Page 85 of 854 FirstFirst ... 3575808182838485868788899095135185585 ... LastLast
Results 1,261 to 1,275 of 12803
  1. #1261
    Oct 2008
    On Earth
    Quote Originally Posted by lukisio View Post
    Hellow. i have a problem, becouse my vag1062 not read mensuring block. Block 1.1 ok, but 1.2, 1.3,1.4 is N/A? I have a full version. v200. Please help me. HEX CAN v1.83
    You don't have a real original softwear you have a cracked chinese softwear and this is the problem. It cannot show everything.
    Sorry
    Good luck
  2. #1262
    Thanks very much, that clears up a lot...
  3. #1263
    And that is not all, DTC is wrong decoded
  4. #1264
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by kevinb2u View Post
    And--I would unsolder the GAL and/or the ATMEGA to flash externally? The "Final Solution" says to flash, but not how. I do have Willem programmer and adapters, and pretty good at SMDs, but have yet to try it. Thanks again
    you can flash the Atmega with PonyProg software via Parallel port ...
    all the best
    mishu
  5. #1265
    Quote Originally Posted by mishu_b View Post
    all the best
    mishu
    Thanks, What do you guys use for hook-up wire from LPT cable to the PCB? Thinking a strand of copper might work ok, also have steel MIG wire, probably would not take solder well. Something better at Radio Shack I should get?
  6. #1266
    Feb 2009
    Default vagcom
    Where can i find faults codes for skoda?
  7. #1267
    brasil
    Quote Originally Posted by PEDRO4053 View Post
    Hello my cable apare?e USB\VID_0403&PID_FA20\RT000001 the one what would this last one be I number RT\000001?
    Pedro
    I wander in the vidpidfix
    Hello
    Am I with a problem when I try to use the vidpidfix him of the mistake?
    thank you
    Pedro
  8. #1268
    Junior Member max4ever's Avatar
    Romania
    Select RT0000001 , click "Open" and go "Write Default EE Data"
  9. #1269
    Feb 2011
    Quote Originally Posted by paro44 View Post
    @apophizz:
    You have ft232rl inside, so your solution is here: (http://www.digital-kaos.co.uk/forums...ft232r-160237/)
    Follow the steps and your interface should work again.
    is there a difference between FTDI 232 R und the RL Version? or its the same?
    a friend of mine has a (i don't know the correct word in english EEPROM Programmer/Burner) who i can write the EEPROM on it, i hope you know what i mean...
    is it easier to rewrite my cable with this? or should i do it with the tutorial i get from paro44?
    regards
  10. #1270
    Feb 2011
    hello
    i'm new user and i want reprogramm my vag-com but i can-t dowload the tutorial.rar : i have not permission.
    Why, ? can you help me please ?
  11. #1271
    Feb 2011
    sorry,
    now it's good : i have posted One message and its good
  12. #1272
    brasil
    Unhappy I not help cable recognized by Windows
    After made the whole work following tutorial ,quando it blinked the green led I removed and I connected it was not more recognized by the windows.When do I connect in the car the green led he/she lights if it connects in the computer the red led he/she lights I must have made something wrong more with I can repair?
    Now my cable this killed somebody it can me to help ,como I can do for the windows to recognize him for me to try to carry the draiver.
    Thank you
    Pedro
  13. #1273
    Dec 2010
    Quote Originally Posted by spongemak View Post
    Found the solution for my problem, it's a software problem, here is the right setup for 10.6.2:
    http://rapidshare.com/files/44543038...-Installer.exe
    Source:
    Google Translate
    Hello spongemak,
    You did a great job to find this working .exe
    Really a big thank you, cable 10.6.2 working 100%
    and saving long coding now )
  14. #1274
    Junior Member Carlos_'s Avatar
    PT
    Quote Originally Posted by kodo28 View Post
    Hello spongemak,
    Indeed it was a great job this finding
    But i have a little problem, i can?t run the exe. the program has 2 exe, one of them is the one that the shortcut on desktop leads to, and when i click it (the shortcut or the exe itself), nothing happens!
    I've tried on 2 different computers (Windows 7 32 and 64bit) and the result is the same.
    Can someone give a suggestion?
    Thanks in advance
  15. #1275
    H? friend , I installed the program VCDS 10.6.2 in the PC windows XP 32bit , it is full working fine now !!!!! , thanks
    My cable is VCDS-10.6.2 with FW 1.83 - drive R-T USB direct , version 2.6.2.0 , USB\VID_0403 PID_FA24\RT000001
    But , what is the correct icon to start ?
    VCDS.EXE
    or
    VAG1062.EXE
    Thank you for all DK members.
