Page 90 of 854 FirstFirst ... 40808586878889909192939495100140190590 ... LastLast
Results 1,336 to 1,350 of 12803
  1. #1336
    Feb 2011
    Quote Originally Posted by alex_SW View Post
    hi.i have a 912 cable,clone....
    if i run 10.6 software will i damage it?or can it be updated from 912 to 10.6??
    tnx
    As far as i have seen,right now there are no free dumps for 10.6 around,so
    just run your cable with 912 software.
  2. #1337
    Mar 2011
    HI i have an Audi a6 4f and need obd software
  3. #1338
    lee_hdi's Avatar
    Sheffield
    Would this be ok to scan and change settings on VAG cars? - Vag com 10.6(FT 232 BL),
    And do you think it will include the software?
  4. #1339
    Dec 2010
    Quote Originally Posted by Carlos_ View Post
    Indeed it was a great job this finding
    But i have a little problem, i can?t run the exe. the program has 2 exe, one of them is the one that the shortcut on desktop leads to, and when i click it (the shortcut or the exe itself), nothing happens!
    I've tried on 2 different computers (Windows 7 32 and 64bit) and the result is the same.
    Can someone give a suggestion?
    Thanks in advance
    You have to set the shortcut created by the installer to windows XP compatibility, the correct exe is VAG1062.EXE
  5. #1340
    Dec 2010
    Quote Originally Posted by viercha View Post
    This will work with FT232BL?
    This is only for 10.6.2 cables that came with bad software.
  6. #1341
    Oct 2008
    On Earth
    Quote Originally Posted by lee_hdi View Post
    If it's what they said the sw will not be a problem.
    Normally they will provide the sw but you know the companies it is a Chinese one, everything could happend.
    Well you can try.
    Good luck
  7. #1342
    brasil
    Default To update cable 812 with PonyProg2000.
    Hello
    I have a problem with my cable vcds 812 atmega 162 ft 232bl I don't get to carry the files vcds908 flash and eprom.hex * with PonyProg2000 ,mais the files vcds805.bim carries normal it will be that has some protection in the atmega162 or the files that I have they are bad.
    Thank you
    Pedro
  8. #1343
    Quote Originally Posted by KenshinPT View Post
    I bet in the USB-SERIAL Adaptor.
    Usually they never work for this kind of applications: uC programmers, programmable automation controller...
    You can try a PCMCIA or ExpressCard adaptor:
    For old laptops with PCMCIA:
    PCMCIA to RS-232 Serial DB9 CardBus Adapter Card Laptop - eBay (item 370481493060 end time Mar-06-11 02:43:56 PST)
    For new laptops with ExpressCard:
    *RS-232 Serial Port Express Card ExpressCard Adapter - eBay (item 230513418951 end time Mar-17-11 01:51:53 PDT)
    USB<->RS232 adaptors emulates a COM port and sometimes the emulation won't work for some devices (programmers and PLCs)
    Those PCMCIA or ExpressCard adaptors add a physical COM port to your laptop.
    I know, this post is some time ago but I think it is important to know:
    "--> Compatible to USB2.0 Full Speed throughput"
    This means, that the Chipset is universal serial Bus (USB).
    In the device manager you will find "usb serial converter COMx) - same as a 2$ USB-Serial Converter.
    Most cheap cards are working as USB-to-Serial. This is the same as you can use a normal USB-to-Serial Adapter. These cards doesn't even work togeter with many diagnostic tools.
    Better you buy a card with Oxford chipset. Like the "EX-1350" or "EX-1370" or similar. These cards work as good as a real RS232/COM Port. I know many people who had this problem.
    Try to connect an old opeltech or carsoft interface with the cards. Then you will see. It will not work, if you havn't an Oxford chipset.
  9. #1344
    Junior Member Carlos_'s Avatar
    PT
    Quote Originally Posted by spongemak View Post
    Still not working
  10. #1345
    Newbie s3mick's Avatar
    wakefield uk
    Hi all. I've tried to repair my 704 cable and completely f*cked it up, been in touch with an ebay seller and he can provide a 10.6 cable, will this be ok to use with the vcds 805 software, or will I have to flash anything, also is there anything I should ask the seller about the cable. Thanks mick
  11. #1346
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Adjust the cable as VCDs 10.6 to version 10.6.3 en?? Anyone got a working DUMP? Thank you ... We VCDs CLONE making trouble, sometimes it does not find the pc ... pc is fine, so I want to try another version or 10.6.2, if anyone has unlocked DUMP please share ....
  12. #1347
    After thousands of posts, many good tutorials, and several hours, I am sure now, not to find any Dump for the German 908. But now I know that serveral people have it ^^
    So if you will change/trade - let me know what you need or what you want to have for it. --> PM
    Thank you.
    By the way... If you delete all double messages and questions here in the thread, I think the thread would get very small - hehe
  13. #1348
    Member paffendorfbg's Avatar
    Default vcds 10.6.2
    nobody did it
    vcds 10.6.2.exe locked 4 of my clones (vag 106)after 5 -6 times usage
    so is there somebody to check this one
    VCDS-Release-1063-Installer.rar - 4shared.com - online file sharing and storage - download
  14. #1349
    Quote Originally Posted by paffendorfbg View Post
    nobody did it
    just use good old 908
    all china 106 have huge problems
  15. #1350
    Romania/Targoviste
    I buy VAG com 10.6, chinesse clone. I use whit VCDS10.6.0 software, whith VAG-COM 704.1 and not working,
    For test interface all OK, but tell vag com is not conected on car. Test is on VW Jeta 2009.
    Interface is defective, or software, or I dont know to use?!?.
    Thanks.
