Page 92 of 854 FirstFirst ... 42828788899091929394959697102142192592 ... LastLast
Results 1,366 to 1,380 of 12803
  1. #1366
    Oct 2008
    On Earth
    Mate the loader is for what version?
    Please.
    Good luck
  2. #1367
    Milky Way
    Quote Originally Posted by mattydr67 View Post
    Please.
    Good luck
    for 10.6.3 version.
  3. #1368
    Today I have tried to update my cable, but something went wrong and the atmega hasn't been programmed correctly. During the flash verification ponyprog showed an error, and the programming process stoped.
    Then, I tried again to reprogram the atmega, but now ponyprog shows "Error 24" and I'm unable to do it.
    What is happening? I think that atmega is blank. Do I need to use a HVP programmer to write it?
    Sorry for my english.
    Regards.
  4. #1369
    Milky Way
    Did you erase the avr first? you can't write on the flash without erase it first...
  5. #1370
    Yes, I did.
  6. #1371
    Oct 2008
    On Earth
    Quote Originally Posted by LuisAndre View Post
    for 10.6.3 version.
    One more question please.
    This will work with my 10.6.0 ft232BL tool?
    Thanks very much
    Good luck
  7. #1372
    Milky Way
    Thanks very much
    Good luck
    Other users told me it works well with that cable... even with firmware 1.81.
  8. #1373
    May 2009
    Well Works from 1.83 and BL as the chip
    ISIS 2.8, ICOM, ISSS, ISID
  9. #1374
    Oct 2008
    On Earth
    One question
    Do I need to run the patch everytime or just at the first time?
    Good luck
  10. #1375
    DK Veteran bibkare's Avatar
    B & H
    I tried to download the patch even my AV NOD32 was deactivated but still keeps to delete it and warns me that virus was detected, anyone has the same problem?
  11. #1376
    Feb 2011
    France
    "trojan detected" with Kaspersky but think it's was a false positive
  12. #1377
    blackpirate's Avatar
    Jun 2009
    Quote Originally Posted by bibkare View Post
    1. haveing the AvV deactivated , it cant delete it!
    2. the file its clean!
    it just a false alarm caused by the protector!
    scan it on virustotal.com
    cheers L.A
    If freedom is outlawed, only outlaws will have freedom!!!!
  13. #1378
    if someone can confirm if it works with 912 interface....i have a 912 but right now i dont have car to test....
  14. #1379
    DK Veteran KenshinPT's Avatar
    PT
    One question
    Di I need to run the patch everytime or just at the first time?
    Good luck
    WRONG INFO:
    Maybe you already know the answer but you don't need to patch it everytime you open VCDS. xxxxx
    But I only tested the cable without a car. I tested only plugged into a 12V power supply.
    My bad... You need to patch everytime you run VCDS
    Did it help? Push Thanks below
  15. #1380
    Milky Way
    Quote Originally Posted by KenshinPT View Post
    No, everytime you start vcds, you need to run the patcher... because this patchs are done on the program memory and not on the disk. If you run only vcds, you may end with a dead cable...
