Page 9 of 854 FirstFirst ... 45678910111213141959109509 ... LastLast
Results 121 to 135 of 12803
  1. #121
    Quote Originally Posted by ivanxxx View Post
    I think you did not program Gal16v8 correctly?
    Is it possible to burn the gal onboard? Or only with an external programmer device? There is no instruction for this.
  2. #122
    Oct 2008
    On Earth
    External Programmer you need and the tutorial you can find at post 98. The tutorial is made by Aminebot and is posted by bnad3m
    Good luck
  3. #123
    Knows somebody here the checksum of the jedec?
  4. #124
    hi all,
    question,
    I have several 908 in English,
    cable in English I can arrange to work with software in Spanish and that this working?
    thank you very much in advance
  5. #125
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by PETERALC506 View Post
    hi all,
    question,
    You should try that by your self, even if your spanish soft disables your cable you have here everything needed for repair.
  6. #126
    Sep 2010
    hi i bought a dual k line interface on ebay 2 weeks ago. i used it this morning on my 02 audi and the software from the seller kept crashing(by the way the software was VAG-COM 409)so before checking around i downloaded vcds lite 1.0 and it seemed to work fine. does this mean that i can use any software that's been cracked ?
  7. #127
    Oct 2008
    On Earth
    Quote Originally Posted by dubdude View Post
    You need the last ftdi chip driver to work with your interface not vagCom driver.
    Any good cracked version works good with your interface. You can use 311.2, 409.1 and vcsd lite. No metter which one but right cracked version.
    good luck
  8. #128
    Sep 2010
    what about some of the newer versions like 905,908 etc. and forgive my ignorance but what is "ftdi " and were do i get the driver. as you can see the "newbie" sign doesn't lie
  9. #129
    Oct 2008
    On Earth
    Ftdi is a chip inside the interface and is named FTDI232RL or BL or BM. You need driver if you like to have a comunication between you computer and the interface.
    Ftdi Chip drivers you find here, it is the last one.
    http://www.ftdichip.com/Drivers/CDM/...0Certified.zip
    For the newer VCSd you need other kind of interface, you need an HEX-CAN interface.
    For your interface you need just that softwear I told you.
    BTW don't worry it is normal to ask if you want to learn something.
    What do you think that all DK mates are "engineers"?
    One of us know others don't that's life but all of us we'll always learn something during all our lifes. Noone knows everything.
    Good luck
  10. The Following User Says Thank You to mattydr67 For This Useful Post:
    ecufix (14th March, 2021)
  11. #130
    B & H
    Quote Originally Posted by mattydr67 View Post
    Good luck
    Thanks to people like Mattydr67 this forum is the best in the world
  12. #131
    DK Veteran manocao's Avatar
    i dont recommend ftdi driver version 2.08.02
    i updated opcom with their files and interface blocked
    in my opinion, best working is 2.06.00 available here http://www.ftdichip.com/Drivers/CDM/CDM%202.06.00%20WHQL%20Certified.zip
  13. The Following User Says Thank You to manocao For This Useful Post:
    rudamie (1st August, 2013)
  14. #132
    Oct 2008
    On Earth
    Quote Originally Posted by manocao View Post
    My friend for Op-Com it is not good 2.08.02 but for VagCom it is.
  15. #133
    Sep 2010
    Quote Originally Posted by bibkare View Post
    I agree 100% with you im glad i found a smart and kind group of guys like all of you. thanks for the advice. Back to the topic. I downloaded 409.1 and loaded the new driver but it still freezes the program crashes and shuts vagcom down. however vcds lite 1.0 from ross tech runs fine but i can't do much in there. btw i am using vista 32bit for this and my clone is a KKL blue serial interface from ebay. i just realized i didn't disable UAC. can that be the reason
  16. #134
    RO-AG
    SALUT ARE CINEVA VAG 908 SOFTUL?
  17. #135
    RO-AG
    Does anyone HELLO SOFT VAG 908?
