Page 94 of 854 FirstFirst ... 44848990919293949596979899104144194594 ... LastLast
Results 1,396 to 1,410 of 12803
  1. #1396
    brasil
    Quote Originally Posted by esrodi View Post
    You have the same problem, and what else? I'm not able to understand that you mean. Could you explain the problem better?
    Regards.
    I recorded the epron and flash when I went to record the fuziveis the ponyprog it turned off when I tried to record again he/she gave error 24. Now I don't tie the cable, as I do to have this sign in the pin 15 of the atemega?
    Excuse my English I use Google translator
    thank you
    Pedro
  2. #1397
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by PEDRO4053 View Post
    thank you
    Pedro
    Maybe you set wrong fuses... for example: you disable SPIEN, or you activated FLASH/EEPROM protections.
    Did it help? Push Thanks below
  3. #1398
    brasil
    Quote Originally Posted by KenshinPT View Post
    I turned off atmega later I recorded the epron and flash when I went to record the fuziveis he/she gave error 24, now my cable doesn't call. I try to turn off the atmega of the error 24 my ,o cable this died with I do to do him to call again.
    Pedro
  4. #1399
    Oct 2008
    On Earth
    Quote Originally Posted by LuisAndre View Post
    Just some pictures... no illegal crack whatsoever here.... Remember, DK don't allow you to have it!
    Great job LuisAndre.
    Did you tried on a car?
    VCDS 11.2 it's need firmwear 1.84 to work well from what I know.
    I will try today the 11.2.
    The 10.6.3 works great with my VCDS 10.6 tool with BL inside.
    Good luck
  5. #1400
    Top Poster + mladen76's Avatar
    By the see
    Quote Originally Posted by mattydr67 View Post
    Good luck
    I have 10.6 whit a RL chip insade,I heard that it is not good chip so aht is the diference betwen RL-BL and can someone thel me will 10.6.3 coud work whit my cable or...?
  6. #1401
    Milky Way
    Not true... You can use firmware 1.83 on v11.2.0. I have tested my loader for v11 beta on several cars... So far so good.. No bad error codes, good live view, autoscan works on both can and kl.... I dont have 10.6 dump, so i cant give live to my broken 10.6 RL cable so i can only do some tests and loaders to 908 cables.
  7. #1402
    Oct 2008
    On Earth
    Yesterday I tested the 10.6.3 and it works great on two cars.
    Today I tried to conect to another car that come in the garage and when I plugged the interface it asked me for the drivers and the conclusion is that the interface Atmega was erased.
    Yesterday I run the exe file then the patc and I didn't push exit I let it on the screen.
    My interface it was ft232BL 10.6.0 with dump.
    LuisAndre please tell me if I did something wrong?
    Or is just becasue my tool have ft232BL inside and it was programmed with 10.6.0 dumps. I have firmwear 1.83 as well.
    Good luck
  8. #1403
    H? mate ,
    some version 10.6.3 for test ?
    my cable is FW 1.83 chinese , but is ( USB direct ross-tech )
    version 10.6.2 doesn't works , is bad , cell 000 measure bloks do not show .
    Thank you for all DK members.
  9. #1404
    Oct 2008
    On Earth
    I fixed my tool and now it's working again.
    I just reright the ftdi with Mprog.
    I don't know what happend that it changed the driver after I used with VCDS 10.6.3.
    But it dosen't erased the Atmega, just changed the ftdi drivers.
    Now it's workingf again and I will try on several car and then I will try back with the 10.6.0
    Maybe this was casue of driver changing.
    It's working with 11.2 too but I think that for new protocols you need to upgrade the firmwear to 1.84
    I will try to do this to see if I will have a new protocol car to try.
    Now it's working with 1.83 how LouisAndre said.
    Good luck
  10. #1405
    Member paffendorfbg's Avatar
    Default vcds
    Please share your .ept
  11. #1406
    Oct 2008
    On Earth
    Quote Originally Posted by paffendorfbg View Post
    ept files are here.
    it is the same like for 908.
    @LouisAndre
    I tested again and it erase my Atmega again.
    I can repair the ftdi I can do the TEST and everythings ok but when I wanna do an Autoscan, it search just 2 controlers and then stopped.
    In ABOUT it show the serial but it aint Full Registred/Activated.
    So in conclusion this patch it is ok for ftdi232RL not for BL
    Atention: For the mates who have dumps you can try but if you have and you cannot reprogrammed, don't try becasue you'' cry after.
    I'm reprogrammed mine and I will forget about this "patch"
    Thanks for trying.
    Good luck
  12. #1407
    Milky Way
    No m8, I only have BL cables... And it works... Anyway, you are right in one point... autoscan doesn't work very well..
    And you can find the dumps for the cable here on DK if something goes wrong. Again, use it only if you want... thats the spirit.
    I also sent you the new loader for V11.2.
    Anyone interested on this , pm me.
  13. #1408
    Oct 2008
    On Earth
    Thank you very much LouisAndre but I told you, for me it dosent works and it erased the EEPROM twice using 10.6.3
    No you don't understand me well, I used Autoscan and how I said it worked very well.
    The day before yesterday it works great on several cars but yesterday when I plugged again into the USB the drivers was changed. I fixed it and it becomes Unregistred.
    I reprogrammed the Atmega and after I tried Autoscan in few cars ( several times ). The EEProm was erased again.
    Take care.
    BTW I don't need dumps for 10.6 and I don' thik that's for free here.
    Thanks again
    Good luck
  14. #1409
    Jan 2011
    Hi, can you advise me some Chinese seller, where I can buy VCDS hardware 10.60 or 10.62/63 with FT232BL/BM chip inside? There is so many bad sellers with even worst products, but maybe somebody has good experience with some companies?
    And is the VAS 5054 better than VCDS?
  15. #1410
    Dec 2010
    Could someone of you tell me where can I get an 912 original version sofware ?? impossible to find it on net...If someone can send it for me
