Page 93 of 854 FirstFirst ... 43838889909192939495969798103143193593 ... LastLast
Results 1,381 to 1,395 of 12803
  1. #1381
    Mar 2011
    Hi guys,
    quick question, I have an old K-Line 409 Vag-Com lead with F232BM chip. Is there any way to upgrade firmare here to clone a VCDS 908 lead.
    FYI I have cracked copy of Lite which is decent but lacking a lot of the new features that were added from v908. I have a Passat B5.5 without CAN interface, don't plan to upgrade car soon so doesn't even warrant buying updated clone cable..... unless it could allow access to full VCDS software features.
    Any help would be appreciated!
    Cheers.
  2. #1382
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by cmacinnes86 View Post
    Hi guys,
    Cheers.
    No updated
  3. #1383
    Milky Way
    Just some pictures... no illegal crack whatsoever here.... Remember, DK don't allow you to have it!
  4. #1384
    Mar 2011
    Quote Originally Posted by angelx431 View Post
    No updated
  5. #1385
    Milky Way
    I think he means you cant update your cable ... give yourself a present and buy a chinese crap cable...
  6. #1386
    Mar 2011
    Quote Originally Posted by LuisAndre View Post
    Good shout.... Chinese crap it is!
  7. #1387
    This cable can't be updated. There isn't an atmega inside of it.
  8. #1388
    I think that here peoples
  9. #1389
    Hi! Everyone!
    I have a problem with a cloned chineese vag 704.1.
    I got it from a client for repairs.
    I have reflashed atmega with 704.1 files.
    The cable is now recognized by the computer and the vag com, but when I connect it to the car, i get no response from the controller.
    When I click in the vag to connect to any controller the led on the cable is blinking, a couple of seconds later I get the error.
    I think it is a hw error on some of the components. Please help to resolve the problem.
    Here are the pictures form the cable and vag com :
  10. #1390
    Hi! Everyone, I've managed to repair the cable. The problem was that the pin #7 (K-Line) was not connected to the board correctly. So no communiocation with the car was possible.
    Best regards!
  11. #1391
    Quote Originally Posted by esrodi View Post
    Today I have tried to update my cable, but something went wrong and the atmega hasn't been programmed correctly. During the flash verification ponyprog showed an error, and the programming process stoped.
    Then, I tried again to reprogram the atmega, but now ponyprog shows "Error 24" and I'm unable to do it.
    What is happening? I think that atmega is blank. Do I need to use a HVP programmer to write it?
    Sorry for my english.
    Regards.
    My cable is working again . All I needed was to connect an external clock signal to pin 15 of Atmega162. I got this clock signal from a PIC. As the update process crashed, the fuses was wrong, and atmega didn't start.
    Regards.
  12. #1392
    brasil
    Regards.
    Hello I have the same problem with my cable, it will be that you were able with doing this work in the pin 15 of the atmega.
    thank you
    Pedro
  13. #1393
    pt
    hi
    is there an simlpe way to simulate CAN in this cable so i can see "CAN ready" my car only have k line.
  14. #1394
    Does anybody have a Binary file from the GAL26V8B?
    I have the JED but need the bin for flashing with a programmer (with PLCC 20 Adapter)...
  15. #1395
    Quote Originally Posted by PEDRO4053 View Post
    thank you
    Pedro
    You have the same problem, and what else? I'm not able to understand that you mean. Could you explain the problem better?
    Regards.
