of use (without ever antivirus or web) the cable is is blocked all the LEDs light up, when I do a firmware restore (provided by the seller) it reaches 100% flashing then indicates that it is blocked.
    So i tried other older firmware , more recent... still blocked It also has the 8 pin chip on the back of the PCB, in short i think the only solution would be to encourage the king Badrax to help us keep the cables up to date. another STM32F405 but for how long will it be used ?
  2. #12707
    Aug 2020
    Quote Originally Posted by Col19 View Post
    Hi friends
    You do know that fly is the one who makes the loader and the hex v2? Buy one of his if you want to keep the hex v2 updated
    If you bought one and it came with kolimer or badrax loader then contact fly if you want to update the hex v2
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  3. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    Col19 (30th April, 2024)
  4. #12708
    May 2020
    • [COLOR=var(--text-normal)]Okej guys first i have atmega it works with my golf 5 and an audi a6 c7 but not C8 so i buy the more expensive one from ali like 80 dollar and now im angry i got the STM415 instead of STM 429 chip i cant do even secuirty access with it i can with atmega [/COLOR]
      [COLOR=var(--interactive-normal)]
      [/COLOR]
      [/COLOR]
      [/COLOR]
      [/COLOR]
    • [07:08]
      [COLOR=var(--text-normal)]So i need a good seller plss i dont trust everyone they allways send you the wrong chip when i but this in the discritpion its says stm429 but i got 415 i can use it but secuirty access dont work i can user it with out loader the 415 thats the nice thing
      [/COLOR][COLOR=var(--text-normal)][/COLOR]
  5. #12709
    Nov 2023
    Quote Originally Posted by smoke100 View Post
      [/COLOR]
      [/COLOR]
      [/COLOR]
      [/COLOR]
    • [07:08]
    Send an aliexpress dispute, the goods are wrong, return the refund
  6. #12710
    Oct 2017
    I have vcds hex-v2 STM32f405 and I want to run it. What loader will be good for the interface and vcds version,
    and will it work with vcds AKP Polish.My vcds is on a better pcb, better version
  7. #12711
    Nov 2023
    Quote Originally Posted by audiobesst1111 View Post
    It is fly vcds hex-v2
  8. #12712
    Oct 2017
    VIIPlusLoader 08.023.11 or VIIPlusLoader 08.024.11 version VCDS ?
  9. #12713
    Nov 2023
    Mega Download link:
    https://mega.nz/folder/CIk2UaLI#ORjmykOKTDgGkFClCYpHRA
    Changelog:
    1. VCDS V08.024.04 VIIPlusLoader
    2. Fixed bugs
    3. Add several ECU module diagnostic identifications
  10. #12714
    May 2020
    i just sell it in facebook marketplace i put a new order now for stm 429 from poland warhouse
  11. #12715
    Aug 2020
    Hello! I am sure that I have a harware problem with Vcds Clone ARMSTM32F429 Fly Loader 08.024.04. To any VAG car with CAN (ignition or engine on) give the mesaage CAN TESTING and can not connect to the car. Contacted Fly team and told me to send back the interface. From Europe to China and back to me it is nonsense. Can you help me with some stepts that I can check myself on the PCB? ThanksIMG_9994.jpg
  12. #12716
    Oct 2017
    I understand that my vcds will work with vcds AKP ?
  13. #12717
    @audiobesst1111
    yes, you can use latest VIIPlusLoader and https://www.vcds.eu/downloads/VCDS-A...-Installer.exe
    but did you sure that you cable working? your MIC2920A look as fired out
  14. #12718
    France
    Quote Originally Posted by Thecracker84 View Post
    Of the ones I've tried, I would recommend the 65-70 euro one which has the ST32F429 chipset with two capacitors. I got mine from Aliexpress from a seller with a warehouse in France and shipping within 5 days to Italy. I got 4 of them and they all have real F429 chips with two capacitors. Loader Fly V2 VIIPlusLoader-08.023.11 VCDS 23.11. Upgradable, said by the seller. I'm sharing with you so we can share information about updates and various issues.
    https://it.aliexpress.com/item/1005006528441039.html
    Hello ,friend
    Could you share with us photos of your vcds cable purchased from this reseller? And also license info on vcds software release 23.11 about tab?
    Is it registered registered in FLY V2, V2 or nothing? or @drdahmani2 cable https://www.digital-kaos.co.uk/forum...8&d=1713527619
    and do you access long coding and sfd?
    THANKS
  15. #12719
    Feb 2019
    Quote Originally Posted by Pater Fortunato View Post
    Try downgrade to the previously ViiPlusLoader 08.024.03 and check it.
  16. #12720
    Oct 2017
    Quote Originally Posted by miouser View Post
    @audiobesst1111
    My vcds has never been used, so I think it should be functional. How to check
    In my vcds, MIC2920A looks like it has been changed because it is manually soldered.
