Page 86 of 854 FirstFirst ... 3676818283848586878889909196136186586 ... LastLast
Results 1,276 to 1,290 of 12803
  1. #1276
    Junior Member max4ever's Avatar
    Romania
    VCDS.EXE is version 10.6.3 kind of!?
    VAG1062.EXE is version 10.6.2!Sure!
  2. #1277
    Default Not plugged into car
    Please help: I have a Vag-com 908 china cable. Unfortunately I had to reinstall my operating system (win7). Now the cable doesn't want to work. My previous system was also win7 where it's worked. With the china 908.1 software I get time out error message always, and the software is not starting.
    With the 908.0 version the software is starting but I get "not plugged into car" message however it's plugged. This also happening with the 812.4 version.
    I have never used or installed higher than 908 version.
    When I plug it in the car I see green LED light.
    What is the problem?
  3. #1278
    Newbie s3mick's Avatar
    wakefield uk
    Hi all, tried reflashing the atmega chip again, the first time was ok but still had shareware, but now ponyprog cannot access it, also the led is not working, does any one know if i have blown/shorted some thing, i can see the cable when pluged into the usb port with mprog and vidpidfix, thanks
  4. #1279
    wakefield uk
    just tried again and the cable works on the car but not when pluged into the lpt port, light is off but comes on when unpluged, think its a problem with the earth wire on the atmega chip? anyway tried scan on car but only runs part through then says requires registerd cable and in the info part it says requires full scan or something to activate, tried several times but no luck, then asked for drivers again and now wont find cable in windows xp, any help please. thanks mick
  5. #1280
    wakefield uk
    just like to add not connected to intenet when running vcd 805.1 if this makes ant differance
  6. #1281
    N.Ireland
    Lost use of my vag com lead a couple of days ago due to running updated software. Was working with VCDS 10.6.0 with firmware 1.81, Will UPGRATE FIRMWARE 908.rar return it to its original state or will I have to use different software and drivers.
    Could I also flash it to version 805 if I wanted or is it hardware dependant
    I also notice in the 908 firmware there is a modified eprom file should I use this or original?
    Andy
    PS my hardware no longer knows when it is plugged into the car but updated software tried to upgrade my firmware to 1.83, Could this cause it to not know if its connected to the car?
  7. #1282
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by Volki View Post
    Use VCDS_908.0_mod
  8. #1283
    Can anyone PM me where and what kind of interface to buy for this software post #1274
    http://www.digital-kaos.co.uk/forums...-Installer.exeplease? Thanks.
  9. #1284
  10. #1285
    Feb 2011
    hiho, on page 84 you can see mine pictures of 908 interface with the FTDI232RL chip and with the instructions "http://www.digital-kaos.co.uk/forums/f152/solution-clone-vcds-908- to flash FT232R 160 237 / "i made it to flash my FTDI chip, and now is also recognized correctly. Unfortunately, now I get always the message "interface not plugged into car" I think I have now the ATMEGA chip to flash with PonyProg, is that correct? my problem is, I can't open PonyProg because the DIPortIO.dll is missing ... what can I do?
    regards
  11. #1286
    Romania
    i have usb-serial adapter for programing atmega and takes me 4 hours for programing and verifing. it is normal?
  12. #1287
    Dec 2010
    It should be less then 2 min job (only programing Atmega).
    Regards, Davorin
  13. #1288
    Romania
    what is the problem? usb-serial adapter or avr programer?
  14. #1289
    N.Ireland
    In answer to my own question above
    Used modified eprom file and all went well
    Unit now knows when ignition is on and working as it was.
    I used an external usb programer for the atmel without any problems (Smart Pro X5) Using the 4 wire ICP connector
    ANdy
  15. #1290
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by dariusddj View Post
    I bet in the USB-SERIAL Adaptor.
    Usually they never work for this kind of applications: uC programmers, programmable automation controller...
    You can try a PCMCIA or ExpressCard adaptor:
    For old laptops with PCMCIA:
    PCMCIA to RS-232 Serial DB9 CardBus Adapter Card Laptop - eBay (item 370481493060 end time Mar-06-11 02:43:56 PST)
    For new laptops with ExpressCard:
    *RS-232 Serial Port Express Card ExpressCard Adapter - eBay (item 230513418951 end time Mar-17-11 01:51:53 PDT)
    USB<->RS232 adaptors emulates a COM port and sometimes the emulation won't work for some devices (programmers and PLCs)
    Those PCMCIA or ExpressCard adaptors add a physical COM port to your laptop.
    Did it help? Push Thanks below
